Reply 20 of 45, by Harry Potter
i'm curious: where can I get the game?
Joseph Rose, a.k.a. Harry Potter
Working magic in the computer community
Reply 21 of 45, by MagefromAntares
In the directory listing I don't see DOS4GW.exe which means that most likely it is statically compiled into the program, which also usually means that it doesn't look for external DOS extender executables, so we are kinda stuck with the inbuilt DOS4/GW professional of the game 🙁
One more thing that can be tried unset the DOS16M variable then create a file named TEX4.VMC with the following contents
minmem = 8192
maxmem = 16384
virtualsize = 16384
Then set the following environment variable:
SET DOS4GVM=@TEX4.VMC
Reply 22 of 45, by DustyShinigami
Harry Potter wrote on Yesterday, 20:04:
Well, they're available digitally on Steam and GOG, but I'm not sure how possible they are to get working in a DOS environment. I'm using the original release.
OS: Windows 98 SE
CPU: Slot 1 Pentium III Coppermine 933MHz (SL448)
RAM: Kingston 256MB 133MHz
GPU: Nvidia 16MB Riva TNT/128MB Geforce 4 Ti 4200
Motherboard: ABit AB-BE6-II Intel 440BX
Sound Card: Sound Blaster Live Value CT4670
Reply 23 of 45, by DustyShinigami
MagefromAntares wrote on Yesterday, 20:10:
In the directory listing I don't see DOS4GW.exe which means that most likely it is statically compiled into the program, which a […]
minmem = 8192
maxmem = 16384
virtualsize = 16384
Yeah, I suspected it might be built in. But thanks for the suggestion. I'll give it a try and bit later and see.
OS: Windows 98 SE
Reply 24 of 45, by Harry Potter
DustyShinigami: are you able to change BIOS settings? Older BIOSes have an option to set the size of RAM. Also, I believe that HIMEM.SYS has an option to set the size of RAM. I don't know off-hand the switch or where to get the information, byt try Googling "himem.sys settings."
Reply 25 of 45, by Harry Potter
Uhh...can you give me an URL?
Reply 26 of 45, by DustyShinigami
Harry Potter wrote on Yesterday, 20:24:
I can adjust the BIOS settings, but I don’t recall seeing one to adjust the RAM. There is something that works for Harvester’s installer. A setting to do with a 16Mb hole. I might try that later; see if it helps.
OS: Windows 98 SE
Reply 27 of 45, by DustyShinigami
Harry Potter wrote on Yesterday, 20:25:
For a copy of the game…? Well, for a site you can get it from for free, it’s best if I don’t. That would be frowned upon. 😄
But the GOG version…
https://www.gog.com/en/game/tex_murphy_the_pandora_directive
OS: Windows 98 SE
Reply 28 of 45, by Harry Potter
Thank you. I should be receiving a $100 gift card in the mail able to ask my people to buy it for me. 😀
Reply 29 of 45, by DustyShinigami
Harry Potter wrote on Yesterday, 20:42:
Awesome. They're great games. I would recommend all three of the FMV games in the series. Despite owning Overseer, I still haven't finished it. ^^;
OS: Windows 98 SE
Reply 30 of 45, by DustyShinigami
minmem = 8192
maxmem = 16384
virtualsize = 16384
Does this file need to be created within the game’s directory or the C drive? And how do you mean, exactly, by unsetting the DOS16M variable? Is there an UNSET command?
I did it within the game’s directory anyway, but the same crash still happens. 😕
OS: Windows 98 SE
Reply 31 of 45, by Harry Potter
DOS doesn't have an UNSET command, but the SET command can erase a variable. Just type "SET var=" where var is the variable you want to erase.
Reply 32 of 45, by DustyShinigami
Harry Potter wrote on Yesterday, 23:24:
Ahh, gotcha. Thanks. 😀
OS: Windows 98 SE
Reply 33 of 45, by DustyShinigami
Well, something different has happened. I unset that variable and then set what was suggested, whilst in the root of C (not sure if that makes a difference…?), and when I try loading the game/setup, I get the general protection fault straight away. At least doing it this early, it doesn’t freeze the system up.
The attachment IMG_5497.jpeg is no longer available
OS: Windows 98 SE
Reply 34 of 45, by NeoG_
A lot of the time the general protection fault overlayed onto the software UI is because of some strange or incompatible sound setting (or even sound hardware issue) - My guess is if you run the game with no sound device selected it will work fine. Probably worth doing as a troubleshooting step.
Reply 35 of 45, by DustyShinigami
NeoG_ wrote on Today, 00:08:
Will try that now. I suspect you’re right and it’ll load up.
Whilst trying to remember the name of my custom batch file, I did load up the Pandora.bat file in a text editor and it has this:
The attachment IMG_5498.jpeg is no longer available
OS: Windows 98 SE
Reply 36 of 45, by MagefromAntares
First I have to say that NeoG_ is right, general protection fault is a quite general error, so it is very well possible that it might be caused by something else than DOS4/GW attempting to use memory, in fact it is possible that the error is caused by something unrelated to DOS4/GW, it is just making DOS4/GW fail.
Well at least by the change of behaviour, it seems that the DOS4/GW version linked into this game supports the DOS4GVM environment variable, unfortunately VMC files are a lot more limited in what can be set than the other environment variables 🙁
It is unfortunate that:
set DOS4G=verbose
didn't work, as that can make the error messages given by DOS4/GW so much more useful...
Reply 37 of 45, by DustyShinigami
MagefromAntares wrote on Today, 05:58:
First I have to say that NeoG_ is right, general protection fault is a quite general error, so it is very well possible that it […]
set DOS4G=verbose
I’ll give it a try with 86Box next. I’m sure it’ll be fine with that, though it still won’t pin-point what’s triggering the issue.
Would the CPU affect it at all? Is there no setting I could put in that Pandora.bat file that would help? Specifically for the dos4vgm variable?
OS: Windows 98 SE
Reply 38 of 45, by DustyShinigami
Okay, this makes for a nice change. Usually things are fine with 86Box, but in this case, the issue happens there, too. Which is good because it makes it easier and quicker for testing. 😀
The attachment 86Box_8r6O8nouVr.png is no longer available
The MPU-401 and Roland Sound Canvas options work, but the MT-32 option doesn't, despite having a virtual one configured.
OS: Windows 98 SE
Reply 39 of 45, by DustyShinigami
Also tried the 15-16MB memory hole setting in the BIOS and lowering the amount of RAM to 16MB. The issue still happens. 🙁
OS: Windows 98 SE
