Reply 20 of 33, by PeterLI
You cannot use a sound card as an IDE HDD controller.
Reply 21 of 33, by ahendricks18
Well, I guess Ill buy a real ide controller. Is the maxtor brand good? Also how would i boot from the hdd on the ide controller?
Main: AMD FX 6300 six core 3.5ghz (OC 4ghz)
16gb DDR3, Nvidia Geforce GT740 4gb Gfx card, running Win7 Ultimate x64
Linux: AMD Athlon 64 4000+, 1.5GB DDR, Nvidia Quadro FX1700 running Debian Jessie 8.4.0
Reply 22 of 33, by PeterLI
1: You need to be able to disable the MOBO IDE controller.
2: IDE is IDE. Brands do not matter. I recommend a cheap ISA I/O card with IDE/FDD and so on.
Reply 23 of 33, by ahendricks18
Would i disable the ide in the bios or with jumpers?
Reply 24 of 33, by PeterLI
Jumpers or BIOS. What is the exact model # of your PB again?
Reply 25 of 33, by ahendricks18
it says legend supreme 730 on the case but in the bios it says pb400
Reply 27 of 33, by ahendricks18
No, I found this: stason.org/TULARC/pc/motherboards/P/PACKARD-BELL-486-PB400-4MB.html. This best matches my motherboard.
Reply 28 of 33, by smeezekitty
I don't have lots of experience with really old PCs but maybe this means i can do something to specify the hdd on the sound card?
That is only for drive geometry. I don't know of any sound card that supports IDE hard drives (at least not with with standard drivers/BIOS support)
Reply 29 of 33, by Sutekh94
That system was more than likely made before hard drive auto-detection was a thing. You will have to manually enter the drive geometry into the BIOS. And yeah, I've never heard of a sound card that can support IDE hard drives, or SCSI hard drives for that matter.
My YouTube | My DeviantArt
Reply 30 of 33, by devius
Usually the geometry information is printed on the HDD label. I had a Compaq Presario 510CDS which also didn't have HDD auto-detection. If the drive parameters are entered incorrectly in the BIOS setup screen the HDD won't boot.
Also, why are you trying to disable the motherboard's built-in IDE controller? What's wrong with it?
Reply 31 of 33, by JayCeeBee64
Rank Retired
Retired
You will find the answer here (just read the whole thread):
found an old packard bell!
I still can't believe what ahendricks18 did to that Packard Bell mobo 😐
Ooohh, the pain......
Reply 32 of 33, by devius
"Ooohh, the pain......" indeed!
Another option is to get a male IDE connector from a dead motherboard and solder it in the place of the broken one.
But, yeah the IDE connector on any sound card can only be used to connect a CD-ROM drive and only a single device can be connected. These interfaces are very basic and don't even have support for master/slave drives. In fact, I never tested this, but it's almost certain that performance of these sound card controllers is pretty bad. Remember that these were produced when CD-ROM drives were transfering between 150 ~ 600KB/s.
Reply 33 of 33, by King_Corduroy
I know... I don't even know how he managed to do that!
Check me out at Transcendental Airwaves on Youtube! Fast-food sucks!
