Unknown 386 motherboard doesn't give display
Reply 20 of 23, by Gavrilo
Negative, everything seems to be alright. Probably picture fault.
zami555 wrote on Yesterday, 13:13:
I have the impression that the pins in SIS chip, the one close to RAM, are bent. Please check carefully whether there is no short circuit between some of these, or that some pin has lost contact with pcb.
The attachment IMG_20251104_140623.jpg is no longer available
Reply 21 of 23, by Gavrilo
Will check that next days and let you know.
butjer1010 wrote on Yesterday, 08:05:
I also didn't saw this other oscillator 🙁
So, if You turn it on without SIMs, and with speaker connected, there is no sound at all?
Reply 22 of 23, by Gavrilo
So let's say the mobo works. What would happen if there were ordinary modules?
99% likely needs the 9-chip SIMMS. I think the keyboard controller is fine... The hex inverter is sometimes different (7404/7405/7406/7407), but the one you have looks like it's for the AMI controller, which is what you already have.
[/quote]
Reply 23 of 23, by PC@LIVE
It could actually be a RAM problem, on the 386DX-40 I have four RAM 30 PINs of 1 MB each, and they are all with 9 chips.
AMD 286-16 287-10 4MB HD 45MB VGA 256KB
AMD 386DX-40 Intel 387 8MB HD 81MB VGA 256KB
Cyrix 486DLC-40 IIT387-40 8MB VGA 512KB
AMD 5X86-133 16MB VGA VLB CL5428 2MB and many others
AMD K62+ 550 SOYO 5EMA+ and many others
AST Pentium Pro 200 MHz L2 256KB
