So. I used the weekend to test some details on the driver side:
- vogons: vxd drivers from 96
- 3c515N.exe: sys drivers from 04/97
- 3c515X.exe: sys drivers from 09/97
—- oemsetup.inf identical. File size of drivers differs. Version of driver file is both time 1.06.
- win98: does seem to use the same drivers from 4/97. same filesize etc
So far no performance differences noticed.
While testing the NDIS2 drivers under MSclient I noticed following sentence during loading: „Bus mastering disabled by EEProm on Adapter.“
First: interesting information.
Second: any idea what could be the reason for this? In the 3c515cfg you cannot configure anything like that. All tests do pass fine.
Any ideas here?
I hope it’s not the case that my board doesn’t support bus master Dma. But it would be new to me that this is mainboard dependent. According to the manual busmaster requests / commands are being accepted and handled. Or it requires a PnP board or sth. Anyway, dont want to put anyone here on a wrong track with these thoughts.
Thank you
Update: just found this release note:
IBM 486 SLC and IBM 386 SLC PCsThe 3C515-TX NIC does not run in bus master mode onthese PCs. To disable bus mastering on your PC, referto readme.txt
My cpu is similar although not exactly the same. I would assume things could be related to this fact. I will therefore test the BARB settings for this cpu as recommended by user feipoa.
1) VLSI SCAMP 311 | 386SX25@TI486SXLC2-50@63 | 16MB | CL-GD5434 | CT2830| SCC-1 | MT32 | WDC160GB/7200/8MB | Fast-SCSI AHA 1542CF + BlueSCSI v2/15k U320
2) SIS486 | 486DX/2 66(@80) | 32MB | TGUI9440 | LAPC-I
