WinXP Arcade Build
First post, by iiamsiincere
Hello
I recently setup a WinXP (32-bit) build that outputs to CRT. Everything seems to be going well in regards to the build install, the updates/installations needed, benchmarking without crashing, testing out PC games and Mame with an Xbox 360 controller. I'm not ready to do the last bit of configuring before I go into enjoying it.
Can I get help from anyone on the following?
  • I'm looking for a suitable FrontEnd that I can use. I saw RetroArch as an option but I've never used it in that way before when using it on Win10. I have also emailed the support team at Launchbox to see if maybe they can provide me a version compatible with WinXP. In case that doesn't happen, does anyone suggest a reliable FrontEnd? I only need it display the games I have, it be nice if it can launch Mame roms, PC Games as well as DOSBox games (although if I can't, I can either stick to using a keyboard and mouse with this build or taking one of the game types off the list). Lastly, I have no problem using a Win10 machine to scrape all of the metadata if it'll be too much of a headache on WinXP.
  • I got interested in USB Polling a few years back but I wanted to know if it's something worth looking into and how to properly set this up on Windows XP. My understanding of USB Polling is that it somehow finds a way to reduce lag for things like a USB controller but correct me if I'm wrong.
  • If need be, is there a specific version of ATI Catalyst that I shouldn't be using, to avoid crashing of applications/games? I have installed the most recent versions of .Net Framework and C++ for 32-bit but I have read here and there that using versions from that time breaks things a lot less but again, correct me if I'm wrong. Are there any go to Windows XP applications that I should install for much smoother computability with either applications like RetroArch/Mame, ATI display drivers or most XP era PC games?
Reply 1 of 22, by iiamsiincere
Update:
"I'm NOW ready to do the last bit of configuring before I go into enjoying it."
Reply 2 of 22, by Linoleum
The most popular emulator front end is EmulationStation Desktop Edition (aka ES-DE)... The devs are very responsive on Reddit (they answered some questions I had in the past). It will require RetroArch in the backend for actual emulators though.
*** Edit ***
I used Maximus Arcade in the past on Windows XP. It works, but there is A LOT of manual setup involved:
https://maximus-arcade.com/
P3 866, V3, SB Audigy2
P2 400, TNT, V2, SB Audigy2 ZS
P233 MMX, Mystique220, V1, AWE64
P166, S3 Virge DX, SB32, PicoGus
486DX2 66, CL-GD5424, SB32, SC55
Prolinea 4/50, ET4000, SB16
SC386SX 25, TVGA8900D, Audician32
286 10, ATI VGA Basic, Forte16
Reply 3 of 22, by orcish75
iiamsiincere wrote on 2025-09-08, 15:48:
Hello
When you say CRT, is it a VGA CRT (31kHz+) or a 15kHz CRT?
Reply 4 of 22, by jh80
I used the Attract-Mode frontend on WinXP before and liked it ( https://attractmode.org/ ). It's open source and highly configurable, but does require spending time learning it and setting it up.
Looking at their github page, it seems like the last release for WinXP was 2.6.1:
https://github.com/mickelson/attract/releases/tag/v2.6.1
Regarding polling rate, I believe the XBOX 360 controller has a hardlocked rate of 125 Hz, which is quite common for many controllers. Might be on the low end for some people in some games, but I'd only worry about it if it bothers you. In that case, your best bet is probably getting a controller with a higher polling rate, as I don't think you can change it (but perhaps there's a way to...?).
I think you're far more likely to experience software-based input lag when running older emulators on WinXP, and that input lag might be 100+ ms and very noticeable. Don't confuse that with the USB polling rate, as they are distinct problems. Never versions of RetroArch have some clever ways of reducing that input lag (mainly run-ahead). I'm not sure how compatible that would be with the WinXP version of RetroArch, and it's also very CPU-intensive, so that might be out of the question.
Reply 5 of 22, by theelf
Hi! For me, the best frontend is MALA. It's not hard to make themes for it, and it runs on GDI so it doesn’t mess with any emulator
Long time ago, i made a MALA layout and look great a 240p
The attachment 000.jpg is no longer available
The attachment 001.jpg is no longer available
The attachment 002.jpg is no longer available
this is a example of what you can do
About the USB polling rate, here’s a way to tweak it — just keep in mind that if you set it too high, it can use quite a bit of CPU. If you have a Pentium 3 or older, it’s better to leave it at the default setting
http://www.overclock.net/faqs/73418-how-impro … y-changing.html
Reply 6 of 22, by konc
Hyperspin also works on XP
Reply 7 of 22, by iiamsiincere
orcish75 wrote on 2025-09-10, 15:59:
Hello
Sony Trinitron Consumer TV (short answer, 15kHz). The 4870 (for some reason) doesn't output Component correctly (It seems to be more designed for HDTV or HD CRT TVs), so I'm using S-Video out (It isn't bad, which I'm ok with).
