3com 3c515 performance worse than 3c509b?
Reply 20 of 43, by Marco
Wow very good to know.
1) VLSI SCAMP 311 | 386SX25@TI486SXLC2-50@63 | 16MB | CL-GD5434 | CT2830| SCC-1 | MT32 | WDC160GB/7200/8MB | Fast-SCSI AHA 1542CF + BlueSCSI v2/15k U320
2) SIS486 | 486DX/2 66(@80) | 32MB | TGUI9440 | LAPC-I
Reply 21 of 43, by DaveDDS
Marco wrote on 2025-10-27, 18:08:
Thanks for the hint. There are unfortunately no packet drivers available for the 515 😒
Bummer... I've run into very few cards where there isn't a packet driver (or one for a compatible card).
To be completely honest however, although I had dozens of NICs back in the day (and still have a few, even a couple
ISA ones) which I use on the 4-5 DOS systems I still have, I don't tend to try and run DOS on my newer systems, and
haven't needed to go looking for newer packet drivers. In the very rare cases where I've booted DOS on something
newish for testing - I can usually just stuff in a PCI card if I need networking.
I'm sure most newer hardware doesn't have need for packet drivers as DOS has been almost eliminated
from "modern" consideration factors in picking an OS.
https://dunfield.themindfactory.com ; "Daves Old Computers" ; SW dev addict best known:
ImageDisk: rd/wr ANY floppy PChw can ; Micro-C: compiler for DOS+ManySmallCPU ; DDLINK: simple/small filecopy(w/o netSW)via Lan/Lpt/Com
Reply 22 of 43, by Marco
So Tests conducted:
SMB Large file Transfer (15MB):
DOS: 428kb/s
WIN311: 788kb/s
WIN95: 750kb/s
FTP Large File Transfer (from Slackware)
WIN31: 837kbps
WIN95: 1120kbps
Not to NUL but fast HDD. Couldnt get wsftp to download to NUL
Further remarks:
- switch port config is in line with NIC config 100MB HD
So at the end I couldn’t get closer to a possible root cause.
I might test another router. But from the current I do easily get 6MB and more for SMB download speed from a modern PC.
My ISA Bus achieves up to 4400kb/s for linear HDD reads so even without busmastering these results are disappointing and more or less identical or slower then the ones of a 3c509.
Next steps:
1. Use another router (for another ftp test)
2. Test the card in my 486dx2 80 as proposed.
Anyway maybe these results do already give someone some more hints?!
Thank you
Reply 23 of 43, by Grzyb
Marco wrote on 2025-10-27, 21:59:
Not the NUL but fast HDD. Couldnt get wsftp to download to NUL
You mean you're using the WS_FTP client?
My preferred setup is:
  • FTP server on a modern PC
  • FTP client on the machine being benchmarked
    • DOS - FTP.EXE from mTCP, with "MTU 1500"
    • Windows 3.x - FTP.EXE from TCP/IP-32, even when using some other TCP/IP stack
    • Windows 9x/NT - FTP.EXE shipped with the system
All three clients can download to NUL.
They look OK for a CPU with 16-bit bus.
In 2003, I voted in favour of joining the European Union. However, due to later developments - especially the restrictions on cash usage - I have withdrawn my support. DOWN WITH THE EU!
Reply 24 of 43, by Marco
Will try now with local FTP on the router itself.
Results:
- Download performance from Modern PC (wifi, to HDD):
--- FTP: 3,35 MB/s
--- SMB: 3,45 MB/s
- Download performance from Testsystem TI486SXLC2 (LAN):
--- WIN95 - FTP.EXE: 467kb/s
--- WIN95 - WSFTP: 520kb/s
--- WIN311 - FTP.EXE: 760kb/s
--- WIN311 - WSFTP: 551kb/s
So all benches now conducted with the testsystem.
Very disappointing.
Reply 25 of 43, by Grzyb
Again - my conclusion was that 100 Mbps NIC doesn't make sense in a 386, and I was testing 386DX, with 32-bit bus!
