Reply 20 of 21, by iiamsiincere
Trypticon wrote on 2025-09-14, 23:01:Those old games were designed for 240p . ( PAL and all the special arcade cases aside). It definitely makes a difference to 480 […]
Those old games were designed for 240p . ( PAL and all the special arcade cases aside). It definitely makes a difference to 480i.
Resolution also matters on CRTs, but it's true you have a certain flexibility.
If you want to stick to your TV-out, you don't need CRT Emu Driver. and it's probably not very beneficial.
Strictly speaking ,you also don't need it for 240p and VGA (RGBHV) conversion to component either, since you can also also use tools like Powerstrip or WinModelines on XP to setup resolutions with appropriate refresh rates.
If you want to play a lot of different stuff as accurately as possible, Emudriver can help you with that.
You could also just setup a 2560x240 resolution/60 Hz and call it a day I suppose.
Thanks, that's good to know. I have gotten responses regarding this on other forums and I get the usual "This old tech, why aren't you using newer tech" (ironically asked on a forum dedicated to tech) or "This won't work, why are you wasting your time?" and I feel like if someone could figure out how to mod these S-Video/TV Out GPUs so that they can output everything needed for GroovyMame or maybe for a HTPC, this would be a worthy shortcut. I'm old enough and aware enough to have seen so many things done that at first didn't make any sense (like when RPi3 had a hat for CRT before anyone really knew about MiSTer or something like MiSTer Cast which has super limited use case), so I'm not sure why this has been such a trigger subject for people on these forums.
I wish I could find some more definitive documentation from ATI or nVidia when it comes how this specific technology worked and maybe a more in depth answer as to why 240p was such a difficult feat to achieve on these GPUs.
I may want to look at how Powerstip or WinModelines works to see if maybe I can mess around and get 240p working? Who knows, I might luck out.
