Removing VRAM from bubble wrap
Reply 20 of 41, by Towncivilian
Anecdote: yesterday I received two 8GB DDR3-1600 ECC unbuffered memory modules from eBay. Each stick was individually wrapped in bubble wrap. I took no special precautions freeing the sticks from the bubble wrap other than grounding myself once, and so far, so good - 18 hours and 19 passes in memtest86+ without issue.
abit BX-133 RAID, P3-S 1.4Ghz, 768MB PC133, Radeon 9000 PRO, AWE64, 2x40GB RAID1, Sony SDT-9000 & Connor CTD-8000 SCSI DDS2 DAT drives, Realtek 8169 1GB NIC, Adaptec DuoConnect AUA-3121, Win2k SP4
Depeche Mode Live Wiki
Reply 21 of 41, by MattRocks
DIMMs have fewer exposed parts than graphics cards. And, you're in the USA. And, humid Florida air is dissipating ESD continuously.
UK sorting hubs are heated dry inside, most packages are plastic, highly mechanised, and uniforms are synthetic - it's a hotbed for static electricity all round.
By comparison the US mostly ships corrugated cardboard and may have stricter ESD controls - science aligns with online reports suggesting items should survive more in that kind of environment.
Either way I'm doing everything I can to extract a working graphics card because the I can count 10+ death-by-bubblewrap graphics cards - I don't want another.
Desktop timeline [ MOS 7501 → 68030 → x86(P5/MMX) → x86(K6-2) → x86(K7*) → PPC(G3*) → x86-64(K8) → x86-64(Xeon) → x86-64(i5) → x86-64(i7) ] * lost
Reply 22 of 41, by BitWrangler
I would bet anything provably killed by bubblewrap was killed when wrapped, not killed when unwrapped. The act of spooling wrap off a large roll is probably when static risk is extreme.
Reply 23 of 41, by MattRocks
BitWrangler wrote on 2026-04-12, 15:35:
You are right! 🙁
Wrapping in bubble wrap is one of the times the silicon chips become charged, but technically it is the discharge that kills those chips - the charge and discharge can occur in the same event.
Hypothetical scenario: Rolled bubblewrap can store thousands of volts, which charges the card in the seller's hands. Then the seller places the packet on a grounded surface (e.g. fridge, kitchen sink drainer, or similar earthed surface). In that moment the package discharges thousands of volts and the card ships dead. The seller is clueless. The recipient isn't even part of the equation!
In a situation like that the only winner is eBay. My view is that eBay bears responsibility because eBay should be taking actions to ensure its customers (e.g. sellers) are sufficiently informed to participate in the transaction that eBay arranged. Sadly, our laws are not sophisticated enough to hold eBay accountable but it's an easy fix for eBay to write, "It looks like you might be selling electronic equipment - click here to follow our advice on antistatic packaging."
Back in the real world, there is an outside chance the bubble wrap was grounded and an outside chance the seller was grounded ... but that really is an outside chance because if they knew to ground everything then they would have known to use an antistatic bag!
Either way. I can't know if it's dead until I insert it into a PC and try to boot.
Reply 25 of 41, by pete8475
Towncivilian wrote on 2026-04-12, 12:46:
I would guesstimate that more than 75% of the used hardware I have ever purchased on ebay has shown up in bubble wrap with no anti-static bag.
Anything listed as working has been fine, anything that was listed as "dead or for repair" was in fact dead.
aka pete4237.5
Reply 26 of 41, by rasz_pl
MattRocks wrote on 2026-04-12, 11:09:
I have left the package in my current PC overnight.
this is phone in a bowl of rice levels of placebo. What good do you think this proximity to PC case does to bubble wrap? Plastic is an insulator, it wont discharge just by looking at nearby ground 😀 Either it is charged and needs to discharge slowly with aid of high humidity (or water spray) or its not charged and nothing will happen.
Not to mention if it WAS charged PC case with all those delicate components would be the last place I would put it 😀
Reply 27 of 41, by vvbee
pete8475 wrote on 2026-04-12, 17:21:
No ESD protection + seems to work = worst of both worlds. Goodbye refunds and hello latent damage.
Reply 28 of 41, by MattRocks
According the MetOffice, conditions are good and I am cleared to begin cutting.
Cutting shall commence when the children have calmed.
Reply 29 of 41, by MattRocks
Sorry folks. It was all rather uneventful and inconclusive. When I sliced through the paper and sellotape with a razor blade I could not see any bubble wrap. There was nothing to see on this occasion and the PC booted without issue.
Reply 30 of 41, by pete8475
vvbee wrote on 2026-04-13, 03:01:
Ah yes the latent damage that will some day maybe strike at some nebulous point in the future...
