Dosbox 0.70 is out!
First post, by kruwi
Has anybody noticed yet?
Visit the end of the internet: www.groskreutz.de
Reply 2 of 88, by wd
Rank DOSBox Author
DOSBox Author
And it's 0.70, not 0.7 😀
Reply 3 of 88, by Neville
Do we need to wait for newer versions of the frontends or they will work fine as they are now?
Reply 4 of 88, by rcblanke
I don't know about the other frontends out there, but I hope to release DBGL 0.55 really soon which will (at least) add support for joystick wrapping. Everything else is already working in the most recent build.
Since joystick options were moved from the bios section to a new joystick section, I expect these to malfunction in older frontends.
Reply 5 of 88, by Neville
Well, well, well... I've been fiddling arouns with v0.70 and boy, I'm impressed.
Watch this:
Yes, it's "NASCAR Racing" in glorious SVGA. I had to switch off the tarmac textures, but, hey, I also needed to do that in real PCs until I got a P366. VGA mode works like a dream with full detail on.
And this?
Oh, yeah, baby. The always enjoyable "Comanche 3" running in 640x480 Vesa 2.0 mode. I reduced the detail to the minimum to gain speed, but it's as playable as the day it was released. VGA mode works great.
On the minus hand, neither "Blood" nor "Indycar Racing II" worked. So what? I can wait. Hell of a release, people. You can be proud.
Tested on an Athlon64 3400+. The DBGL frontend worked fine for me, both with old and with new profiles.
Reply 6 of 88, by catchaserguns
Its definitely faster. What games can it take now that could not do before? I hope this one is a big improvement on the others. I know about supposed improvements with other software (Microsoft). Keep on going. Hurrah!
Reply 7 of 88, by ErikGG
D.O.G. 1.53rc1 supports the 0.66 versions but the rc2 that will be released soon will be useable with 0.70. 0.70 is already useable with the current experimental D.O.G. build because it inherently uses the latest version of DOSBox if it detects an unknown version string, and this one is compatible with dosbox 0.70. But with the 1.53rc2 version D.O.G. will also detect and use the 0.70 version of dosbox. D.O.G. 1.53 wil be declared "stable" by next week.
Some easy stats :
Tombraider 1 : runnable with low res on 1GHZ laptop ATI mobility
Railroud Tycoon : runs great unitl you set autocycles, I always do though, but don't run firefox or any other memory hungry program.
Have fun,
Erik.
Read the new FAQ.doc
Reply 8 of 88, by Neville
More:
Now I'm salivating...
Reply 10 of 88, by leileilol
Blood works fine over here. Did you set up the sound card properly?
My a64 3200 can run around Pentium 233 speeds 😁
long live PCem
FUCK "AI"
Reply 11 of 88, by Reckless
Cool! Thanks to the DOSBox team and its contributors 😀
Reply 12 of 88, by halkyon
Very impressive. The new universal build works really well on a MacBook Pro... very nice speeds. 😀
Reply 13 of 88, by XulChris
What are you talking about? Blood has been tested and shown to work 100% in 0.70. Please visit the games database before concluding a game does not work.
Stangely Indy Car Racing II is not in the database, care to add it anyone?
Reply 14 of 88, by franpa
how do i compile a build optimized for my cpu? i've already asked about this but got zero replies... so im at a loss.
AMD Ryzen 3700X | ASUS Crosshair Hero VIII (WiFi) | 16GB DDR4 3600MHz RAM | MSI Geforce 1070Ti 8GB | Windows 10 Pro x64.
my website
Reply 15 of 88, by rhoenie
The Mac OSX port is already optimized for both G4 (and up) and Core Duo (and up) CPUs. But if you decide to do your own build to gain speed then take a look at the included documents. 😉
Reply 16 of 88, by red_avatar
I'll add it later - Indy Car R2 works just fine. I have a feeling he's using some custom setting that is screwing with certain games.
Reply 17 of 88, by wd
Rank DOSBox Author
DOSBox Author
The universal build can be grabbed from the dosbox homepage,
it's your build rhoenie, yes?
Reply 18 of 88, by Qbix
Rank DOSBox Author
DOSBox Author
It is rhoenies build. I'm very grateful for it.
Water flows down the stream
Reply 19 of 88, by Neville
red_avatar wrote:
XulChris wrote: […]
Hell, I didn't meant to cause such a commotion. If I say a game doesn't work I mean it doesn't work for me, not implying that the DOSBox team is not doing their job. When I have more grounded information I'll gladly contribute to the games compatibility list.
I've done some further testing and got "Blood" to work. XulChris was right about this one, I hadn't configured sound properly. As for "Indycar Racing II", the version I obtained works fine under VDMS, but under DOSBox (directly, no frontend used) I get a black screen while sound plays. Setup works fine, though, and I'm sure I got the config right this time.
On the other hand, I did got "Nascar Racing 2" working by executing DOSBox without a frontend. It crashes using D.B.G.L. v0.54, don't know why yet:
