First post, by Cyberdyne
Just everytime I leave my guard down and not preunpack my stuff in modernish computer I get burned. It is just bad practice. First it was with RAR3. Then a DOS unpack become available. Then 7Z. But there is a DOS version now available. Now we need to vet ZIP files. The fuc..ing industry standard has a new algorithm after deflate.
Reply 1 of 30, by UCyborg
Nothing new. The version of 7-Zip ZS I have has the following for ZIP:
  • Deflate
  • Deflate64
  • BZip2
  • LZMA
  • PPMd
  • Zstandard
Arthur Schopenhauer wrote:
A man can be himself only so long as he is alone; and if he does not love solitude, he will not love freedom; for it is only when he is alone that he is really free.
Reply 2 of 30, by Cyberdyne
But you can limit your compression. RAR 2.50. ZIP deflate. 2.04g ecr... If you release a nice DOS retro game and provide archives in your homepage. But those archives are more or less unusable in your nice retro machine.
Reply 3 of 30, by Harry Potter
I believe PKZip would work on an old DOS machine and handle .zip files and the Deflate technique. I don't know where to get it, but try Googling "pkzip archiver."
Joseph Rose, a.k.a. Harry Potter
Working magic in the computer community
Reply 4 of 30, by cyclone3d
We could just port 7-Zip to DOS. The Windows GUI is just a front-end for the CLI.
I'm not sure exactly what code would have to be made from scratch as I have never looked at the source or what libraries it uses.
By default, it works all the way back to Windows 2000.
Yamaha XG repository
YMF7x4 Guide
Aopen AW744L II SB-LINK
Reply 5 of 30, by keropi
I am always using the latest winrar of the time with it's zip option to compress archives and the zip files created can be unzipped with the old PKZIP official releases under DOS
If a DOS archive is using an incompatible method just repack it with the winrar trial ( that never ends...)
🎵 🎧 MK1869, PCMIDI MPU , OrpheusII , Action Rewind , Megacard and 🎶GoldLib soundcard website
Reply 6 of 30, by chinny22
It's annoying but only a slight inconvenience.
Much better to unpack on your modern machine and repack to whichever standard you prefer
Reply 7 of 30, by roytam1
keropi wrote on 2025-12-04, 22:09:
some ancient ZIP archives that uses old PKZIP methods (for example, Reduced4) can't be unpacked by 7-Zip/WinRAR/etc. and you may finally need old good PKUNZIP to do so.
Reply 8 of 30, by Grzyb
I always use Info-ZIP.
It's open source, and available for all platforms - the only more portable piece of software is "Hello World" 🤣
Nie rzucim ziemi, skąd nasz root!
Reply 9 of 30, by mockingbird
cyclone3d wrote on 2025-12-04, 22:05:
It's already been ported. See here.
(Decommissioned:)
Reply 10 of 30, by Cyberdyne
Yep. I tried DOS version of 7Z. Version 16.02 and it unpacks newer ZIP files.
Reply 11 of 30, by keropi
roytam1 wrote on 2025-12-05, 07:10:
never found one tbh - is there some example somewhere?
Reply 12 of 30, by Cyberdyne
Have seen few old shrinked and imploded ZIP files. Never heard of Reduced4.
keropi wrote on 2025-12-05, 17:34:
Reply 13 of 30, by DaveDDS
For my DOS stuff I release, I mainly use an original registered version of PKZIP, and I usually use -EXtra compression, and the option to "sign" the .ZIP file.
I have no trouble UPZIPping with older 7ZIP both the DOS versoon, and a couple winblows versions (32 & 64 bit)
But.. I've had reports of problems unzipping with more recent 7ZIP versions:
Re: DDLINK: Easily move files between/To/From DOS systems
Dave ::: https://dunfield.themindfactory.com ::: "Daves Old Computers"->Personal
Reply 14 of 30, by Grzyb
I've created it with PKZIP 0.92...
-e   Specifies the extra compression method.  This method is known as
Reducing. If the -e option is not specified, the default method of
compression is Shrinking.
Info-ZIP needs special compile-time option to support that method...
$ unzip -t OLDIE.ZIP
Archive: OLDIE.ZIP
skipping: MANUAL.DOC `reduce' method not supported
Caution: zero files tested in OLDIE.ZIP.
1 file skipped because of unsupported compression or encoding.
$ unzip -v | grep unreducing
COPYRIGHT_CLEAN (PKZIP 0.9x unreducing method not supported)
Reply 15 of 30, by keropi
heh , winrar opens it and you can view the file but cannot do anything more than that:
! OLDIE.ZIP: Unknown method in MANUAL.DOC
! OLDIE.ZIP: No files to extract
never had this before 🤣
Reply 16 of 30, by eM-!3
Both RAR and ACE use PKUNZIP so they can be used to unpack OLDIE.ZIP.
Cyberdyne, can you show your file that you are unable to unpack in DOS?
Reply 17 of 30, by roytam1
sure. http://ftpmirror.your.org/pub/misc/dos/RbbsIn … 6Z/CHGCOLOR.ZIP
Reply 18 of 30, by DaveDDS
7Zip 9.2 can open OLDBIE.ZIP and see MANUAL.DOC but cannot decompress it "unsupported compression method"
I can open OLDBIE.ZIP in Windows explorer (Win7) and drag out MANUAL.DOC which looks like to normal text file.
I can also unzip it in DOS with PKUNZIP 2.04g and Info-ZIP UnZip 3.0 - also appears to work OK
(I don't know how/when the UnZip I have was compiled, but I've had it *many* years)
Reply 19 of 30, by UCyborg
Who would have thought, Explorer unpacks something 7-Zip doesn't.
But if I haven't come across such ZIP in first 3 decades of being here...may be more likely for pensioners of VOGONS. 😜
