First post, by keropi
Hello!
I had a blast making win3.11 working fine with DOS7.10 (win98SE dos with FAT32 partition) , so I am sharing my experience 😊
1st problem:
DOS7.10 IO.SYS needs to be patched so that windows 3.x can be installed.
This can be done with Ralf Buschmann's OSR2fix package, the program needed is inside the WIN3X.BUG directory. It will backup and patch IO.SYS automatically. Be sure to check the documentation (basically you forget 32bit disk/file access)
2nd problem:
OK you got win3.11 installed but when you exit it you are greeted with this:
The filesystem is fine but until you change a directory and make some file operation then you are stuck with phantom garbage files.
I have posted this problem over MSFN forums HERE and rloew came up with a small patch on win386.exe to stop it from corrupting the DOS directory pointers.
It works for both windows 3.1 and 3.11 , the changes needed are the following:
 Patch SYSTEM\WIN386.EXE as follows:
Windows 3.1
0005EA26: 66 C7 46 49 FF FF -> 6A FF 8F 46 49 90
0005EC38: 66 C7 46 49 FF FF -> 6A FF 8F 46 49 90
Windows 3.11
00065A26: 66 C7 46 49 FF FF -> 6A FF 8F 46 49 90
00065C38: 66 C7 46 49 FF FF -> 6A FF 8F 46 49 90
I have made a small patch to apply this for win3.11 win386.exe, run it under DOS (win386.exe is located in the <windows>\System subdir).
Notes:
* Be sure to load IFSHLP.SYS from the windows3.x directory if you need networking, the win98SE one lacks the needed functions.
* For win3.x avoid the nvidia riva128/TNT driver since it will cause many stability problems.
Thanks for reading and enjoy!!! 😊
    osr2fix.exe
    29.53 KiB
    1575 downloads
    win311-FAT32-compatibility-patch.zip
    604 Bytes
    1561 downloads
    small .com to patch \system\win386.exe to improve compatibility with DOS7.1/FAT32
🎵 🎧 PCMIDI MPU , Orpheus Soundcard , Action Rewind and Megacard website
💻 WTB Amstrad PC7486SLC-33
Reply 1 of 16, by Dominus
Rank DOSBox Moderator
DOSBox Moderator
nice, thanks
Windows 3.1x guide for DOSBox
60 seconds guide to DOSBox
Reply 2 of 16, by AdamP
As I recall, Windows 3.x can be installed in DOS 7.1 (Windows 98 original), but not run without a patch. I also don't recall getting that dir error. I believe I used w3xstart to get Windows 3.x running on DOS 7.1, and yes, it's on a FAT32 partition.
Reply 3 of 16, by keropi
yes you are right about the w3start patch, it's used to run win3x not install it... anyways the FAT32 problem is there and is known for a long time... maybe AdamP your 3.x partition was a small one (~2-8GB?) and that's why you did not get it....?
Reply 5 of 16, by Sammy
Should be possible.
I have win95 and 3.11 under Dos 7.1
I have a config.sys with Selection which Windows to boot.Each windows has its own drive Letter and Folder-name.
But there a some Problems. Some Drivers for example install in the wrong windows.
So i learned, before make changes to the system, make backup first.
But ehen configured well, it works great.
Reply 6 of 16, by Anonymous Coward
MS-DOS 7.x supports long filenames, correct? Is it possible to get those to show up in Win 3.x?
Reply 8 of 16, by Jorpho
Way back in the day, I had a utility that somehow patched the Win3.x File Manager to support long filenames. I guess that counts.
Win3.x is sufficiently unstable that I wouldn't want to do anything more in it than I absolutely have to.
Reply 9 of 16, by DosFreak
Be careful with utilities that don't support LFN and running them on filesystems that do.
I remember running pc tools defrag on my newly installed Windows 95 back in 1995.....not good.
