This is a serious question, not trying to be negative... but, what is the purpose of the delidding that is going on in this thread? Especially with newer CPUs, Ryzen, etc. there is almost nothing gained even by lowering temperatures. These chips are pushed near the absolute maximum from the factory and the binning processes have become so good that there is very little left for enthusiasts to do aside from undervolting with curves\PBO2 tuning.
Here is a good example:
https://www.youtube.com/watch?v=y_jaS_FZcjI
Der8auer delidded a 7900X and used liquid metal for direct die cooling and managed a 3% performance improvement in Cinebench with all cores pegged at 5.5Ghz (a minor increase over stock cooling) despite lowering temps 18-20C at peak load. The crazy thing is that the 7000 series is known for deliberately pushing chips to high temperature limits to achieve the highest clock speeds, so if any modern architecture should benefit from cooling mods like this, you'd think this one would. Of course, you can manually jack up the voltages more now that there is more thermal head room. How long these chips will last in those circumstances, however, I don't know.
I can use negative core offsets on my 5800X3D to bring temps and power consumption down while having a slight gain in performance and I can run all of the fans in my PC so that they are inaudible at idle and barely audible during a heavy gaming load. No hardware modifications were needed to achieve this. Just good air cooling and somewhat decent thermal paste.
If the goal is to try to preserve these chips by keeping them at lower temperatures, I guess that's an admirable goal, I just don't know if there will be real world benefits. Personally, I'd trust an untouched CPU to still work properly 20-30 years from now versus one that was delidded part way through its lifespan.
EDIT: It's hard to convey the tone of this post, but it is not combative or trying to tell you not to delid CPUs. I am just genuinely curious what the goal is.
