First post, by ottelo9
The attachment IMG_9674.jpg is no longer available
Connect your PS1/PS2 controller via a adapter/converter (selfmade or from me) directly to your parallel port and play every game in real MS-DOS (reboot in DOS with Win95/98) on real old hardware.
Background/Project history
I bought an old laptop this year (an IBM ThinkPad 380XD) to relive the feeling from my childhood 😜. Windows 98 SE runs perfectly, but old games such as Orion Burger or other rarities from the ‘Gold Games 2’ collection don’t run on Windows. That means booting the machine into MS-DOS mode. However, this means you don’t have CD-ROM, mouse or USB support. Fortunately, there’s ‘MS-DOS Mode Super Easy’ to provide CD-ROM and mouse support. I then had to look a bit further to get USB support so I could get my Logitech USB dongle mouse working.
So I was able to play through Orion Burger on MS-DOS 😉. Next up, though, was a different adventure game: *Time Gate Knight’s Chase*. It’s controlled via a MIDI controller/joystick or keyboard. But as I wanted to play comfortably with a controller, and my laptop doesn’t have a MIDI port, whilst the USB support doesn’t work with joysticks, I had to come up with a solution. There is a docking station with a MIDI port for my ThinkPad, but nah. Too expensive, hard to find and bulky. Running the MIDI port directly from the motherboard: not interested.
SNESKEY
I’ve found what I was looking for. There’s a programme called SNESKey from 1998. It runs in the background in DOS and virtually routes the buttons on an SNES controller as keyboard keys. With the latest version, it was also possible to connect a PSX controller. The whole thing is connected via the parallel port (LPT). With a few diodes and cables, you can build your own adapter. Long story short… it never worked with my PSX controller. I even modified the SNESkey.exe file (using AI and my own programming knowledge) so that it would run in test mode at all. But it never worked with actual games (more info on my blog).
Nevertheless, I still wanted to use my PS1 controller on my retro laptop. As I’d already fed my AI with the SNESKey, I decided to put it to work on a project of its own. And that’s how PSXKEY came about. The AI tried several times to talk me out of seeing the project through, arguing that it would be much easier just to give up and use the keyboard or simply use a DOS emulator 😉. I stuck to my guns.
Using PSXKEY
And lo and behold, it really does work perfectly. Simply copy PSXKEY.exe to any location and run it (in DOS). The programme will then attempt to load the PSXKEY.ini file containing the key mappings (PSX keyboard). If none exists, one will be created with default values. The tool then runs in the background and when you press a button on the controller, it simulates a keystroke on the keyboard. You can now simply start the game. You can customise the .ini file for each game and copy the .exe and .ini files into the game directory.
PSXKEY LPT-PSX Adapter
The attachment psxkey converter 1.png is no longer available
The attachment psxkey converter 2.jpg is no longer available
As not everyone can build their own PSX-LPT adapter, I’ve now designed a PCB and am currently having it manufactured. I already have the components to hand. I’m using a level shifter on the board to convert the 5V from the LPT port to 3.3V for the controller, as the IC in the controller can actually only handle 3.6V. A slightly higher voltage is also possible, but it causes the IC to age more quickly. This means the controller COULD be damaged if a level shifter isn’t used. So far, however, I haven’t come across anyone to whom this has happened, and I’ve already spent around 10 hours gaming with the DIY adapter (without a level shifter). But if I’m going to offer an adapter like this, it has to be professionally made.
UPDATE:
The adapter is finished and I have tested it thoroughly. I’ve made five of them to start with and am now selling them e.g. here (German page). If you want one, please contact me in this thread or on my blog.
Links
My german Blog ottelo.jimdofree.com
PSXKEY github Repo
Want to play games on real MS-DOS hardware/PC using a PlayStation controller ️ (via the LPT port)?
=> use my DOS program PSXKEY together with my optional PSXKEY converter
Reply 1 of 23, by L-Link
Thanks a lot. I was years triying to make a PSX controller work on DOS without success. There is also another parallel port driver for DOS called Console Cable which anounced support for PSX controllers, but just like SNESKey I never was able to make it work with any PSX controller.
Your driver works really well and is fast and lightweight. I tested it with Aces of the Pacific and runs perfect.
However I have found two issues:
- It doesn't work on Project X and Lion King, both of them by East Point Software. I can't remember if SNESKey (using SNES or Genesis pads) have the same problem.
- Is there a way in the INI file to map a button to a numpad key? I tried putting "num5" but it seems that doesn't work. I have a version of Puzzle Bobble which uses that key and can't be changed to another one.
Thanks again for your work.
Reply 2 of 23, by ottelo9
Thanks for the feedback!
Numpad: The new build supports num0–num9, num., num+, num-, num*, num/ and numenter, so cross = num5 works for Puzzle Bobble.
