Reply 20 of 220, by red-ray
 - Oldbie
PARKE wrote on 2025-05-04, 13:30:Do you have all the CPUID's in the same look-up database ?
It's actually a constant C structure and all the CPUID/S-Spec SIV knowns about are in the same structure, but it does not have "all the CPUID's" there are only 689 entries starting with 0400 486DX and currently ending with 068A SL5QK, the same CPUID is usually there multiple times, once for each S-Spec. It started with i486 ones to populate the dropdown and I have added more over time.
