I did some more testing.
I have tested the driver in another PC much more faster (Athlon XP 2400+, MSI KM4AM MS-6734, MS-DOS 7.1 launched from Windows 98 SE with a .pif file, parallel port as SPP, sound via SBEMU using JEMMEX.EXE).
I used the Hori pad and PSXKEY /t detected it perfectly, setting at 0x4000 delay. Playing Bust a Move (without RTC) everything works perfectly. However, playing Lion King (with RTC), despite the pad is loaded properly with PSXKEY, it doesn't work in game and the system speaker keeps beeping every time I press a button, just like when you press many keys on a keyboard blocking it by the key rollover limit. ProjectX (RTC also) is able to be played, but if you try to press lot of buttons at same time it can make some beep also.
Then I relized that, when PSXKEY is loaded without RTC, pressed buttons on the DOS CLI are not registred. But if you load PSXKEY with RTC, the buttons pressed are registred in the CLI, even when the game was running. With lionking.ini loaded, I was able to beep also in the CLI (i.e. with the game not running), pressing random button at the same time. I don't know if this fact is related to what happens in game, but I give the info just in case.
Cheers!