Project X / Lion King: My guess is that these games take over the timer interrupt completely and don’t pass it on, so PSXKEY never gets a chance to read the pad. I’m thinking about an option that uses the real-time clock interrupt instead. Would you be willing to test a build with that?
https://github.com/ottelo9/psxkey/commits/main/
Reply 3 of 23, by ottelo9
Update: Project X and Lion King work now. Add timer = rtc to PSXKEY.INI, then PSXKEY reads the pad via the real-time clock instead of the system timer. Tested both on my Toshiba. Project X needs EMS, and EMM386 works fine with PSXKEY.
There are also example INIs for both games in the ini/ folder. F1–F12 and backspace are supported now too.
Reply 4 of 23, by MoneySquirrel
Wow, this is a cool project! Have you tried it with Super Street Fighter II Turbo? I was never able to get my Sidewinder gamepad to work with that game using keyboard emulation.
Reply 6 of 23, by L-Link
I tested the last release on a Toshiba 320CDS laptop running MS-DOS 6.22 and I have a strange bug, which varies from a slow key response to ramdom freezes with a key holding pressed, even making the game and the gamepad stop working completely. It happened to me both with and without RTC setting enabled.
The new features worked perfectly: numpad keymapping, button presses with RTC are detected on East Point games... but the aforementioned bug is present every time.
When I have the opportunity, I would try to test it on other PC and see if it gives me the same bug.
Reply 7 of 23, by crusher
Wow this is a really interesting project!
Every "new" old hardware/mod is welcome for us retro community.
Keep up the good work 😀
Reply 8 of 23, by ottelo9
@L-Link
Thanks for testing! I found a bug that matches what you describe: PSXKEY injected keys before the timer interrupt was finished, so the game couldn’t read them in time and a second key could overwrite the first one, which leads to stuck or missed keys. Fixed in the new build on GitHub.
Could you test it again on the 320CDS? If there are still problems, please send me the startup line (port and delay) and the error counter from PSXKEY /T.
Reply 9 of 23, by L-Link
With the latest update all the issues have disappeared and now it's working properly with an official Dual Shock 2 (port autodetected, delay auto set to 0x300) and an official Dual Shock 1 (port not autodetected, delay auto set to 0x300).
Incidentally, I have also tried some third party controllers which I have here, with mixed results. As expected, some work properly (i.e. Interact Dual Impact), others struggel to work and it's required unplug and plug the controller before initializating the game (i.e. Hori Analog Sindou), while others didn't work at all (i.e. Nyko Viper>PSX). I expected some third party controllers having trouble because it's used to happen that with other parallel port drivers for other OSes. I share this only for informational porposes.
Thank you a lot for this project.
Reply 10 of 23, by ottelo9
Thanks again! I had a look at the Dual Shock 1 detection: the auto-detection polled the pad back to back without any pause, which is too fast for some pads. It now waits about 1 ms between polls and gives the pad a bit more time after power-up. Could you test the new build with the Dual Shock 1, and maybe also with the Hori? It might help there too.
https://github.com/ottelo9/psxkey/releases/tag/2026-11-14
Reply 11 of 23, by Shiftyy
I would be interested in an adapter that connects a PS1 controller to the midi/gameport rather than LPT.
Reply 12 of 23, by MoneySquirrel
Do you plan on also making parallel port adapters for snes controllers? I guess psx controllers have more shoulder buttons, but the snes d-pad is so perfect. Did you get a chance to test Super Street Fighter II Turbo? You'll definitely need the official patches too, as sometimes the keyboard inputs don't respond in the original release. It definitely does something different with the keyboard input, maybe it's related to supporting 6 button controllers via the game port?
Reply 13 of 23, by L-Link
@ottelo9
I have tested the new build with those pads.
Dual Shock 1 now is always detected.
Hori do a strange thing:
- If it's connected before powering on the computer, then is not detected until it's unplugged and plugged a single time. In this case, after this plug/unplug cycle, it works perfectly and is always detected even after loading and unloading PSXKEY multiple times.
-If the controller is not conected when computer power on and it's plugged after boot DOS, then it's detected on the first try without have to unplug anymore. And it continues to be always detected after subsequent loads and unloads.
Both controllers are auto set to 0x300 delay. On the previous release, the Hori was auto set to 0x800.
Reply 14 of 23, by ottelo9
@L-Link
Thanks for testing again! The Hori probably doesn’t get a clean reset while the PC boots, because the BIOS toggles the parallel port lines. The new build switches the pad’s power off for a moment before detection, which should do the same as unplugging it. This only works if your adapter powers the pad from the data lines (pins 6–9).
One more thing: a self-built adapter without level shifters drives the pad’s CLK, CMD and ATT lines with the full ~5 V of the parallel port. The controller is designed for 3.3 V, so this can damage it over time.
