ATi RagePro supported games
Reply 20 of 152, by marxveix
dr.zeissler wrote on 2025-11-30, 09:18:
I think you got me wrong on some things. […]
1. The driver I am using is marked DX3, but it works with everything I tested up to DX7 (my demos require DX7).
2. The driver I am using is working with the DVD Player Software from ATI. There are several (two?) versions of the dvd-Player but I only managed to combine the driver and the dvd-player-software I use. Every other combination of driver and dvd-player throughs errors at me or hangs up the machine when starting the dvd-player software.
3. You may perhaps have run doomGL with openGL and the floor-textures and lights are rendered correctly but that is not the case in my driver-combination. I tested several OpenGL versions but they did not work for me and the issue remains the same. Keep in mind that the openGL version I am using has issues with DoomGL but works just fine for quake.
4. Of course CIF is working just fine with my driver.
5. Later Version of the ATI driver crash/hang up some direct-draw games. Like xenon2k. I had to use that old one in order to make it work.
Beside the DoomGL problems the only downside that I had noticed is that acdsee3 hangs-/lockups zee machine when displaying monochrome-stuff. I have to investigate this, or switch to another picture-viewer.
Doc
1.DX7 demos from this tool?
https://www.pouet.net/prod.php?which=20544
https://www.pouet.net/prodlist.php?platform%5 … 1&order=thumbup
2.I know at least two 3.10 version of ATi Player, one with older engine, other newer. Then there is 3.2 and 6.2, but they all look the same.
There are older ATi DVD-s, like 1.20 and 1.27, i am missing only 1.27 version at the moment. Someone has ATi DVD Player 1.27 or 127?
5. Nice to test then with this game, thanks.
Best ATi Rage3 drivers for 3DCIF / Direct3D / OpenGL / GLUT / DVD : ATi RagePro drivers and software
33+MiniGL / OpenGL Win 9x dll files for all ATi-Rage3 based cards : ATi RagePro OpenGL files
Reply 21 of 152, by dr.zeissler
1. OldSkoolDemoMaker YES (keep in mind that the wobbling effects do not work on old ati/matrox. seems hardcoded to Nvidia
2. I use the old one
Perhaps there is a combination where everything works that I have not found. direct-draw is very important for me, more important than OpenGL on this machine and the later drivers have issues with direct-draw on my setup with PCI-RagePro, maybe the AGP Version is not effected on this.
Reply 22 of 152, by marxveix
dr.zeissler wrote on 2025-11-30, 17:14:
My drivers are dx6 or dx6.1 ones, dxdiag directdraw works and xenon2000 game also works well, just played it 15-20 minutes.
I can check it with Rage Pro PCI 4MB if you want?Edit:Played 5 minutes with Rage Pro PCI and same as with AGP card, it works.
Used my latest 5.40 drivers for AGP and PCI Rage Pro
To be more correct, then Rage3 cards have 4 API support, not 3 API support for Win9x
1. DirectDraw 2D API hardware acceleration
2. Direct 3D is 3D API hardware acceleration
3. ATi-CIF API hardware acceleration
4. OpenGL API hardware acceleration
Reply 23 of 152, by marxveix
Evil Islands: Curse of the Lost Soul (from 2000/2001)
Never played this game, someone has and is it good?
https://www.metacritic.com/game/evil-islands- … -the-lost-soul/
More demanding game for RagePro,but it is supported,8MB 2xAGP please
I would try it @RageXL 8MB AGP (4xram-64bit) / RagePro cards 8MB AGP
Use faster CPUs, not minimal configuration @ 233 or 266MHz Celeron/P2
https://allods.gipat.ru/sites/evil-islands_.c … eng/faq_hw.html
https://allods.gipat.ru/sites/evil-islands_.c … g/settings.html
If ingame dithering settings does not work,try Rage2dev and Rage Pro Tweaker tools
ATi Rage128 / Rage128Pro is fully supported and runs well @ 32bit, best experience 😀
Evil Islands: Curse of the Lost Soul (original 2000)
https://nival.com/games/pc-games/evil-islands
Evil Islands: Lost in Astral (expansion pack: 2006)
How is the expansion pack, its hard game to find
https://www.uvlist.net/game-168797-Evil+Islan … +Lost+in+Astral
Reply 24 of 152, by marxveix
First comparison is with Turok1 vs at someones OC results
Main difference comes with driver, hes is using his latest.
Re: ATi RagePro supported games
Celeron 500MHz Mendocino (5x100MHz) OC
128MB RAM, 440ZX, Rage Pro
Turok1 640x480x16 27.0fps Rage Pro 8MB AGP
vs
Celeron 533MHz Mendocino (8x66MHz) Default
128MB RAM, 440EX, Rage Pro
640x480x16 42.7fps - ATi Rage PRO 8MB AGP
Turok1 with fog and everything ATiD3D default (Xpert@Play setting)
640x480x16 40.8fps - ATi RageLT PRO 8MB AGP - very long benchmark
640x480x16 42.7fps - ATi Rage PRO 8MB 2xAGP - very long benchmark
640x480x16 47.7fps - ATi Rage XL 8MB 2xAGP - very long benchmark
Rage LT Pro vs Rage Pro are bit different + faster Rage XL added.
