Getting system to boot.
Reply 20 of 25, by Repo Man11
Super Fdisk can speed things up: https://www.youtube.com/watch?v=N5ivV5tyfRs
Reply 21 of 25, by Sphere478
okay. it's booting now some bios setting was causing it to hang at updating escd and verifying dmi pool data. I reset to defaults and disabled system bios cachable (as per jan's reccomendation for k6 + cpus) and set the proper boot order
also tried it with a different cd drive I'm pretty sure the other one was bad
next problem, blue screen in windows 7 setup. says the bios in this system is not fully acpi compliant
is there any chance in hell of getting around that with a bios patch or windows patch?
Sphere's PCB projects.
Reply 22 of 25, by Repo Man11
"Here’s a quick guide on installing the Standard PC Hardware abstraction layer:
Reboot your machine in order to bring back the Windows Setup screen.
once you see the ‘Press F6 if you need to install a third-party SCSI or RAID driver‘ bottom prompt, press F7 (Not F6) in order to bypass the installation of ACPI and install the Standard PC HAL."
https://appuals.com/0x000000a5-windows-7/
I tried installing Windows 7 on my Asus P55T2P4 with a K6-3+ and 512 megs of EDO - it spent most of a day installing it when I finally gave up and pulled the plug and installed XP instead. I've given up on installing anything newer than Windows 98 on such old hardware now.
Reply 23 of 25, by Sphere478
Repo Man11 wrote on 2021-01-24, 19:56:
"Here’s a quick guide on installing the Standard PC Hardware abstraction layer: […]
sweet, I'll give that a shot! thank you so much!
have you tried mini xp? I just booted to that on a live cd and it seemed pretty fast
Reply 24 of 25, by Sphere478
okay, It's crashing before that screen and I don't seem to have that option in bios settings for PSS & SCC Configuration what do you think the chances are of a 1999 bios working? I'm on the 98 bios now and will soon update to jans's 2005 modded 1999 bios i don't think the ram is issue as suggested in the article because I have already loaded windows xp mini on a live cd to desktop on a ram drive
Reply 25 of 25, by Repo Man11
You might as well try updating the BIOS, it can't hurt.