New release:
https://github.com/ottelo9/psxkey/releases/tag/2026-11-15
@MoneySquirrel
No, I dont plan to build a new adapter for SNES controller, because its very easy to build it on your own + I haven’t sold a single one of my PSKey adapters so far. So It think it’s simply not worth putting any time into a SNES adapter.
Note: The SNES controller runs on 5 V, just like the parallel port. So you don’t need a special adapter with level shifters like for the PlayStation pad. A few wires and diodes are enough, and anyone can solder that themselves. PSXKEY doesn’t support SNES pads yet. Until then you can use the old DOS program SNESKEY, which already works with SNES pads on the parallel port. Wiring: https://www.instructables.com/SNES-to-Parallel-Port/
@Shiftyy
The gameport only has inputs (4 buttons and 4 axes), no outputs. But a PS1 controller needs the PC to drive three of its lines, so it can’t be wired to the gameport directly like to the LPT port. It would need a small microcontroller in the adapter that reads the PS1 pad and acts like a normal PC joystick. Games with joystick support would then work without any driver, but only with the d-pad and 4 buttons, because that’s all a standard gameport joystick has.
So it’s possible, but it would be a separate project, not part of PSXKEY.
Reply 15 of 23, by L-Link
On the 320CDS with the latest build the Hori isn't autodetected at all. If you unplug and plug the pad in the test mode, it stop to give errors, but when you launch PSXKEY.COM it fails to autodect and the controller doesn't work with the games.
However I also tried the lastest build on a Biostar M5ATD with parallel port set as PS/2. Official Dual Shock 2, Hori Analog Sindou and Nyko Viper>PSX are autodetected and work properly. However Dual Shock 1 doesn't work at all. If I change the parallel port on BIOS from PS/2 to SPP, it gives me trouble with most of the other controllers.
Something that I observed related the Dual Shock 1 is that, when analog button is pressed, on 320CDS the red analog LED blink less than a second and inmediately returns to digital mode, while on M5ATD it doesn't respond at all, just like the pad is disconected. I wonder if it could be a power issue...
Besides, I tested the Super Street Fighter 2 Turbo 1.6 version and it works perfectly when RTC is enabled on INI file.
Appart from this, I think that would be good to add the possibility of select an INI file by argument when loading PSXKEY.COM
Reply 16 of 23, by L-Link
I did some more tests about what I said in the previous message, and I found that:
- Dual Shock 1 works well on M5ATD using a external 3.3v power supply instead of the paralell port diode connection. I guess the motherboard for some reason doesn't provide enough power on parallel port, because that controller also doesn't work with DirectPad Pro driver under Windows 98 despite the adapter having one more power line with a diode (5 in total).
- On 320CDS, the red LED bliking when pressing analog button on Dual Shock 1 was caused by ECP setting on BIOS. Changing to Standard bi-directional the issue dissappears and the analog button works normal with LED going on or off after every press.
Reply 17 of 23, by ottelo9
Thanks for all the testing, L-Link! New build is up:
https://github.com/ottelo9/psxkey/releases/tag/2026-11-16
- Hori: I removed the power off/on at startup again, it made things worse. Just replug the pad before starting PSXKEY.
- ECP: I can see the same analog LED behaviour on my Toshiba. PSXKEY now switches ECP ports to Bi-Directional (PS/2) mode itself, so it may work in ECP mode now too.
- Power: yes, the parallel port only gives a few mA depending on the board, so an external 3.3 V supply is the way to go there.
- Your idea is in: PSXKEY GAME.INI loads any INI file. I also added an SSF2T.INI (thanks for testing it!).
- New: Pause key and key combos on one button, e.g. cross = ctrl+e
@MoneySquirrel
I tested "Super Street Fighter II Turbo" DOS floppy version 1.0 patched to 1.5 (with MIDI support) and as L-Link already wrote, it works! A ready-made SSF2T.INI is in the repo's ini/ folder!
Reply 18 of 23, by MoneySquirrel
Oh wow, so SF Turbo is one of those games that takes over the system timer? It might be too technical for me, but what was the advantage of doing that? Some old school hack-ish way of syncing the video, audio, and inputs? It's a pretty great port, probably the best home version from back in the day, before the next-gen consoles. Obviously the Achilles heal would've been getting two 6 button controllers working on a PC back then. According to the readme, a six button gameport controller together with a six button keyboard emulation pad was a working combo 🤣. Thanks for testing the game, guys! And cool that it has a custom INI for psxkey!
Reply 19 of 23, by MoneySquirrel
So I was thinking, since we verified that SSF2 Turbo works, do you think a full-on arcade joystick would work with psxkey 🤣? Something like the Hori Fighting Stick PS? Would be interesting.