Rage LT Pro 13,8fps more, 27 vs 40,8 at D3D with average fps, same resolution.
Rage Pro 15.7fps more, 27 vs 42,7 at D3D RagePro vs Rage Pro, same resolution.
Rage XL 20,7fps more, 27 vs 47,7 at D3D RagePro vs RageXL, same resolution.
Did not think that Rage LT Pro is slower than Rage Pro or my Rage LT Pro has slower clocks,
all settings are the same, just three different Rage3 cards. Still RageXL is the fastest Rage3.
Reply 25 of 152, by dr.zeissler
I am not sure if they are really the same (RagePro vs. RageLtPro) because the RageLtPro fails in amithlon while RagePro seems to be fine in VESA.
Reply 26 of 152, by marxveix
dr.zeissler wrote on 2025-12-06, 19:19:
I add Rage Pro result soon - soon, i think they are the same for Turok1 or similar.
edit
It was faster, Rage LT Pro was 40,8fps - Rage Pro got 42.7fps.
Maybe clocks are different, but Rage XL still faster.
27fps result is taken from here:Rage Pro 4MB+4MB AGP
https://www.clous.cz/ati-3d-rage-pro-agp-2x/
So difference is even bigger, Rage Pro vs Rage Pro
Turok1 27fps result is not my result,pc are similar
Run1: 27 vs 42.7, difference 15.7fps at average results.
Run2: 27 vs 43.1, difference 16.1fps at average results. 😀
Second run was faster 42.7 vs 43.1, i will not change first bencmarks results for any cards!
Same 540 driver,different results with fog,can it be system specific problem?
Now i have DX6 D3D with FOG, its Windows 95 and Directx8.0a-fresh install.
No need to downgrade D3D to DX5, DDRaw,CIF, OPENGL, DVD, all works now.
Now i did run 3D Mark99 Max at default 800x600 and no difference here.
RagePro = RageLTPro, ATiRageXL is winner
3D Mark99 Max 1321p - ATi RagePro 8MB AGP
(Rage LT Pro, same 3DMark score as Rage Pro)
3D Mark99 Max 1465p - ATi RageXL 8MB AGP
Reply 27 of 152, by marxveix
At first i did not give any attention to DDraw (DirectDraw 2D API hardware acceleration) and its games. DDraw games can also be here.
I have not played many 2D API games,but these are listed as DirectDraw ones+Rage3 cards have DirectDraw HW Acceleration @Win9x.
Up to 277 released games and add-on games for DirectDraw and Windows? There are no filter for Windows version,all is one Windows.
Moby Score (from best)
https://www.mobygames.com/game/attribute:3392 … y_score/page:1/
Critic Score (from best)
https://www.mobygames.com/game/attribute:3392 … c_score/page:1/
Player Score (form best)
https://www.mobygames.com/game/attribute:3392 … r_score/page:1/
Reply 28 of 152, by marxveix
DethKarz 1998 - ATi RagePro is fully supported
From DethKarz Readme.txt
Direct3D Support:
Full support:
ATI Rage Pro
3Dfx Voodoo1
3Dfx Voodoo2
3Dfx Voodoo Rush
3Dfx Banshee
Intel i740
Matrox G200
Matrox Mystique / MY220
Nvidia Riva 128
Permedia 2
Power VR
Limited or not fully tested support:
S3 Virge/DX (375)
Rendition 1000 series
Nvidia TNT
https://store.steampowered.com/app/1257910/DethKarz/
https://www.mobygames.com/game/3167/dethkarz/
https://thandor.net/benchmark/14
Two more games that has ATi Rage Pro support.
Wing Commander: Prophecy
https://www.wcnews.com/wcpedia/Category:Wing_ … em_Requirements
M1 Tank Platoon II
https://www.subsim.com/radioroom/printthread. … 03D%206MB%20PCI
Reply 29 of 152, by MadMac_5
marxveix wrote on 2025-12-11, 15:21:
I played through Prophecy several times with my ATI Rage Pro 27 years ago, and it played surprisingly well. Performance seemed OK at the time, but I was also coming from a 486 DX2-66 and anything better than 20 FPS felt as smooth as butter. I should toss the Rage Pro back into my 440BX rig and test it out just for fun, after the other three projects that I have on the go get finished.
Reply 30 of 152, by marxveix
MadMac_5 wrote on 2025-12-13, 05:24:
I have not played this game, by the video its a movie and game combination, so it was and is a good game if you played it several times? If you worry about performance and still want to use Rage Pro based card, use faster Rage XL AGP with 4 memory chips, not 1 memory chip and you should be fine i think. With good motherboard chipset, like your 440bx, its should be no problems with that game and the original Rage Pro.
