Dosbox 0.70 is out!
Reply 20 of 88, by franpa
setllers 2 @ 80,000 cycles 😁 (any higher and the midi starts playing in slowmo and cpu also averages about 45%)
blood @ 120,000 cycles (averages around 45% cpu usage) 😁
what do i need to compile under windows? theres no terminal for typing "sudo sh package" or whatever the syntax is.
AMD Ryzen 3700X | ASUS Crosshair Hero VIII (WiFi) | 16GB DDR4 3600MHz RAM | MSI Geforce 1070Ti 8GB | Windows 10 Pro x64.
my website
Reply 22 of 88, by SysGOD
when i was reading this topic yesterday, i thought it was a joke first... but iam glad its not.
big thanks to the devs. you have done impressive work! another step closer to v1.0. 😀
one question: are there any special improvements to 0.66rc3 or why the jump in the version number?
Reply 24 of 88, by DosFreak
Jump in version # was so there would no be any confusion with previous 0.6 releases.
Alot of users still come here asking for help with their 0.61/0.62/0.63 and a couple of the 0.66rc releases were leaked...
Changing to 0.70 will hopefully eliminate some confusion.
Make your games work offline
Reply 25 of 88, by franpa
gulikoza wrote:
thanks for the link, mmuch more informative then the readme included with dosbox 0.70
my website
Reply 26 of 88, by amano
rcblanke wrote:
I don't know about the other frontends out there, but I hope to release DBGL 0.55 really soon which will (at least) add support for joystick wrapping. Everything else is already working in the most recent build.
Since joystick options were moved from the bios section to a new joystick section, I expect these to malfunction in older frontends.
Will there be an updated Linux port as well? Your frontend works soo well with Ubuntu 6.10. Kudos for that 😉
Reply 27 of 88, by franpa
so i add an extra path pointing to the location of the sdl.dll file to my autoexec.bat file and reboot the pc?
and at the end i type "make -f PLATFORM=win32 RELEASE=yes CPU=nocona" within the root of the source?
my website
Reply 28 of 88, by DosFreak
It's up to each distro to provide the packages. If you can't wait then you can compile the DosBox code yourself. (It's pretty simple).
Reply 29 of 88, by billoute
well, just passed by and spotted the new DosBox...
what can i say ?
THANKS
just thanks for all the good work... thks to all the team and DosBox contributors.
Reply 30 of 88, by leileilol
CVS 0.66rc1 compiles aren't leaks.
long live PCem
Reply 31 of 88, by red_avatar
😜 true but unlike, say, a 0.65 CVS, the 0.66 RC1 was inferior to the final 0.66 (which became 0.70) so it was much more of a danger than a 0.65 CVS over 0.65. I'm glad it became 0.70 because this way there won't be any confusions.
Reply 33 of 88, by presto
0.70 runs faster than 0.66 on my Mac PowerPC -- thank you! I also am now able to have Windows 3.1 run very nicely in 800 x 600 resolution in DOSBox on my Mac.
Reply 34 of 88, by Reckless
red_avatar wrote:
XulChris wrote:
Neville wrote:
On the minus hand, neither "Blood" nor "Indycar Racing II" worked. So what? I can wait. Hell of a release, people. You can be proud.
What are you talking about? Blood has been tested and shown to work 100% in 0.70. Please visit the games database before concluding a game does not work.
Stangely Indy Car Racing II is not in the database, care to add it anyone?
I'll add it later - Indy Car R2 works just fine. I have a feeling he's using some custom setting that is screwing with certain games.
I downloaded the demo earlier today and whilst the game works fine without the UniVBE extension, I get a black screen with it enabled. Perhaps that's what the op meant ?
Reply 35 of 88, by eL_PuSHeR
Wow. DOSBox is getting better and better. Tried a 1996 demo called "Magic Biniou" by French group eclipse. It now runs with defaults (core=auto , cycles=auto) without hanging. Good work!.
Intel i7 5960X
Gigabye GA-X99-Gaming 5
8 GB DDR4 (2100)
Reply 36 of 88, by Muyfa666
DOSBox is truly an amazing program. It runs most of my games better than I remember them on my native 486 computer.
This v0.70 release seems very stable and improvements in speed are noticeable.
Keep up the good work! Let me play my Sierra classics forever. 😀
Reply 37 of 88, by Neville
Well, well, well, Reckless is right about "Indycar Racing II". It works fine if you uninstall the UniVBE driver from the setup program. Then you get this:
Still can't make it work from DBGL, though, it then complains it can't find INDYCAR.EXE. Probably I need to mount the dir in a different way or something, but it works fine from the DOSBox prompt.
Reply 38 of 88, by abyss
How did you get indycar 2 to run on dosbox. I keep getting can't find indycar and when i try to use the setup it says can't find config.
I than try to run it without dosbox and i can run indycar and the setup program.
Do i need to mount the game in a certain way. It is thr demo version of the game.
Reply 39 of 88, by MiniMax
Rank Moderator
Moderator
abyss - I answered your question about Indycar Racing 7 weeks ago:
http://www.dosgames.com/forum/viewtopic.php?p=72264#72264
_________________
