Reply 20 of 25, by shevalier
This is the main problem of the top NVIDIA video cards of that time.
And no conspiracy theories.
They all dried out completely, overheated and burned.
Aopen MX3S, PIII-S Tualatin 1133, Radeon 9800Pro@XT BIOS, Audigy 4 SB0610
JetWay K8T8AS, Athlon DH-E6 3000+, Radeon HD2600Pro AGP, Audigy 2 Value SB0400
Gigabyte Ga-k8n51gmf, Turion64 ML-30@2.2GHz , Radeon X800GTO PL16, Diamond monster sound MX300
Reply 21 of 25, by Archer57
No conspiracy theories here - Xenos is one of the prime examples of bumpgate related failures and it was an ATI chip, based on something from x1000 series IIRC. This is pretty much the only fact i am aware of - everything else would be speculation. What was defective and what was not is unknown, the same as it is unknown for nvidia - lists from well known lawsuit(s) are most definitely incomplete.
Dried thermal compound would have played a role once the stuff was old enough (several years at least), but also it usually is not as critical as people may think. I've seen a lot of different hardware with 20+ years old thermal compound and my opinion is - all the horror stories about it are no more than myths. Thermal transfer is hindered, but more often than not - inconsequentially so. You'd see something like a 5C difference, or with temperature controlled fans - slightly higher fan RPM and that's it.
Not to mention that what people often perceive as "dried thermal compound" can simply be very high viscosity thermal compound from the factory...
I am yet to see an example which would change my mind about it...
Reply 22 of 25, by shevalier
I would agree with you completely if we were talking about Tualatin.
No energy-saving technologies, the temperature is always 45 degrees regardless of the load and 30 watts of consumption.
But GT(x? I don't remember all these NVIDIA prefixes)560, which I personally had to delidded a year after the warranty expired, completely disagree with you.
Reply 23 of 25, by AlexZ
All my 9800 GT cards have broken fan regulation. Not only they run fan at like 35-40% regardless of temperature, fan control is inverted. If you set it to 20% the fan runs faster. Re-pasting has lead to 4-5'C temperature reduction. I didn't delid any of them. Some had thermal compound that was completely solid, more like burned to the die, others had thermal compound similar to MX-2, very hard to remove. Keep them at about 60'C while gaming and they should last.
Back then people didn't use mesh cases and case airflow was very poor.
Pentium III 900E, ECS P6BXT-A+, 384MB RAM, GeForce FX 5600 128MB, Voodoo 2 12MB, Yamaha SM718 ISA
Athlon 64 3400+, Gigabyte GA-K8NE, 2GB RAM, GeForce GTX 275 896MB, Sound Blaster Audigy 2 ZS
Phenom II X6 1100, Asus 990FX, 32GB RAM, GeForce GTX 980 Ti
Reply 24 of 25, by Archer57
shevalier wrote on Today, 07:26:
Well, it is completely possible and likely that i simply have not seen cases severe enough. And then it can lead to more subtle issues like local overheating in areas which are no longer making good contact...
But i've seen so many people break their stuff trying to fix something that was not broken in the first place that i am kind of allergic to whole idea of thermal compound related "maintenance".
At least with modern hardware there is no need to guess anymore or replace thermal compound "just in case", ability to monitor temperatures including hotspot makes decision when to delid or just repaste very easy to make.
AlexZ wrote on Today, 08:24:
Yep, this has been pretty much my experience as well. Pull apart a card with 20 year old completely solidified thermal compound, replace it, get ~5C improvement.
Also somehow i hate modern "mesh cases" and cases built out of fans. Over9000 fans blowing in random directions through overplayed mesh+dust filter do not result in good airflow. This becomes very evident looking at how industrial systems, or even just gaming consoles are designed.
It is possible to get great airflow with cooling better than on open stand with just 1-2 correctly positioned fans in a case which is properly designed and is not made out of mesh. It is impossible with mesh though, so mesh is actively harmful in many situations.
Reply 25 of 25, by The Serpent Rider
All my 9800 GT cards have broken fan regulation. Re-pasting has lead to 4-5'C temperature reduction. I didn't delid any of them
That's nonsense. G92 cards had no lid.