I also have an nVidia GTX 275 that DOES output Component in full color but it's easier at the moment for me to deal with ATI for this setup.
Reply 8 of 22, by iiamsiincere
theelf wrote on 2025-09-11, 08:06:
Hi! For me, the best frontend is MALA. It's not hard to make themes for it, and it runs on GDI so it doesn’t mess with any emula […]
I'll have to think about MALA as I tend to spend too much time configuring things and would like to, for once, spend more time playing then configuring (I rebuilt this machine at least 10 times trying to figure out if whether WinXP, Windows Media Center 2005, Vista or 7 would accomplish everything I needed).
Thanks for the info regarding USB Polling, I'll have to read through it.
Reply 9 of 22, by theelf
iiamsiincere wrote on 2025-09-11, 14:27:
Hello
svideo 480i ? this is terrible....
Reply 10 of 22, by iiamsiincere
theelf wrote on 2025-09-11, 16:18:
On paper it is, but not in real life. IF you use MiSTer on a CRT TV, it's really not that far in quality. The desktop itself isn't great quality but when playing games, it's actually pretty good. I was playing 3rd Strike the other day and it's almost identical to playing it on Dreamcast (s-Video) or PS2 (Component) if not better. My expectations isn't 4K quality, so it does it's intended job.
Reply 11 of 22, by theelf
iiamsiincere wrote on 2025-09-11, 17:08:
Hold the L button and start when the Capcom logo pops up on DC
Reply 12 of 22, by orcish75
Excellent! That's the answer I was hoping for! GroovyMAME http://forum.arcadecontrols.com/index.php/board,52.0.html is your ticket, it was built specifically to run on 15kHz CRTs and to minimise lag. It's the closest you can get to real arcade machines through emulation using Groovymame and an ATi card with CRTEmu driver. Mister is better, but I can't tell the difference with the vast majority of games on my Groovymame setup and real arcade boards. I think 0.224 was the last version that works on XP. Also I haven't tried Groovymame with S-video (I'll do some research) , I've always used the RGB out on the ATi card into an RGB modded Trinitron. RGB modding your Trinitron will give you the best results, but if your Trinitron has component inputs, you can get an RGB to component converter.
I second @jh80 suggestion of Attractmode, pretty easy to setup and get going, but there are others worth trying.
You can also get GroovyArcade http://forum.arcadecontrols.com/index.php/top … c,160023.0.html An ArchLinux based live CD (with option to install on a hard drive) which makes it really easy to setup and configure a workig 15kHz system. Fine tuning may be a bit more difficult if you're not familiar with Linux.
Reply 13 of 22, by iiamsiincere
orcish75 wrote on 2025-09-13, 18:22:
Excellent! That's the answer I was hoping for! GroovyMAME http://forum.arcadecontrols.com/index.php/board,52.0.html is your tic […]
1. When I used normal Mame (pre-0.217) on Windows XP outputting S-Video, the timing seems to be pretty on point (I don't have a way to measure it) and I tested this with 3rd Strike (I've played the arcade version, xbox, xbox360, ps2 and dreamcast version for years). I used an Xbox 360 controller but I do have an arcade stick that I modded with Brook-Zero Pi if that's a better testing tool.
2. I've tried using GroovyMame but honestly, I need a better set of instructions as somewhere I tend to hit some roadblock. Either it's related how the instructions say you should set up the files or Windows XP issues that I'm not experienced enough to resolve, so I haven't gotten this properly setup yet on my setup.
3. Funny enough, I setup GroovyArcade last night without knowing you would leave this comment. It got setup with zero issues but some of the instructions skip so many random steps that are pretty important (I looked through several guides for what the SSH credentials were and I still don't know where you're supposed to place BIOS files as if I leave it in the roms folder, the games just don't start for me). Right now, I'm stuck where If I try to play a game, the screen just remains black and I can press ESC to get back to the main menu.
4. I have to find a good guide for Attractmode setup on Windows XP.
5. With a GPU that has TVOut/S-Video output, you can connect it directly to a consumer TV as long as it's S-Video/Component, but if you want to use VGA or Analog DVI, you need something between the GPU and TV (like a transcoder). I have basically trying to cut out the middle man to get as close to a console experience as possible.
Do you or anyone here know where I might be able to get drivers for thw WMC remotes, Logitech Harmony remotes or the Logitech RF extender?
I'm trying to also add this to setup to try and remove the need for a keyboard/mouse and make it living room capable.
