Reply 20 of 30, by Cyberdyne
I more or less do not have a problem anymore. Dos 7Z unpacks newer zip files.
Reply 21 of 30, by Grzyb
Cyberdyne wrote on 2025-12-06, 19:41:
I don't understand what exactly the problem was.
What was the utility that failed to unpack the ZIP files from WINZIP 8.8+ ?
Can you upload a small example of problematic ZIP ?
In 2003, I voted in favour of joining the European Union. However, due to later developments - especially the restrictions on cash usage - I have withdrawn my support. DOWN WITH THE EU!
Reply 22 of 30, by Cyberdyne
PKZIP failed. But now i know that 7Z opens newer ZIP files. Do not have any examples anymore.
Reply 23 of 30, by MrFlibble
Here's a version of DOS Info-ZIP UnZip that extracted OLDIE.ZIP in DOSBox for me.
I keep it 'cause it seems to go about extracting PKZIP 1.1-packed files (Implode and such) a bit faster than later versions.
DOS Games Archive | Free open source games | RGB Classic Games
Reply 24 of 30, by Grzyb
MrFlibble wrote on 2025-12-10, 15:07:
That's version 5.12 - no support for Deflate64.
I would rather compile my own UnZip 6.00.
Reply 25 of 30, by Living
its 2025, who in his right mind uses winzip?
Its been Winrar for me since 2000
Reply 26 of 30, by Cyberdyne
In Windows yes. Winrar has the best user interface. We are talking about packing algorithms and DOS unpacking. And ZIP file is industry standard. In reality only Deflate is industry standard in my opinion.
Living wrote on 2025-12-10, 22:07:
Reply 27 of 30, by Grzyb
Cyberdyne wrote on 2025-12-07, 10:32:
PKZIP failed.
Cyberdyne wrote on 2025-12-04, 21:29:
2.04g
I think I know what the problem was...
- Some modern ZIP utilities default to Deflate64
- PKUNZIP 2.04g doesn't support Deflate64
and there's several solutions for DOS:
- PKUNZIP 2.50 supports Deflate64
- Info-ZIP UnZip 5.50+ supports Deflate64, doesn't support Reducing from PKZIP 0.9x by default, but it can be compiled in
- aparrently the DOS port of 7Z, but AFAIK it requires 32-bit CPU and a lot of memory
Reply 28 of 30, by leileilol
6.3/7/8 had a better icon scheme at least. winzip blue metal compressing orange cabinet > bunch of stupid books
long live PCem
Reply 29 of 30, by MrFlibble
Grzyb wrote on 2025-12-10, 17:44:
Somewhat recent-ish I played around with compiling different recent versions of UnZip with DJGPP. It worked but somehow it was slower in DOSBox than the precompiled versions. I also suspect that more recent releases are generally less well optimized for slower hardware. I wonder if something could be tweaked in the makefile to improve performance? I'd not looked into it then.
Also UnZip 6.00 uses this annoying time zone variable and prints a message when it can't find one.
But it's good to know that support for legacy compression formats can be turned on in the makefile options.
Reply 30 of 30, by Grzyb
MrFlibble wrote on 2025-12-11, 10:18:
OK - I forgot about this, as I always have TZ set on my DOS machines.
With RTC battery dead or removed, first thing I do after power-on is setting the clock via NTP, which requires proper TZ variable.
