DOS Questions
Reply 20 of 258, by DustyShinigami
Grzyb wrote on 2025-03-02, 13:06:
DustyShinigami wrote on 2025-03-02, 12:09:
Regarding SHSUCD - can it be used to load physical CDs as well? Or is it purely images?
SHSUCDX is supposed to be an MSCDEX substitute - so yes, it should work with real drives as well.
That's what I thought. Although I've not had much luck getting it to work yet. I could be wrong, but don't you need to specify the path of an image? When you initialise SHSUCDHD? That loads the device driver and then when I've set up SHSUCDX, it assigns the drive to E by default. At least for me. I presume there's a switch/command to specify what drive you want it to be? So instead of E it will be F etc?
OS: Windows 98 SE
CPU: Slot 1 Pentium III Coppermine 933MHz (SL448)
RAM: Kingston 256MB 133MHz
GPU: Nvidia 16MB Riva TNT/128MB Geforce 4 Ti 4200
Motherboard: ABit AB-BE6-II Intel 440BX
Sound Card: Sound Blaster Live Value CT4670
Reply 21 of 258, by Grzyb
See the following example:
shsucdhd /F:g:\test300m.iso
shsucdx /D:shsu-cdh,h
it makes the contents of g:\test300m.iso accessible as drive h:
Also, make sure the LASTDRIVE statement in CONFIG.SYS allows for sufficient number of drives - for this exmple, you need at least:
lastdrive=h
In 2003, I voted in favour of joining the European Union. However, due to later developments - especially the restrictions on cash usage - I have withdrawn my support. DOWN WITH THE EU!
Reply 22 of 258, by DustyShinigami
Grzyb wrote on 2025-03-02, 13:51:
See the following example: […]
lastdrive=h
Ahhh, okay. Thanks for the tips. I didn't realise something can be added at the end of /D:shsu-cdh. 😀 I know in the config.sys file I've added the L: switch for the basic MSCDEX driver. So if I add something like J as my last available drive, I should be able to add multiple mounted drives, right? Particularly if a game has 3-4 CDs. Am I able to add multiple paths for each image so it's like this...?
shsucdhd /F:g:\test300m.iso; g:\test301.iso; g:\test302.iso
shsucdx /D:shsu-cdh,h, i, j
Thanks
OS: Windows 98 SE
Reply 23 of 258, by DustyShinigami
Okay, my other issue… I seem to be having a problem with memory in DOS, although it’s for one specific game at the moment. Harvester. Whenever I run the install, I get greeted with a blue box that says ‘Your system does not have enough installed memory to run. 8Megs are required.’
I’m guessing this is conventional memory…? If so, I only have 640K. I have EMM386 enabled in the config.sys file, and I’ve tried different combinations, but I can’t seem to get it to work. This is how it’s set:
The attachment IMG_4135.jpeg is no longer available
Any ideas? I checked the manual, but that covers the same stuff I’ve tried.
The attachment IMG_4136.png is no longer available
I think I tried with HIMEM disabled, but that’s required for EMM386, right?
EDIT: Apparently the Windows setup does the same thing, so there must be something else I need to do.
OS: Windows 98 SE
Reply 24 of 258, by jakethompson1
DustyShinigami wrote on 2025-03-03, 01:07:
640K is the most conventional memory any IBM-compatible has without doing tricks with video memory, so it's not that.
It sounds like this game wants EMS.
Run MEM /C /P to help get an idea of what is going on.
Reply 25 of 258, by DustyShinigami
jakethompson1 wrote on 2025-03-03, 01:17:
640K is the most conventional memory any IBM-compatible has without doing tricks with video memory, so it's not that. It sounds […]
Okay. The fact it’s doing it in Windows as well though is very strange. ‘[/m]’ doesn’t appear to work.
But yeah… everything looks fine.
The attachment IMG_4138.jpeg is no longer available
I can’t find anything on Google so far about this particular issue.
OS: Windows 98 SE
Reply 26 of 258, by jakethompson1
You didn't show the second screenful about free EMS. Another possibility is that this game doesn't properly handle extremely large amounts of total or free memory like 256MB, and thinks it's less than 8MB.
Reply 27 of 258, by DustyShinigami
jakethompson1 wrote on 2025-03-03, 01:41:
Ah. Sorry. I'll go grab that now. But yeah, the thought did cross my mind that it could be 'too much'.