Re: Expected network throughput on ISA network cards
Reply 26 of 43, by Marco
Seems like I simply have to accept that fact as well 😀
I was at least hoping for CPU usage reduction by DMA Busmaster. But as always mentioned here in the forum: seems to be black magic and no one really knows if it's working / used.
Again - thanks to everyone
Reply 27 of 43, by Disruptor
It remembers me on my tests with an EISA 3Com 3C597 (100 MBit/s) in a 486DX50 with an Adaptec 2740W EISA SCSI controller:
EISA: Win95C --> Windows 10: 14.5 MBit/s (from cache)
EISA: WinNT 4.0 --> Windows 10: 25 MBit/s (from cache), 22 MBit/s (from disk)
Re: Why are 3Com NICs regarded in such high regard?
Reply 28 of 43, by Marco
Great results.
I could extend my testings:
1. make NDIS message „Dma busmaster disabled“ disappear by doing auto Dma tuning in config
- thanks for that hint upfront here which I really missed earlier
- results could be improved slightly but marginally
2. tested now on my system 2 (isa at 13,3MHz):
- DOS large file copy from SMB: 1152kb/s
- Win311 large file copy from SMB: 937kb/s
- Win311 large file copy FTP to NUL: 1520kb/s
There is indeed an increase but nothing close to even 50mbit. Again 100MB HD media type setting.
I get more and more the impression that a comment a read here somewhere was right: 515 is capable of allowing 100MB switch port configurations in large setups (auto config, homogen config, homogen switch systems, …) but cannot provide notably (!!) more bandwidth than the 509b.
Reply 29 of 43, by Grzyb
So, 3C515 performance is *NOT* worse than 3C509B... MYTH BUSTED!
But the window where it's actually better is pretty narrow...
- doesn't make sense in a 386, even on steroids
- doesn't make sense in anything with EISA or PCI
- OK for ISA-only and VLB machines with fast CPU, primarily 486, possibly also NexGen and other oddballs
Anyway, don't expect miracles - though I suspect the results would be somewhat better with protocols lighter than TCP/IP - IPX? NetBEUI? EtherDFS?
I hope to do some benchmarking on my 486DX2 later this week, but only with TCP/IP - nowadays, setting up a server with other protocols is too much work...
Reply 30 of 43, by Marco
Yes I agree.
Some remarks:
1. the myth is not (fully) busted when we talk about operations in „low end“ systems. Maybe at a certain time I will re do tests with the 509b.
2. Etherdfs didn’t show improvements in my previous tests on the 509b. The 515 lacks packet driver Herefore
Anyway thanks to all of your help.
Reply 31 of 43, by Grzyb
So I've got the following machine:
The attachment system.png is no longer available
FTP server is a modern PC.
FTP client downloading in BINARY mode to NUL.
mTCP set to MTU 1500.
WfW 3.11 using TCP/IP-32.
All results in KBytes/s.
First, the 10 Mbps card, with these settings:
The attachment 3c509b.png is no longer available
Always using the drivers from this package:
83-1024-001
EtherDisk for the Etherlink 10 ISA NICs (3C509B Family)
Version 6.1
Copyright 1999 3Com Corporation. All rights reserved.
mTCP, native PD: 786
mTCP, NDIS+DIS_PKT: 995
mTCP, ODI+ODIPKT: 919
WfW: 760
Now, setting "Network Driver Optimization: DOS Client", which is supposed to improve network throughput at the cost of higher CPU utilization...
mTCP, NDIS+DIS_PKT: 994
mTCP, ODI+ODIPKT: 921
WfW: 769
Reply 32 of 43, by Grzyb
Next, the 100 Mbps card, with these settings:
The attachment 3c515.png is no longer available
Did the "tune the DMA parameters" procedure.