Reply 14 of 22, by orcish75
Yeah, it is a mission to set it up initially. CRTEmu driver has to be set up before Groovymame will work. I'll give it bash tonight on XP and an X1300 ATi card that has S-Video out. I have a feeling that it doesn't work over S-Video, only RGB.
I've found an RGB to component converter on Aliexpress. I have no experience with it so can't comment on it's image quality.
https://www.aliexpress.com/item/1005007879913 … _origin_prod%3A
This Reddit post seems to suggest that it's reasonably good.
https://www.reddit.com/r/crtgaming/comments/z … s_to_component/
Reply 15 of 22, by theelf
CRTEmu driver is only over RGB, for svideo, only a active converter RGB>SVIDEO
The svideo output in cards are only interlaced and resolution fixed
Reply 16 of 22, by iiamsiincere
orcish75 wrote on 2025-09-14, 06:54:
Yeah, it is a mission to set it up initially. CRTEmu driver has to be set up before Groovymame will work. I'll give it bash ton […]
Yea, as far as I can tell I'm unsure of the importance of Emudriver when you have a card that is S-Video out of the box. As long as it can display at 60hz, I believe it should be able to switch refresh rates on the fly since S-Video is an analog signal and CRT TV's are capable of doing that by design. I don't require more than 480i, especially since analog console games/pre-PC based arcade games weren't designed to be concerned about pixels but more about lines. I could be wrong but if you're emulating a game like Art of Fighting 2, the original game wasn't designed for 480p, 720p or 1080p. It was designed for NTSC, then maybe tweaked to handle PAL regions since they have a different refresh rate. I'm sure I did a lot of paraphrasing.
Reply 17 of 22, by iiamsiincere
theelf wrote on 2025-09-14, 18:06:
Yea, I found that out the hard way. Windows Vista/7 does away with 60hz 480i in favor of 30hz or 29hz, even with the same driver version, which is super annoying. I was hoping someone online created a software that could potentially change that and enable the full analog capability, regardless of the version of Windows you run. I can guess that it would work on something like Ubuntu since GroovyArcade is Arch Linux based but I'm not fully comfortable enough to image linux, setup groovymame on there and play it within a day or two of configuring (I already know it'll take me several days and it might not end up being worth the headache).
Reply 18 of 22, by Trypticon
Those old games were designed for 240p . ( PAL and all the special arcade cases aside). It definitely makes a difference to 480i.
Resolution also matters on CRTs, but it's true you have a certain flexibility.
If you want to stick to your TV-out, you don't need CRT Emu Driver. and it's probably not very beneficial.
Strictly speaking ,you also don't need it for 240p and VGA (RGBHV) conversion to component either, since you can also also use tools like Powerstrip or WinModelines on XP to setup resolutions with appropriate refresh rates.
If you want to play a lot of different stuff as accurately as possible, Emudriver can help you with that.
You could also just setup a 2560x240 resolution/60 Hz and call it a day I suppose.
Reply 19 of 22, by orcish75
I tried last night to see if CRTEmudriver would work with the S-Video port, @theelf is 100% correct, it's always fixed at 480i no matter the resolution you choose, it only works on the RGB output. I'd still say it's worth getting the RGB to Component transcoder linked above and setting up CRTEmudriver and GroovyMAME. I have my arcade cabinet setup with a gutted 21" Sony Trinitron TV tube and chassis that's been RGB modded and driving it with an ATi HD6470 (Dell OEM). I used Atom-15 to mod the BIOS on it for 15kHz and composite sync. https://github.com/antonioginer/ATOM-15
The combination of CRTEmudriver and GroovyMAME will always pick the correct resolution (240p, 256p 480i etc) and refresh rate for the game, even games with non-standard refresh rates such as the IREM games (55HZ), Double Dragon (57Hz) and a few others. It does take some effort to set it all up properly, but once it's done, the results are as close as you can get with emulation. I can't tell the difference from the original boards for the vast majority of games. There is an average total lag of about 3-6 frames for most games and I'm unable to feel it. Sure, pro gamers will probably be able to feel it, but they'll probably be using original boards anyway.
Here are a few photos of games running on my cabinet. I use it for arcade games, Sega Megadrive, SNES and the PC Engine. (Sorry for the crappy quality pics, it's the best my phone camera could do on a CRT)
Golden Axe, GroovyMAME showing the selected resolution and refresh rate for the game
R-TYPE 2 showing the 55Hz refresh rate and 256p resolution
Sega Megadrive
SNES
Willow CPS-1
Caveman Ninja
Still a WIP, just replaced the original arcade CRT and chassis with the 21" Trinitron tube as the original CRT had screen burn on it and the chassis wasn't great.
The RGB mod input
