Sam and Max Hanging Notes SC-55
Reply 20 of 24, by NORTHERN WALLY
Okay, bummer. I'll give it a try with slowdown or throttle for cpu reducing
Reply 21 of 24, by NORTHERN WALLY
Tried out Myslow.exe and reduced my Pentium 166mhz by 50% and everything works all smooth now. MT32 with talkie version. Looking forward to a rainy summer day now
http://www.csclub.uwaterloo.ca:11068/myslow/
Reply 22 of 24, by DustyShinigami
Is MySlow the only solution for this? I have used CPUSPD to slow the game down to the correct speed, but still got the hanging note bug with the SC-55. Pretty sure I selected option 5 or 6.
OS: Windows 98 SE
CPU: Slot 1 Pentium III Coppermine 933MHz (SL448)
RAM: Kingston 256MB 133MHz
GPU: Nvidia 16MB Riva TNT/128MB Geforce 4 Ti 4200
Motherboard: ABit AB-BE6-II Intel 440BX
Sound Card: Sound Blaster Live Value CT4670
Reply 23 of 24, by crusher
I'm using ALI5THT.EXE to slow down my PC. So, other tools should work as well. Depends on chipset I assume.
Reply 24 of 24, by sunmax
Couple ideas from my experience with Sam & Max:
- even with slow CPU, the hanging note still happens when not using an intelligent MPU-401 (I'm not able to reproduce with MPU401AT and PCMIDI driving the SC-55)
- it seems to happen more often with the CD talkie version + MIDI GM - the floppy version with GM is fine (different GM drivers)
- it only happens with GM driver (haven't been able to reproduce with MT32 driver)
- it seems to mostly happen in the intro: if we skip it at the "Friends" line, the rest of the game seems to sound fine
Hope this helps.
