My three retro builds showcase
Reply 20 of 26, by Nick4
dr_st wrote on 2026-08-17, 05:43:
Nick4 wrote on 2026-08-16, 20:27:
Adding some unboxing pictures for 2007-2008 Silver Bullet Build. I just love NOS hardware. […]
Where did that Pentium 4 HT go? 😁
The fun part is that this build started when I acquired this P4. But later I realized that this CPU is underpowered for the rest of the hardware, so I decided to go with a C2D instead. So this P4 is now sitting on a shelf, waiting for its time to come=)
Reply 21 of 26, by AlexZ
Pentium 4 would be too close to that Sempron. Core 2 Duo 2.6Ghz is much faster, although it will get in big trouble in Vista era (2007-2009). Good until 2006. Vista era is very demanding and needs about 3.2Ghz dual core.
Pentium III 900E,ECS P6BXT-A+,384MB,GeForce FX 5600, Voodoo 2,Yamaha SM718
Turion 64 MT-40@2.4Ghz,Gigabyte GA-K8NE,2GB,GeForce GTX 275,Audigy 2ZS
Phenom II X4 965,Gigabyte GA-MA770-UD3,8GB,GeForce GTX 780
Vishera FX-8370,Asus 990FX,16GB,GeForce GTX 980 Ti
Reply 22 of 26, by Nick4
AlexZ wrote on 2026-08-17, 18:05:
This P4 is one of the latest from 2006, 3,2 Ghz, so I think it is much faster then Sempron from 2004. Anyway, there is not much sense to build it.
Reply 23 of 26, by Nick4
Upgraded 2004 TIE Fighter build with a Sound Blaster Audigy 2. The sound card had a well-known issue with crackling sound, so I had to replace some of the caps.
The attachment SB1.jpg is no longer available
I used four Nichicon UHE1E470MDD.
The attachment SB2.jpg is no longer available
After the recap, the crackling issue was solved, but I had some problems installing the drivers. After a few attempts with different driver versions, this issue was also resolved. For now, the Audigy works fine, and EAX is also working.
Reply 24 of 26, by TELVM
If you don't mind Nick4, I'm mostly sound card illiterate.
Are there any special considerations when selecting replacement caps for cards like a Sound Blaster 16 CT4170, or an AWE64 Gold CT4390?
Let the air flow!
Reply 25 of 26, by Nick4
TELVM wrote on 2026-08-22, 11:29:
Sorry, I'm not an expert either. I found info about fixing my Audigy here - Audigy 2 ZS Crackle Fix