BTW I sold computer hardware for 20+ years, I ran a retail store front and you'd be amazed how many distributors and manufacturers shipped you product in cardboard or bubblewrap and nothing else.
aka pete4237.5
Reply 31 of 41, by MattRocks
pete8475 wrote on 2026-04-13, 22:39:
But did those products have memory chips?
Reply 32 of 41, by pete8475
MattRocks wrote on 2026-04-13, 23:53:
Yes.
Video cards, motherboards, sticks of ram, etc. etc. etc.
and let's not forget the copious amounts of styrofoam and styrofoam packing peanuts that things were so often buried in.
aka pete4237.5
Reply 33 of 41, by vvbee
You're not supposed to learn from the bad examples.
Reply 34 of 41, by MattRocks
pete8475 wrote on 2026-04-13, 23:55:
Yes. […]
Yes.
I don't remember anything messy like packing peanuts but as long as each cards is in an antistatic bag, it doesn't really matter what the packing is.
I don't remember anything being sold without an antistatic bag. I am trying hard but really every internal component I can think of was in an antistatic bag except CPUs - those were either in foam pads or on hard plastic trays protect their pins.
Reply 35 of 41, by AlexZ
I have like 20+ cards (GPUs, sound cards, wifi cards) stored in bubble wrap bags that resemble anti-static bags because I ran out of anti-static bags. I always ground myself when touching the bubble wrap. I have also received various components in bubble wrap and they worked. There were a few GPUs that eventually turned out to be faulty after storage for a few years, but they were passive cooled so ran too hot during their active life and must have suffered damage. Anti-static bags are cheap though, so I will probably buy them and get rid of the bubble wrap.
Pentium III 900E,ECS P6BXT-A+,384MB,GeForce FX 5600, Voodoo 2,Yamaha SM718
Turion 64 MT-40@2.4Ghz,Gigabyte GA-K8NE,2GB,GeForce GTX 285,Audigy 2ZS
Phenom II X4 955,Gigabyte GA-MA770-UD3,8GB,GeForce GTX 780
Vishera FX-8370,Asus 990FX,32GB,GeForce GTX 980 Ti
Reply 36 of 41, by MattRocks
AlexZ wrote on 2026-04-14, 19:27:
Please do that because if any card fails while in storage then the storage has to be a suspect. Sound cards and WiFi cards are a lot more resilient because they rarely have RAM on the boards, and its specifically RAM that is highly vulnerable to damage by static.
Reply 37 of 41, by rasz_pl
Pink/orange bubble wrap bags are ESD safe. They were made for storing electronics.
Reply 38 of 41, by MattRocks
rasz_pl wrote on 2026-04-14, 21:33:
The classic child's first science experiment is to rub a filled balloon on their head to charge it with static, then stick the balloon to the wall.
Balloons filled with air are used because they are light enough to enable the static to resist the effects of gravity. Insulating static materials like rubber become charged, and stick to surfaces while they gradually discharge. Conductive antistatic materials do not become charged, and do not stick to surfaces.
Q. So what happens when I rub pink bubble wrap on my head and press it to a wall?
A. It sticks - it's holding a static charge.
Method: Science demands experiments that can be reproduced and verified
I used a small piece of material to reduce the effects of gravity/weight, and because I don't have much hair on my head.
I rubbed the flat side on my head, and pressed the flat side against the wall.
It's important to not touch the side being tested as doing that would discharge the surface into your finger.
Reply 39 of 41, by StriderTR
Most pick anti-static bubble wraps is generally safe for shipping electronics, with two big caveats.
1. Just becasue it's pink, does not guarantee it's anti-static. You can buy colored bubble wrap, including pink, that's just plain bubble wrap.
2. Unlike anti-static bags that have an external conductive layer, anti-static bubble wrap works by pulling small amounts of moisture out of the air to make the exposed surface conductive and reduce the buildup of a static charge. No moisture, no ESD protection.
That being said, you should be able to rub an anti-static bag on your head on all day and it should never hold a charge, wet or dry. If you do this with ESD safe bubble wrap, your hair and friction will remove the surface moisture and allow it to hold a charge until that moisture is replenished.
Me personally. I always store and ship in anti-static bags, then covered in bubble wrap if needed. For maximum protection, I've also used anti-static bags infused with bubble wrap that has a physical conductive layer, one that does not rely on moisture like the pink stuff. Many modern video cards are shipped and stored this way. However, it's obviously more expensive. Though, I would never ship RAM, or any other sensitive electronic components, with just bubble wrap. Anti-static bags are super cheap.
DOS, Win9x, General "Retro" Enthusiast. Professional Tinkerer. Technology Hobbyist. Expert at Nothing! Build, Create, Repair, Repeat!
This Old Man's Builds, Projects, and Other Retro Goodness: https://theclassicgeek.blogspot.com/