83-0809-001
3Com Fast EtherLink ISA Parallel Tasking 10/100 Base-TX
Version 2.0
Copyright 1997 3Com Corporation. All rights reserved.
mTCP, NDIS+DIS_PKT: 860
mTCP, ODI+ODIPKT: 1236 (driver displays 100 FD)
WfW: 1185
Setting "Network Driver Optimization: Maximized Network Performance"...
mTCP, NDIS+DIS_PKT: 1371
mTCP, ODI+ODIPKT: 1233 (driver displays 100 FD)
WfW: 826
Back to original settings, and forcing 100 HD (can't set 100 FD in 3C515CFG)...
mTCP, ODI+ODIPKT: 1233 (driver displays 100 HD)
WfW: 1188
Still forced 100 HD, and disabling bus mastering...
mTCP, NDIS+DIS_PKT: 988 (driver displays "Bus mastering disabled by Keyword.")
mTCP, ODI+ODIPKT: 927 (driver displays 100 HD)
Conclusion:
  • NWay auto negotiation in this card sucks, and wrong speed/duplex mismatch can indeed make it worse than a 10 Mbps card - it's better to force it manually
  • disabling bus mastering also hurts a lot
  • even in perfect setup, the Corkscrew is not a 100 Mbps card - more like a 15 Mbps card 🤣
Reply 33 of 43, by Marco
1. Fully agree to your conclusions 😀
2. Hereby my results:
3. Conclusions:
- 515 is indeed faster. Myth busted yes
- some strange numbers in red I dont understand
- Even though an addon the TCP IP Layer on Win311 seems to be most performant overall. The fast HTTP download might be related to file-still-in-IE-cache
- Differences in DOS SMB differ largely between Ti486 and 486DX280.
- Win95 suffers largely in lot-small-files transfers. But this seems to be mainly due to high cpu usage for graphical copy jobs (windows commander). running same tests under NC5 where much faster (170kb/s on 3c09).
Thanks again for the nice testings. I will in short try to re-do exactly your tests.
Can you therefor shortly tell me what is meant by:
..., native PD
..., NDIS+DIS_PKT
..., ODI+ODIPKT
I am just aware of using mTCP with packetdriver provided by 3com v6.1 - nothing elso to choose here. Thanks upfront
Reply 34 of 43, by Grzyb
Marco wrote on 2025-10-31, 10:16:
Can you therefor shortly tell me what is meant by: ..., native PD ..., NDIS+DIS_PKT ..., ODI+ODIPKT […]
..., native PD
..., NDIS+DIS_PKT
..., ODI+ODIPKT
mTCP - and many other TCP/IP packages for DOS - need a Packet Driver.
In case of lack - or poor quality - of a PD, it can be substituted by NDIS or ODI driver with appropriate converter/shim.
I'm attaching the PD replacements configured for 3C515...
Reply 35 of 43, by Marco
Thanks a lot. Will test.
Wait: I just realize that there ARE packet drivers then for the 515???
Reply 36 of 43, by Grzyb
Marco wrote on 2025-10-31, 14:32:
Not quite - but there are drop-in replacements.
So yes, it's possible to use PD applications with that card.
There may be some limitations - but I only know about the incompatiblity between mTCP NetDrive and ODI+ODIPKT.
Reply 37 of 43, by mbbrutman
Grzyb wrote on 2025-10-31, 16:10:
Not quite - but there are drop-in replacements. So yes, it's possible to use PD applications with that card. There may be some l […]
As far as I know there is no incompatibility like this. Are you saying that mTCP Net drive doesn't work with any combination of ODI driver and ODIPKT? Is there a bug report that I missed?
Reply 38 of 43, by Grzyb
mbbrutman wrote on 2025-10-31, 16:52:
I mean this - Re: mTCP NetDrive: network attached storage for DOS 2.0 or better
I've tried it many times, with various NICs, and the result was always the same - NetDrive works with NDIS+DIS_PKT, but doesn't work with ODI+ODIPKT.
Reply 39 of 43, by Marco
Just noted that the non-busmaster setting results are similar to the ones of the 509b. So you could (!) assume that speed advantage mainly derive from the busmaster capability. Just a theory 😀
