First post, by Gavrilo
Hello fellas,
adding another today's topic from me.
I got some stuff last week and among things was this nice but unknown 386 motherboard. The mobo didn't have keyboard bios and processor so I put there my Intel 386DX 25MHz which I saved from JoindataSystems G386SYM (which I am desperately still looking for 😀) and keyboard bios from another 286 mobo. Battery wasn't present, but there was some corrosion around, nothing serious, but I cleaned it with Kontox, old cleaner for electric circuits. I connected vga card, keyboard and power supply. But after turning it on it gives no video on monitor and no beeping. I checked routes from DIN5 keyboard connector to keyboard bios, seems to be alright. Do you have any suggestions? Or the board is dead?
Here I have found the closest match, but it's not it:
https://arvutimuuseum.ee/th99/m/E-H/30264.htm
Thanks.
Reply 1 of 56, by butjer1010
Hi, as i see on picture, oscillator is 66MHz, and CPU is 25? Mabybe this CPU can't go 33MHz?
Reply 2 of 56, by nuno14272
I would say the same.. The board is for 33mhz cpus.
1) change the cpu to 33mhz
2) use only two sticks of ram on bank0. no need to 4 for now, and you can test the ram sticks
3) do you have a POST card to see if the board gives some codes, or dont initialize ? its a very big difference.
1| 386DX40
2| P200mmx, Voodoo 1
3| PIII-450, Voodoo 3 3000
Reply 3 of 56, by PC@LIVE
Since it is a 386DX, it is correct to use 4 SIMM 30 PIN, 2 instead are fine on the 386SX.
The CPU could probably work at 33 MHz, but it's better to try a 386DX-33 instead of that 386DX-25.
AMD 286-16 287-10 4MB HD 45MB VGA 256KB
AMD 386DX-40 Intel 387 8MB HD 81MB VGA 256KB
Cyrix 486DLC-40 IIT387-40 8MB VGA 512KB
AMD 5X86-133 16MB VGA VLB CL5428 2MB and many others
AMD K62+ 550 SOYO 5EMA+ and many others
AST Pentium Pro 200 MHz L2 256KB
Reply 4 of 56, by Gavrilo
Thanks guys for suggestions. Unfortunately I do not have 33MHz processor, last one was sold on Aukro in one auction in 2023. I will take a look somewhere else. Nuno, I don't see anything on screen so I can't tell. Is it possible that I burned my 25MHz when the oscillator runs higher?
Reply 5 of 56, by Cyberdyne
No. It does not burn.
PS.Nice server/workstation board. Never seen a 386 with so many SIMM. Like whoa 16x4MB 64MB for a 386.
Reply 6 of 56, by Anonymous Coward
Nice Rabbit.
Based on the older style cache chips it uses, I'm going to say you probably have an older revision chipset that only supports 64kb cache and 16MB...no 4MB SIMM support.
Reply 7 of 56, by MikeSG
Possibly need 4x 9-chip RAM SIMMs to get it to post.
Some boards like this might also use a Fujitsu type keyboard controller which is slightly different.
Reply 8 of 56, by Gavrilo
Sorry, I read it wrong before. Unfortunately I don't have POST card, would be good to have one.
nuno14272 wrote on 2025-11-03, 09:38:
I would say the same.. The board is for 33mhz cpus. […]
Reply 9 of 56, by Gavrilo
Yes it is a nice piece, glad I got something unusual like this.
Cyberdyne wrote on 2025-11-03, 10:38:
Reply 10 of 56, by Gavrilo
So now I will need i386 33MHz processor, 4pcs of 9chip simm modules and Fujitsu controller...challenge accepted. Shame I did not wait for these suggestions although I wouldn't be able to now that someone will post here these info, because this morning I ordered keyboard bioses and one for my another 486 system. If I had waited bit longer I would have ordered those Fujitsu as well 😀. I really appreciate it.
MikeSG wrote on 2025-11-03, 15:20:
Reply 11 of 56, by PC@LIVE
I saw that you have in the photo, a 50.0 MHz OSC4, if that's what he uses for the CPU, that 386DX25 is fine.
But is the one in the photo your motherboard, or is it the same as yours?
Reply 12 of 56, by Gavrilo
Not exactly sure what do you mean, but this mobo has 66MHz oscillator as you can see above memory modules.
Reply 13 of 56, by PC@LIVE
Gavrilo wrote on 2025-11-03, 19:28:
Next to the 66 MHz one is the 50 MHz one, the visual aspect is different, but it is possible that this (50) is the one for the CPU frequency, I don't know what that 66 is for.
Reply 14 of 56, by Gavrilo
Oh I see, you're right, there is another one next to that 66MHz. So now I am confused. Maybe others will be able to shed some light on it? Because now it seems we have here two oscillators.
Reply 15 of 56, by butjer1010
I also didn't saw this other oscillator 🙁
So, if You turn it on without SIMs, and with speaker connected, there is no sound at all?
Reply 16 of 56, by nuno14272
I mena... every jumper is hardwired already.. so is dificult to understand whats fsb is running.
1| 386DX40
Reply 17 of 56, by zami555
I have the impression that the pins in SIS chip, the one close to RAM, are bent. Please check carefully whether there is no short circuit between some of these, or that some pin has lost contact with pcb.
The attachment IMG_20251104_140623.jpg is no longer available
Reply 18 of 56, by MikeSG
Gavrilo wrote on 2025-11-03, 18:15:
99% likely needs the 9-chip SIMMS. I think the keyboard controller is fine... The hex inverter is sometimes different (7404/7405/7406/7407), but the one you have looks like it's for the AMI controller, which is what you already have.
Reply 19 of 56, by butjer1010
zami555 wrote on 2025-11-04, 13:13:
Good eye You have 😉
