First post, by amstradus
Hey all,
I'm wondering if anyone knows how to properly power a Gotek or a 3.5 floppy for use with my Amstrad 1512. I've read that you can switch pins 1 and 4 on the berg connector but I am afraid to try this... not something I really want to troubleshoot. I'm not finding particular information on the 1512, and not sure it's the same for all Amstrad models. I have an edge connector for the drive and a molex to berg adapter with 4 wires...
Reply 1 of 39, by konc
Where did you read that you need to switch pins on the 4-pin power connector, was it some AI by any chance? If so I'll explain why I'm asking.
As far as I know the molex and, consequently, the 4-pin power connector after using the adapter is standard. You can also easily verify it yourself by measuring voltages and comparing against a common PC PSU, there is no need to troubleshoot and risk anything. So I wouldn't worry about the power but:
-In most 1512s (if not all) the floppy cable is fixed to the motherboard and only has an edge connector, so you'll need an adapter edge > 34-pin floppy (or to replace the cable)
-The 3.5" drive needs to be configurable as DS0, later drives don't have these jumpers. I know nothing about the gotek though and how/if it can be done.
Reply 2 of 39, by amstradus
konc wrote on 2025-11-07, 07:46:
Where did you read that you need to switch pins on the 4-pin power connector, was it some AI by any chance? If so I'll explain w […]
Thanks for the reply. I actually read this on a blog post first, though it was with regards to a different model of Amstrad. I can't find it now. But yes, I did follow up with AI, and it confirmed the info that I read, that Amstrad pin 1 is +12V, and pin 4 is +5V, whereas the Gotek pin 1 is +5V, pin 4 is +12V. Maybe it is AI "confirmation bias".
I can't actually reconfigure my floppy drive without physical soldering, so I was thinking of using it as the B: Drive (it is set at DS1).
The whole goal for this is to get a midi sequencing program (Voyetra Sequencer Plus) to run on the Amstrad 1512. I have tried to run the file straight off of my XT-IDE but I've been unable to bypass the insert floppy command. I did a bit of footwork with substitute commands, etc. but had no luck.
I have a 3.5 DD copy of the software so I was going to just try to run it from the B: drive. If the floppy option doesn't work I may go with a Gotek solution.
Reply 3 of 39, by amstradus
Just found this in the service manual:
Reply 4 of 39, by mkarcher
amstradus wrote on 2025-11-07, 19:10:
Just found this in the service manual: […]
Wait a second. I recently remote serviced an Amstrad 1640 over WhatsApp (finally unsucessful), and that thing doesn't have the 3.5" ("Berg") drive power connector, only the 5.25" ("Molex") connector. The Molex connector has the standard pinout. If you use a standard 5.25-to-3.5 power adapter cable, the voltages are assigned correctly, no need to swap anything. It's possible that the Molex pins are counted the other way compared to the Berg pins.
Reply 5 of 39, by weedeewee
mkarcher wrote on 2025-11-07, 20:11:
Wiki to the rescue
https://en.wikipedia.org/wiki/Berg_connector
https://en.wikipedia.org/wiki/Molex_connector
Do not ask Why !
Reply 6 of 39, by amstradus
Sorry, I am referring to the adapter I am using to connect to the drive. I am getting mixed info as to where the drives are powered (at pin 1 or pin 4). Maybe you are more familiar.
My 3.5 EPSON SMD-1300, I just found out by testing, is powered at pin 4 at 5V. So the standard connection works. My search results kept showing it was powered at pin 1 so I didn't want to blow the thing up.
Side note, and maybe I should start a new thread for this, but I am getting a "sector not found" message when I try to run the software disk or format a blank DD disk. The drive is a 1.44 but I think it's supposed to be able to run at 720k. I edited the batch file on the Amstrad to add
DRIVEPARM=D:1 /F:2
but maybe there is something else I need to do... or maybe this drive won't be compatible...
Reply 7 of 39, by DaveDDS
Any time you are working on things even slightly "odd", a miltimeter is a good
investment. For simple "hooking things up", you don't need a fancy/expensive.
(A $5 one is so much bettern than none) -though I do recomment splurging enough
to get one with an audible "continuity" function) - The most common functions
you are likely to use are:
-- Voltage --
In this case it would be trivial to check the the voltages are on the right
lines to the drive. The connectords will look something like:
           /------------\                 ___[~]___
5.25" -> | O O O O | 3.5" -> | O O O O |
These both have the two center pins grounded, +5v on one end and +12v on the
other. I don't recall which way they go (and can't be bothered to go downstairs
and look), but it should be easy to find the pinouts online - they are almost
always Black(Ground) in the two center, Red(+5) and Yellow(+12) on the ends
(but always confirm)
-- Resistance/Continuity --
Always handy when checking connections/wiring you've made. This is where an
audible continuity function is nice - simple beep when you touch the probes
to things that are connected.
- Dave ; https://dunfield.themindfactory.com ; "Daves Old Computers" ; SW dev addict best known:
ImageDisk: rd/wr ANY floppy PChardware can ; Micro-C: compiler for DOS+ManySmallCPU ; DDLINK: simple/small FileTrans(w/o netSW)via Lan/Lpt/Serial
Reply 8 of 39, by amstradus
DaveDDS wrote on 2025-11-07, 21:19:
Any time you are working on things even slightly "odd", a miltimeter is a good investment. For simple "hooking things up", you d […]
-- Voltage --
Cool connectords 😀 Thanks for the tips
I did finally end up using a multimeter to check the power coming from the Amstrad before I tried the drive. Pin 4 is indeed +5 volts, pin 1 is +12 volts
Reply 9 of 39, by mkarcher
amstradus wrote on 2025-11-07, 21:18:
The Gotek I have does not use +12V, and requires 5V on the pin that is closes to the 34-pin floppy connector.
If you want to use a 1.44M drive as 720K, I got best results if I did both of
  • ground pin 2 to put the drive into DD mode. Some drives also have jumpers to permanently select DD, but that's uncommon.
  • use 720K media, or tape the hole of 1.44M media.
depending on the drive, one of these steps may suffice, but its safest to make sure both the interface pin and the media type sensor agree on DD mode.
Reply 10 of 39, by amstradus
mkarcher wrote on 2025-11-07, 22:11:
The Gotek I have does not use +12V, and requires 5V on the pin that is closes to the 34-pin floppy connector. […]
Thank you--
Sorry, ground which pin 2? From where to where? Isn't pin 2 already going to ground?
I have pins 2 and 3 ground, and pin 4 is 5V. I left pin 1 (12V) disconnected.
I'm pretty sure the software diskette is 720k (it just has a single notch upper right). And I have some720 DD diskettes.
Reply 11 of 39, by amstradus
I suppose you mean grounding pin 2 on the ribbon/floppy connector to an odd numbered pin? What would you say is the most straightforward method? I'd prefer not to take apart the Amstrad cable, and I don't have any extra ribbon cable or connectors.
Reply 12 of 39, by mkarcher
amstradus wrote on 2025-11-07, 23:41:
OK, so the disk(s) are fine then.
amstradus wrote on 2025-11-08, 05:28:
I suggest you wrap a thin bare copper wire (e.g. a single strand of a stranded wire) around pin 1 and 2 at the 3.5" drive and twist the ends to fix it. that should still be thin enough that you can easily connect the adapter and the Amstrad cable. I just re-checked the service manual of the 1512, and confirmed that pin 2 is not connected to anything on the main board. Pins 1 and 2 should be next to the power connector at the drive.
Reply 13 of 39, by konc
amstradus wrote on 2025-11-07, 18:47:
Yeah I thought so, a different model and AI hallucinating as usual. This "trick" to switch pins 1 & 4 is used on the Amstrad CPC 6128 when replacing the 3" with a 3.5" drive, unless someone corrects me I'll insist that the 1512 drives are standard ones.
amstradus wrote on 2025-11-07, 21:42:
Let's make sure we are on the same page: on the molex pin 1 is the yellow wire and is indeed 12V. On the 3.5" floppy connector pin 1 is where the red wire is and is, of course, 5V. So when you connect your adaptor and measure at that end, pin 1 will be 5V. Isn't that what you need? Don't assume pin numbering, always check the pinouts to be sure. But then again do as you choose so that you won't blame me if you blow up anything 😉
The attachment Untitled.png is no longer available
Reply 14 of 39, by amstradus
mkarcher wrote on 2025-11-08, 07:51:
OK, so the disk(s) are fine then. […]
Woops, I missed this message. Thank you!
I will try. Does the thickness of the strand matter? I have some copper wire but the strands look very thin...
Reply 15 of 39, by amstradus
konc wrote on 2025-11-08, 14:24:
Yeah I thought so, a different model and AI hallucinating as usual. This "trick" to switch pins 1 & 4 is used on the Amstrad CPC […]
Ahh, now I see. I think I assumed pin 1 on the berg connector side would be in the same orientation as it is on the ribbon cable connector. Yes! It is what I need 😀
Reply 16 of 39, by amstradus
Here is the connection with new wire on pins 1 and 2. Maybe it is not substantial enough of a filament...
I tried the drive again and am getting the same error:
Reply 17 of 39, by mkarcher
Oh, that's strange. So the computer is able to read track 0, which contains the FAT and the root directory, but it can not read files. This looks like seeking does not work, and the drive is stuck at track 0. If it tries to read sectors of a different track, it still finds the sectors of track 0 but does not find the requested sectors. Do you hear any seeking sounds?
Reply 18 of 39, by DaveDDS
Good way to test seeking --- use ImageDisk
In the Align/Test function, you can seek to any track.
In the clean-heads function, it "scrubs" the heads by seeking back and forth.
Both easily visible.
Reply 19 of 39, by amstradus
mkarcher wrote on 2025-11-10, 19:52:
If I try to run the install file I hear five short rather loud 'scrubbing' sounds, and then I get the error message.
https://youtube.com/shorts/UVSfhkCMgY0?feature=share
I also tried to format a blank disk and I get the same error message
