New util for DosBox users.
Reply 20 of 37, by Dominus
Rank DOSBox Moderator
DOSBox Moderator
Hmm, I don't get it 😉
So, I have a data track, chosing that is easy.
Then I have some music tracks, how do I get the program to know which files it should start and end with? I'm really not understanding...
Edit: or is it enough just giving the name and extension and numbers of tracks? I know that a cue/bin needs the index to reflect the "time slot" a track starts in the image. So, does a cue sheet with track files not need the time slot? Writing that, it seems to make sense to me. Am I on the right "track"? 😀
Windows 3.1x guide for DOSBox
60 seconds guide to DOSBox
Reply 21 of 37, by bloodbat
Yes, the name and extension of sequentially numbered tracks are enough.
Since they are separate tracks, the time slot should be zero, otherwise it would start in the wrong frame, it works for uncompressed tracks too, per Maurwurfs suggestion (already implemented: check the options menu).
Reply 23 of 37, by Dominus
DOSBox Moderator
A snapshot of Revision 50 of the CueGen SVN is at https://www.dropbox.com/s/a1m6fg3lz59hp7u/Cue … or-Snapshot.dmg (only for intel OS X 10.5 and higher)
Reply 24 of 37, by IIGS_User
Thanks, you got it. 😀
Klimawandel.
Reply 25 of 37, by leileilol
I tried this on some of my images by Audiograbbing the tracks to Ogg then Imgburn files from folders to image to make the data track and I ran into mounting errors (like MSCDEX: Uknown Error) after creating a cue with this, correct filenames and all 😒
long live PCem
Reply 26 of 37, by bloodbat
All files must be located in the same folder (unless your filename included the path too). Mind if I take a look at the generated sheet?
Reply 27 of 37, by collector
Do you have the right mode for the ISO? I tried this and it defaulted to MODE1/2352, which did not match my ISO. I corrected to MODE1/2048 and it mounted properly.
Perhaps the tool needs a way to select the mode or perhaps a browse to the image file to scan it for the proper mode. Of course it is not that hard to manually edit it. Now if only DOSBox supported more audio formats.
Reply 28 of 37, by jmarsh
It should work with anything supported by the SDL_Sound library, what other unhandled formats would you want to use?
Reply 29 of 37, by Dominus
DOSBox Moderator
It should work with everything SDL_Sound has been compiled with support for and that's the most likely culprit. I think my snapshots and the DOSBox version 0.74-1 for OSX only comes with mp3/ogg support. I'm pretty sure I didn't build any of the other optional dependencies (flac, mod,...).
Windows DOSBox more likely the same.
Reply 30 of 37, by jmarsh
Can you make a proof-of-concept build with FLAC enabled and we'll use it as an excuse to pester gog.com to stop packaging cd audio tracks in lossy formats? 😁
Reply 31 of 37, by bloodbat
collector wrote:
Do you have the right mode for the ISO? I tried this and it defaulted to MODE1/2352, which did not match my ISO. I corrected to […]
Actually, it is planned for the next update.
Reply 32 of 37, by Dominus
DOSBox Moderator
Actually I barely find time these days and I'm just not an audiophil so it doesn't hold much interest for me.
Reply 33 of 37, by leileilol
What's wrong here?
(and yes there's a DOS-based source port out there. Just giving this as an example)
long live PCem
Reply 35 of 37, by bloodbat
A new version of Cue Sheet Generator (the "compressed" part of the name is gone) has been released.
Version 1.2.2. Among other things, the program is more pleasant to look at and use (includes syntax highlighting, for example), you can change the binary file mode and create cue sheets for uncompressed audio as separate tracks (useful for turning your GOG games into CDs to use in a real machine).
Win32 binaries are up, OS X (Intel) binaries to follow shortly.
You can find it at
http://sourceforge.net/projects/cuegen/
Enjoy!
Reply 37 of 37, by badflame
This program does not take into consideration the PREGAP flags 🙁
Is there any other software for Windows that does preserve the flags?
