What is this 486 mb?
Reply 20 of 22, by brassicGamer
konc wrote:
Well I didn't try to deduce the socket type from anything, they're physically different. Look at the "key" corner:
Very true. Unfortunately it doesn't tell us anything about the board - socket 2 doesn't prevent a 3.3V CPU being inserted.
Reply 21 of 22, by konc
True as well, but I thought you mentioned earlier that socket 2 is 5V only (I don't know if this is true, it's been a while since I last tinkered with 486s). If this is true, it sure narrows down possible CPUs to make this motherboard post with a correct CPU, and certainly less dangerous.
Reply 22 of 22, by brassicGamer
Based on the lack of markings I would be inclined to agree. The only other explanation is that they used left over socket 2s to save money. But that makes no sense given it's a VIP board. I would have thought that choosing a bus was cheaper. Triple bus systems were supposed to save users money, not manufacturers.
I don't know what sort of precedent there is for 5v-only PCI boards. Doesn't make much sense given the signaling village of PCI.
Edit: PCI is dual voltage. Go figure.
