Reply 20 of 39, by amstradus
DaveDDS wrote on 2025-11-10, 19:59:
Good way to test seeking --- use ImageDisk […]
In the Align/Test function, you can seek to any track.
In the clean-heads function, it "scrubs" the heads by seeking back and forth.
Both easily visible.
Ah, thank you. I don't have a drive set up with a modern PC in order to run any diagnostics that way. Maybe there is something similar that I could put on my XT IDE disk...
Reply 21 of 39, by DaveDDS
amstradus wrote on 2025-11-10, 20:26:
ImageDIsk doesn't run on "modern" PCs - it has to run under DOS, because it access the floppy hardware directly, and can't tolerate the various protections
and real-time uncertainty of "modern" systems.
It will run on at XT ... by default it assumes you have an AT type floppy controller - but there's a switch to make it fall back to an XT compatible one.
That will reduce some capability ... but it should still work well for seek tests.
- Dave ; https://dunfield.themindfactory.com ; "Daves Old Computers" ; SW dev addict best known:
ImageDisk: rd/wr ANY floppy PChardware can ; Micro-C: compiler for DOS+ManySmallCPU ; DDLINK: simple/small FileTrans(w/o netSW)via Lan/Lpt/Serial
Reply 22 of 39, by mkarcher
amstradus wrote on 2025-11-10, 20:25:
If I try to run the install file I hear five short rather loud 'scrubbing' sounds, and then I get the error message.
https://youtube.com/shorts/UVSfhkCMgY0?feature=share
That sound seems to confirm that something's up when the drive tries to seek. On the other hand, if the drive were just seeking the wrong way, it wouldn't notice it when formatting a disk. How far does the formatting process progress before it aborts with an error?
Reply 23 of 39, by DaveDDS
mkarcher wrote on 2025-11-10, 20:36:
That sound seems to confirm that something's up when the drive tries to seek. On the other hand, if the drive were just seeking the wrong way, it wouldn't notice it when formatting a disk. ...
I wouldn't count on that - It does use a Track-0 sensor to tell when the head is home'd, and that doesn't exist at the inner track depth.
not knowing where the head is would also likely result in it banging against the limit stops frequently, even if for some reason it didn't fail
on Track-0 seek.
Reply 24 of 39, by amstradus
It just says Saving UNFORMAT information, scrubs 5 times then "Sector not found reading drive B" message:
https://youtube.com/shorts/GyJY6VjSgfg?feature=share
Reply 25 of 39, by amstradus
DaveDDS wrote on 2025-11-10, 20:33:
ImageDIsk doesn't run on "modern" PCs - it has to run under DOS, because it access the floppy hardware directly, and can't toler […]
Ah, woops. I found this listed on your site (first listed). Is this the correct program?
http://dunfield.classiccmp.org/img/
Reply 26 of 39, by mkarcher
amstradus wrote on 2025-11-10, 21:15:
Try "format /U" to avoid saving UNFORMAT information. This will not fix your issue, but possibly help identify the cause of the issue.
Are you sure that the drive works in a different system? You can get issues like this if the drive is mechanically jammed and unable to move the head properly. Although on the other hand, a jammed head movement is unlikely to be jammed exactly at track zero.
Reply 27 of 39, by amstradus
mkarcher wrote on 2025-11-10, 21:42:
with Format/U the disk was able to be formatted but unable to write BOOT:
Reply 28 of 39, by DaveDDS
amstradus wrote on 2025-11-10, 21:17:
Yes.
Do you have a way to get it onto your DOS system?
Network , serial port or another working floppy drive?
Reply 29 of 39, by amstradus
And no, I'm not sure the drive works. I bought it untested.
Reply 30 of 39, by amstradus
DaveDDS wrote on 2025-11-10, 22:03:
Yes. […]
Yes.
I have a flash drive on my XT IDE that I can transfer it to. Would I need to then transfer it to a floppy or can I run it from the XT IDE? I will try. The 5.25 A drive works but the only blank I have is a single sided DD which won't fit the folder.
