I have a Radeon Mobility 9600 with 128bit memory,
http://www.newegg.com/Product/Product.aspx?It … N82E16814153028
http://www.ebay.com/itm/ATI-96MXA-RADEON-9600 … FEAAOSwEetV~FbP
(mine has 128MB)
It doesn't have a half sized bracket but it might fit in such case. Some measurments and custom bracket would be needed. I remember it was scoring around 7000pts in 3dmark01 (with P3 1GHz), but unfortunately it was unstable with my 694x chipset and doesn't working with 693A.
The computer was freezing after few minutes of use, it was difficult for it to pass entire 3dmark test. I had to use Omega drivers because i couldn't find anything else working in 9x.
I also have GF6200 64bit and that Radeon was significantly faster.
Well, it is a pretty weird card. Mobile GPU in desktop PC, and actually pretty fast. Maybe i will try with 440BX mainboard later, those problems could be caused by that VIA chipset.
//UPDATE:
I found screenshot of a test with 1.13@1.24 GHz Tualatin. 7620 pts. I also attach GF6200 with same setup - 5458 pts, that's 39% difference.
