Reply 20 of 21, by Kahenraz
Although this is only marginally on topic, I also experienced FAT corruption with Windows 3.1 when using partitions formatted as 4GB (unsigned int) rather than the standard 2GB (signed int). I believe this worked because DOS 7.1 supported this kind of formatting, although I don't recall exactly. I do believe that the corruption happened from Windows 3.1 having a problem with it though, so it's not a DOS 7.1/Windows 3.1 compatibility problem per se, but more of a compatibility side effect of a feature.
My rule of thumb now, for maximum safety, is to never install Windows 3.1 to a partition larger than 2GB, and to always use FAT and not FAT32.
I believe symptoms of the problem are visible after loading Windows 3.1, exiting back to DOS, and trying to use the DIR command. I think it throws an error.
I should have taken better notes. This is all anecdotal and from memory.
Reply 21 of 21, by Aqua
Hi Guys,
Have anyone Patched Win32s 1.30 Packages for Win 3.1(1) in FAT32, also for MS-DOS 7.10 available ??
Or recommend relevant Win32s Files for replace, include in-for existing normal Win32s Installers. (E.G. From R. Loew)
Because i think, the W32s.386 must be Hex Patched for successful Win32s Programms running Like the Same with 16Bit Win386.exe on FAT32 Partitions.
Thanks in Advance.. ☺️
Am5x86 PCI 3dfx Voodoo1.
AMD K6-2 500 3dfx Voodoo2 SLI.
Toshiba P200MMX PC Card Wonder.
Dell Optiplex Small PC Intel Core Duo.
Dell Vostro 1000 AMD64 X2 LD-52.