Faster Pentium II or Pentium III cpu is good companion for Rage Pro, gets bit more out of Rage3 cards than slower end and more older cpus.
I had Celeron 300A at 450Mhz with Rage Pro 8MB AGP back then, good times. 😀
Reply 31 of 152, by MadMac_5
I have an 8 MB Voodoo 2 if I want to play Prophecy at a high framerate in Glide, and my usual graphics card in that system is a Rage MAXX; the 8 MB Rage Pro is kept around just for curiosity and nostalgia reasons, as it was my first 3D accelerator.
Reply 32 of 152, by marxveix
MadMac_5 wrote on 2025-12-15, 05:40:
Rage Fury Maxx (2xRage128Pro) i never had, only regular Rage128 Pro. Same here, my first 3D card was Rage Pro.
Reply 33 of 152, by marxveix
Speed Busters: American Highways 1998
Other names: Speed Busters (PC) / Speed Devils (Dreamcast)
https://www.mobygames.com/game/2769/speed-bus … rican-highways/
ATi Rage Pro support written on some of the game boxes.
https://www.mobygames.com/game/2769/speed-bus … 4/cover-624368/
Reply 34 of 152, by Putas
There will be too many games supporting the Rage Pro. But I can add:
Falcon 4.0 supports "Rage" since driver 5.30.
Homeworld (even Rage II support)
Panzer Commander
Shogo
Take No Prisoners (even Rage II, discourages Rage Xpression owners from using d3d)
Does an edition of a game like Dungeon Keeper Gold count?
Reply 35 of 152, by marxveix
Putas wrote on 2025-12-18, 09:58:
There will be too many games supporting the Rage Pro. But I can add: Falcon 4.0 supports "Rage" since driver 5.30. Homeworld (ev […]
Panzer Commander
Shogo
Thanks for your input! Most games that are made for Rage II / II+ /IIC should run very well on Rage Pro cards.
Any Game counts if it works well with Rage Pro/ XL type of cards, its more like feedback, what game you have played and played well with Rage3.
Also would be good to find out more games that specificly have been tested out and recommended with Rage Pro from the makers of the Game.
Reply 36 of 152, by Spark
Serious Sam plays well on Rage Pro, if you don’t mind a frame rate on the slightly low side. At least it works with 8mb, I never checked the 4mb version.
Reply 37 of 152, by marxveix
Spark wrote on 2025-12-18, 17:53:
Thanks!
I see it has bit higher requirements + 16mb vga recommendation. You have played it with Direct3D or OpenGL API, at Direct3D its faster?
https://www.mobygames.com/game/3512/serious-s … ncounter/specs/
Max Payne: also game from 2001 and has no Rage Pro support, but actually it works if correct driver version used.
https://www.mobygames.com/game/4529/max-payne/specs/
I have played Max Payne and played it to the end, i just dont remeber was it with Rage Pro, probably was, but i remember it had slowdown moments, newer pc specs helps, not 100% great experience and i used the same m6.12.12 + direct3d 4.12.1031 combo back then. Still great to try and play and it was with Win95 OSR2. I am sure with Rage XL AGP and with VGA Memory OC it can be bit more fun.
Info from here: https://www.oocities.org/ziyadhosein/rprow98.htm
Giants Citizen Kabuto - M6.12.12 is the only driver to correctly display textures.
Black and White - M series crashes the video setup program. Use a J series driver to setup the video. Once done, use any driver for game play.
Max Payne - Preliminary tests seem to favour M6.12.12 coupled to the 4.12.1031 Direct3d module.
Tribes 2 - Massive corruption with popular drivers. No effort will be made to get it working
If i already added in this post some higher requirement games, that should not work with Rage Pro,
i add some more, that can, but not with greatest framerate of all time. GTA III / 4 needs exe patch. 😀
Games like GTA III / GTA VC and Medal of Honor can be run with Rage Pro.
https://www.mobygames.com/game/5189/grand-theft-auto-iii/
https://www.mobygames.com/game/7626/grand-the … auto-vice-city/
https://www.mobygames.com/game/5616/medal-of- … allied-assault/
Reply 38 of 152, by Spark
marxveix wrote on 2025-12-18, 19:16:
Thanks! […]
Thanks!
Yes the game works in both OpenGL and D3D on the Rage Pro, but works better in D3D.
Reply 39 of 152, by Hoping
Max Payne, I find it incredible. I thought that without HTnL it wouldn't be playable. I remember seeing it on a TNT2 and not being able to stand it. I played it at the time with a Geforce 2 MX.
Giants Citizen Kabuto surprises me even more.
If they really are playable to the point that they don't seem like a different game because of the graphics, it's impressive.