DOSBox Compilation Guides
DosBox Feature Request Thread
PC Game Compatibility List
Running DRM games offline
Reply 10 of 16, by chrisNova777
Riva128 TNT?
does that apply to the m64 card aswell? re: win3.11 driver being buggy?
http://www.oldschooldaw.com | vintage PC/MAC MIDI/DAW | Asus mobo archive | Sound Modules | Vintage MIDI Interfaces
AM386DX40 | Asus VL/I-486SV2GX4 (486DX2-80) | GA586VX (p75) + r7000PCI | ABIT Be6 (pII-233) matroxG400 AGP
Reply 11 of 16, by dr.zeissler
I am currently working in that solution and found this thread. Perhaps I can figure it out.
40GB Harddrive:
02GB FAT16 Boot
06GB FAT32 Dosdata (mostly dosgames)
32GB FAT32 Windata (mostly wingames)
I install Win95b into the Boot-Partition and change the startupfiles so that win95b is always starting to the Dosprompt.
I install Win95b into "Win9x-Folder" and Win311 into "Win3x-Folder".
I create some Batchfiles in order to start either Win95 or Win311. Currently Win311 does not boot at all, Win31 does indeed boot but only with "/s"= Standard-Mode. I must have 386-mode otherwise my sound and graphic-drivers do not work correctly.
Doc
Retro-Gamer 😀PowerMac 6100-66/Houdini 486/66 - G4 Cube 450/Rage128pro OS9.0.1 - Macintosh LC/Apple IIe Card OS6.0.8 - Acorn A4000 Archimedes - Unisys CWD 486/66 + Aztech Washington
Reply 12 of 16, by dr.zeissler
The patches do fix the 386mode issue. Thx!
Reply 13 of 16, by dr.zeissler
I found one bug or is this normal behavior?
- Booting into Win95b command-line and executing win3x after installing the patches.
- When I quit Win31 I get back to C:, but I have to do a reboot because I always get the message "file-system corrupted on C:" if I do anything (like "dir") after quitting Win31.
Reply 15 of 16, by retardware
If I remember correctly there is some option for 3.x win.ini that directs it to use DOS for filesystem operations.
That was not the default behavior because of the performance penalty to enter real mode for every filesystem call.
Right now I do not remember the details, so I am not sure whether I am confusing that with the VirtualHDIrq thing.
Reply 16 of 16, by Delphis1982
Rhuwyn wrote:
Sorry for the Necro. But does this mean you can get Windows 3.11 working alongside Windows 98 as well?
Yes, it's possible, afaik in the same partition as well.
You have to make a bootmenu inside the config.sys to load the drivers needed for each OS.
Then inside the autoexec.bat you have to use the %config% variable to jump to the right section inside the autoexec.bat to make some preparations BEFORE starting Windows:
For example you choose to start Win98. Then in the autoexec you jump to the Win98-Section.
There are some commands to rename some folders.
For example rename the Windows Folder:
:MENU
IF %CONFIG%==WIN311 GOTO WIN311
IF %CONFIG%==WIN98 GOTO WIN98
GOTO EXIT
:WIN311
IF NOT EXIST C:\WIN311 REN C:\WINDOWS C:\WIN311
IF EXIST C:\WIN98 REN C:\WIN98 C:\WINDOWS
WIN
:WIN98
IF NOT EXIST C:\WIN98 REN C:\WINDOWS C:\WIN98
IF EXIST C:\WIN311 REN C:\WIN311 C:\WINDOWS
WIN
GOTO EXIT
:EXIT
Make sure to check, if the Folder was already renamed (for that reason I used the IF EXIST and IF NOT EXIST commands) to avoid renaming twice and therefore scramble both folders.
The programs folder doesn't need to be renamed.
Windows 3.11 uses C:\PROGRAMS, Windows 98 uses C:\Program Files (under Windows 3.11 shown as C:\Progra~1. DON'T CHANGE ANYTHING IN THIS FOLDER!!!).
Of course you have to adapt this commands to your needing, especially the names of the sections I used (WIN98 and WIN311).
They MUST match the section names used inside the config.sys for the bootmenu.