Reply 31 of 39, by amstradus
Yes. […]
Yes.
Which file to run for the proper disk utility?
Reply 32 of 39, by amstradus
Yes. […]
Yes.
I managed to get into the utility I think. Running it now but the floppy has been running for 2 minutes now...
Reply 33 of 39, by amstradus
Yes. […]
Yes.
Welp! I've done my diligence for today. Cool utility. I reformatted the floppy with your utility and then finally figured out how to run TEST FDC on the floppy drive. Here are the results:
I suppose I could try the alignment/test utility again -- it's no longer giving my question marks, just a long scroll of numbers, and it runs 3 minutes+ and keeps going. Not sure how long that is supposed to take, maybe you could give me an idea, if you think it's worth doing.
Reply 34 of 39, by DaveDDS
Yes, you can run it from IDE...
Try "clean heads" - the goal was to find out it the drive seeks properly - CleanHeads will "scrub"the head back and forth, and you can easily see how it moves.
(If you have a 3.5" floppy - the top cover will probably come off so you can see the heads move)
Reply 35 of 39, by amstradus
DaveDDS wrote on 2025-11-11, 02:23:
I tried the cleaning function. The heads are moving but making a good amount of noise. I don't think there is enough lubrication on the 'guide' shaft, and maybe it is skipping over the metal. Just a guess:
https://youtube.com/shorts/RaRriZgU4-I?feature=share
Reply 36 of 39, by DaveDDS
Look about right and doesn't appear to be "sticking".
Some 5.25" drives are loud stepping, and ImageDisk in it's goal to support as many old drives as possible, doesn't have a super-fast step rate.
If you power-off, and move the drive heads to the inner end (prob have to manually move the stepper shaft. when you power-on, is it as loud?
This would get BIOS to step the length of the disk at it's "normal" rate.
Have you actually cleaned the heads? Your problem may be related to dirty heads (although I would expect track-0 to be equally affected in that case)
Your problem could also be alignment (but again, should affect all tracks).. Do you have other systems with similar drives?
Have you tried this drive an any other system? Have you tried other (known working) drives in this system?
(Sorry, these Q's may have been asked/answered here before ... just not keeping everything in memory as well as i used to these days)
Reply 37 of 39, by amstradus
DaveDDS wrote on 2025-11-11, 10:31:
Look about right and doesn't appear to be "sticking". […]
I moved the heads towards the inner end and powered up again and it seemed quieter than during cleaning, but now it's not reading at all for some reason.
I'm going to go ahead and pick up another drive tomorrow, a Panasonic JU-256A216P, and give that a go. This is the only system I have with drives.
Would you say that most 3.5" drives that work at 720k can be made to work in these older machines? Initially I had thought there were only certain models that would work, and a search gives mixed answers. Maybe you can give me a brief on what I might look for, in case this one doesn't work tomorrow. Thanks again
Reply 38 of 39, by mkarcher
amstradus wrote on 2025-11-11, 19:21:
Any 720KB drive should work, and any PC-compatible 1.44MB drive should work if pin 2 is shorted to ground. If pin 2 is open, it may or may not work. Drive B in that Amstrad machine is accessed like drive B in any other PC compatible computer. For drive A, you need to modify the drive to respond to DS0 instead of DS1, which requires soldering on many newer drives, if it is supported at all.
Good luck with the other drive you are getting!
Reply 39 of 39, by DaveDDS
Quieter is not really surprising ... like I said earlier, ImageDisk uses slower step rate - Stepping faster is often quieter.
Did it work more before you moved the heads?
Perhaps the heads really are not moving correctly - try moving it back to home and see if it works as well as before.
Sometimes it can help to lube the stepper motor and shaft. I use a light silicon grease with good results for things like that.
All 3.5" drives can do DD (720k) - this is at 250kbps data rate. HD drives (1.44m) can also do 500kbps data rate.
The "trick" is that there is a signal to the drive to adjust it's electronics to suit the data rate and a DD only system may not
have that connected - you can make a connection to force an HD drive to always be DD (I don't recall the pin but I think somone else suggested Pin2)
