Reply 20 of 27, by remowilliams
If it's of any use, here's my .conf
[sdl]fullscreen=falsefulldouble=falsefullresolution=originalwindowresolution=originaloutput=surfaceautolock=truesensitivity=100waitonerror=truepriority=higher,normalmapperfile=mapper.txtusescancodes=true[dosbox]language=machine=vgacaptures=capturememsize=16[render]frameskip=0aspect=falsescaler=normal2x#scaler=2xsai[cpu]core=dynamic#core=normalcycles=auto#cycles=3000cycleup=500cycledown=20[mixer]nosound=falserate=22050blocksize=2048prebuffer=10[midi]mpu401=intelligentdevice=defaultconfig=[sblaster]sbtype=sb16sbbase=220irq=7dma=1hdma=5mixer=trueoplmode=autooplrate=22050
[gus]gus=truegusrate=22050gusbase=240irq1=5irq2=5dma1=3dma2=3ultradir=C:\ULTRASND[speaker]pcspeaker=truepcrate=22050tandy=autotandyrate=22050disney=true[joystick]joysticktype=autotimed=trueautofire=falseswap34=falsebuttonwrap=true[serial]serial1=dummyserial2=dummyserial3=disabledserial4=disabled[dos]xms=trueems=trueumb=truekeyboardlayout=none[ipx]# ipx -- Enable ipx over UDP/IP emulation.ipx=false[autoexec]# Lines in this section will be run at startup.### regular Dosbox boot config ###mount c c:\games\dosboxhdc:mount d: g:\ -t cdrom### config to install floppy images to hard drive file ####mount d c:\games\dosboxhd#imgmount c d:\c.img -size 512,63,16,60 -t hdd -fs fat### config to copy installed HD file games to dosbox HD ####mount c c:\games\dosboxhd#imgmount d c:\c.img -size 512,63,16,60 -t hdd -fs fat