Is it this bottom part...? Or was there something else that should've happened?
The attachment IMG_4139.JPG is no longer available
OS: Windows 98 SE
Reply 28 of 258, by jakethompson1
When EMM386 is running and providing EMS, MEM will state as such. You either aren't running it at all, or are running EMM386.EXE NOEMS.
Try having just device=c:\windows\emm386.exe
in config.sys
Reply 29 of 258, by DustyShinigami
jakethompson1 wrote on 2025-03-03, 01:51:
in config.sys
Ahh. Yeah, I believe I was. ^^; Just changed it.
The attachment IMG_4140.JPG is no longer available
The attachment IMG_4141.JPG is no longer available
OS: Windows 98 SE
Reply 30 of 258, by jakethompson1
Then if your game doesn't work now, it's an issue with it handling large memory sizes.
Reply 31 of 258, by DustyShinigami
jakethompson1 wrote on 2025-03-03, 02:01:
Ah-haaa! I've just discovered there's an issue with the image files and that's why it keeps complaining. The original CDs are perfectly fine though.
OS: Windows 98 SE
Reply 32 of 258, by DustyShinigami
DustyShinigami wrote on 2025-03-02, 14:28:
Ahhh, okay. Thanks for the tips. I didn't realise something can be added at the end of /D:shsu-cdh. :) I know in the config.sys […]
lastdrive=h
Thanks
Still haven’t figured out how to add multiple image drives, nor being able to use it for physical CDs. I’ve had to keep re-enabling my default CD driver instead in order to use physical CDs.
OS: Windows 98 SE
Reply 33 of 258, by DustyShinigami
Found this thread on adding the command for an optical drive - https://forums.overclockers.com.au/threads/te … .1313243/page-2 - but it isn’t working for me. Added it to the autoexec, but it just says Can’t open CD driver OPTICAL. SHSUCDX can’t install.
OS: Windows 98 SE
Reply 34 of 258, by DustyShinigami
Hi. Quick question: what DOS command can be used to move files from one folder to another?
I’ve tried ‘move’, but it tends to move the folder with its contents, if I use the /e and/or /s switch. But it’s just the files inside it I want in this case. Thanks.
OS: Windows 98 SE
Reply 35 of 258, by jakethompson1
Not sure what you're trying, but you could cd to the source directory, then move *.* somewhere_else
Reply 36 of 258, by DustyShinigami
jakethompson1 wrote on 2025-03-11, 00:43:
I was trying to copy/move Cute Mouse files I have saved in a folder of Windows/DOS goodies I’ve collected to my DOSDRV folder on the C drive. I can’t recall what I did, but I think I put them in a temp folder whilst trying something and then tried to move them from there into C:\DOSDRV\CTMOUSE.
I’ll have to give that a try next time. Thanks. 😀
OS: Windows 98 SE
Reply 37 of 258, by DaveDDS
DustyShinigami wrote on 2025-03-11, 00:20:
Have you got my DDLINK?
You can run DDLINK in local mode (No C=, L= or P=) which accesses two directories on your local system.
Simple get the directories you want on Left/Right sides of screen, use <- -> to select the one
to work within, Up/Down arrows to select the file you want to copy, then 'C' to copy it to the
other side.
If you want to do a bunch of files, 'M' to do a Multiple copy.
https://dunfield.themindfactory.com ; "Daves Old Computers" ; SW dev addict best known:
ImageDisk: rd/wr ANY floppy PChw can ; Micro-C: compiler for DOS+ManySmallCPU ; DDLINK: simple/small filetransfer(w/o netSW)via Lan/Lpt/Com
Reply 38 of 258, by DustyShinigami
DaveDDS wrote on 2025-03-11, 01:45:
Have you got my DDLINK? […]
other side.
I don't believe so. What's that? A third-party manager of some sort?
OS: Windows 98 SE
Reply 39 of 258, by DaveDDS
DustyShinigami wrote on 2025-03-11, 01:50:
It's essentially a file transfer tool that can copy files over Serial, Parallel or Network.
It has a 2-side(2 directories) display and quite a few actions it can perform
(Copy, Rename, Erase, View, set-Attrs etc. - on either end)
It's the primary method I used to move files to/from and between DOS systems.
There's a thread about it here: DDLINK: Easily move files between/To/From DOS systems
Dave
