Intel overdrive dx4 100 running at only 75mhz
Reply 20 of 24, by treeman
The only pins on the turbochip is a dx/sx setting, I was curious about this and downloaded the pdf instruction and weird nothing about the sx/dx pins. But about 4 pages on how to safely remove the old cpu.
I set the pin on DX, however now im thiking Maybye try SX.
But 116 is a weird number if it was on 3x multiplier I think should show 99mhz exactly like the dx4 overdrive.
I read a thread a while ago about some guy that was trying to oc a old 486 board and was also stuck at some odd mhz reading.
Unless it is a total coincidence and a 586 running at 116 mhz gets exactly the same score as a dx4 running 99mhz. As you say about the readings being correct.
Anyhow I will be on the hunt for a 80mhz crystal as yeah apparently the 586 are very overclockable.
Reply 21 of 24, by amadeus777999
SI outputs wrong numbers when it, sometimes incorrectly, detects a Cyrix core. This happened on every board I've tested it on, so I assume it's software specific.
Reply 22 of 24, by treeman
You are correct, I just ran 2 other benchmark tests which showed correct specs
Reply 23 of 24, by Anonymous Coward
Then I guess everything is running normally. It's weird that the Turbochip doesn't have a clkmul jumper. It must be the only one that lacks this feature.
Reply 24 of 24, by treeman
here is a pic of the amd if you are curious. (there is 1pin only and its sx/dx currently on dx mode)
also I added another 16 meg 30 pin ram now giving me a total of 32mb ram and suddenly my overall speed score doubled! however since we determined that particular app is not accurate I am not fully relying on it.
But I really like the result for a isa only system.
also I have just ordered a 40mhz crystal from ebay, this time Taiwan so looks like this thread just doesn't want to die
