Reply 21 of 28, by chrs1885
vetz wrote on 2025-04-07, 14:42:
chrs1885 wrote on 2025-04-07, 14:22:
Can someone please re-upload the d3d patch since it doesn't seem to be available anymore?
Fixed
Awesome, thank you . The patch works quite good, I was even able to fix the stuttering when running on Windows XP by using Riva Tuner Statistics Server and setting the max FPS to 30. The last piece missing is getting the glide support up and running. The guide at https://www.myabandonware.com/game/sega-rally … hampionship-a63 is quite good and helped me fixing most of the issues. It also tells you how to add the D3D patch properly. However, in order to get even better graphics you need to the following
After you installed the game - install Unofficial Direct3D patch, simply copy the files to the game folder [...] That patch is based on rare Direct3D version of the game, it adds the better compatibility with modern systems [...]Then install dgVoodoo (2), copy D3DImm.dll & DDraw.dll from MS/x86 folder, dgVoodoo.conf and dgVoodooCpl.exe into game folder [...] If you don't want to play with dgVoodoo, you can also run the game with DDrawCompat or cnc-ddraw. Simply do the same steps but use DDrawCompat or cnc-ddraw instead of dgVoodoo
Using dgVoodoo 2 or DDrawCompat is not an option, since they don't support Windows XP, cnc-ddraw draw doesn't seem to work either. Also dgVoodoo 1.5b doesn't give me better results.
Does anyone know how to get the 3dfx experience when running on WinXP?
Athlon 1,4 GHz
Asus A7V266-E
GeForce 3 TI 200 64 MB
SoundBlaster Live!
Windows XP
Reply 22 of 28, by b0by007
I think you are confused. There is no "3dfx experience". Sega Rally Championship is NOT a glide game. If you read carefull: "... Then install dgVoodoo (2), copy D3DImm.dll & DDraw.dll from MS/x86 folder, dgVoodoo.conf and dgVoodooCpl.exe". The glide dlls for glide games are not even copied.
The dgVoodoo is used with only for direct 3d to achive higher resolutions. I saw this on some patches for Colin McRae 2.
So if the game works in 3d for you in WinXp, then that is all of it.
HP Vectra D2753A 486/25N i486 SX 25mhz
UNISYS SG3500 AMD486 DX2 66mhz
OLIVETTI M4 i486 SX2 50mhz
IBM PC 330 6577-79T, Pentium 166mhz
IBM PC 300GL 6561-350, Pentium II MMX 266mhz
My retro youtube channel!
Reply 23 of 28, by chrs1885
b0by007 wrote on 2025-04-09, 20:08:
Thanks a lot for the clarification! You're right — I probably am a bit confused 😅
Unfortunately, dgVoodoo 2 doesn’t seem to be supported on Windows XP. Is there a way to get the same result without it?
Really appreciate your help — thanks again!
Athlon 1,4 GHz
Asus A7V266-E
SoundBlaster Live!
Windows XP
Reply 24 of 28, by VirtuaIceMan
Just a heads-up, the higher-res assets for the non-D3D game, and improved engine noise (and possibly Game Over sound, but that's just for D3D version) don't seem to load on Windows 10, unless you use WinXP or Win98 compatibility mode, it'll just pull assets from the CD instead. If you do use compatibility mode then custom controller settings may not work.
I suspect some tinkering with Windows Compatibility Toolkit could remedy this, but I'm not so much into tinkering now 😁
Reply 25 of 28, by VirtuaIceMan
I've made a video covering the arcade vs PC versions, including some of the more hidden Direct3D features:
https://www.youtube.com/watch?v=HTqZVtiBewo
Reply 26 of 28, by keropi
VirtuaIceMan wrote on 2025-05-13, 18:30:
Just watched the video great stuff as always
It is too bad there is no fix for the draw distance and FPS, if these existed the pc ports would be more awesome
Reply 27 of 28, by b0by007
That video was awesome! A lot of cool details and informations. Thanks for the 3D patch, man!
Some annotations, if I may, for the PC versions:
- if you finish the game in easy mode, you dont get anything.
- if you finish the game in normal mode, you get the Stratos.
- if you finish the game in hard mode, you get the Extra Stage for Practice.
The cheats with the XYZYX dont work in the 3D version.
I attached the unlocked "save file", if anyone wants to experience the Stratos and the Extra Stage (uncompress and overwrite in the game folder).
Reply 28 of 28, by pinkyo
I'm having really bad unplayable glitching trying this on my XP machine, wondering if anyone has any idea what could be causing it? I can upload some pictures or a video if helpful 😒
