Getting system to boot.
First post, by Sphere478
Gets past pci device listing then gets stuck on
Updating escd......
I’m trying to get it to boot to a add in card
In the bios I have it set to boot to scsi which I assume is a general “boot to card” setting
I have a sil0680 and a promise tx4 300
I have a bootable cd in a drive on the sil0680
I have a drive with windows (may be a uefi install is that the right acronym?)
Not sure what updating escd is
My next thing I was gonna try is formatting a drive and putting the windows 98 install on it and seeing If I could boot to it? (How do I do that from a Iso? Just coppy files out of the iso to a fat32 partition that is set active?
Sphere's PCB projects.
Reply 1 of 25, by Repo Man11
I've never had any luck getting a machine to boot from a CDROM attached to a PCI controller. And as slow as CDROMs are, I've never bothered since they aren't bottlenecked by ATA33 controllers.
A lot of times when you first start out on a project you think, This is never going to be finished. But then it is, and you think, Wow, it wasn't even worth it. - Jack Handey
Reply 2 of 25, by Sphere478
Repo Man11 wrote on 2021-01-23, 03:36:
I’m stuck as the only ide cable I have is a 80 conductor and I don’t want to break the pin on the motherboard and the one on the cable isn’t removable
Reply 3 of 25, by Repo Man11
Sphere478 wrote on 2021-01-23, 04:10:
With some careful effort you should be able to drill out the pin hole in the cable's connector. I've done it by just pressing the cable in extra hard ( I wasn't paying close attention, and didn't realize it had a blocked pin hole!). I don't recommend trying that on a motherboard you care about.
Reply 4 of 25, by Repo Man11
You could try this: https://www.youtube.com/watch?v=7_GEsE2_j4Y
I would be surprised if a motherboard that old could boot from USB though.
Reply 5 of 25, by texterted
Heat up a safety pin with a flame.
Cheers
Ted
98se/W2K :- Asus A8v Dlx. A-64 3500+, 512 mb ddr, Radeon 9800 Pro, SB Live.
XP Pro:- Asus P5 Q SE Plus, C2D E8400, 4 Gig DDR2, Radeon HD4870, SB Audigy 2ZS.
Reply 6 of 25, by Repo Man11
texterted wrote on 2021-01-23, 04:22:
Yep. Looks like this guy did it with a corn on the cob holder (skip to the five minute mark). https://www.youtube.com/watch?v=3J9v2wn9MsA
Reply 7 of 25, by darry
Repo Man11 wrote on 2021-01-23, 04:40:
My instruments of choice are a metal paper clip and lighter . It also lets me pretend that Clippy is going through a trial by fire . 😉
Reply 8 of 25, by Repo Man11
I like this video where Clippy gets his revenge. https://www.youtube.com/watch?v=b4taIpALfAo
Reply 10 of 25, by Sphere478
Repo Man11 wrote on 2021-01-23, 04:48:
haha that's so cool!
okay so I did the pin trick as suggested and I got it plugged in and detected
buuuuttt.... I think the cd drive is defective because it sounds like a floppy drive and no change still won't boot and I made sure it was set to boot to the drive
I tried a boot loader cd that I still had from ages ago and a windows 95 cd (is that bootable?) in any case it isn't booting I think the drive is dead
I also don't have usb booting or any kind of floppy option as my only drive works in the computer I'm trying to make work an no others and none of my floppys are boot floppys
my best option I think is to make a hard drive that can boot and put it in the computer
and the fun part I don't have any ide hard drives I will soon have a ide to sata adapter but not yet
the scsi boot option in the bios is what I choose for add in cards right? cause I need to get windows setup on a hard drive and boot it from the sata card
Reply 11 of 25, by Sphere478
okay guys I figured it out
but I need help
I need a hard drive image of a drive right after the setup files were copied but setup not completed i can use macrium reflect to restore it to a hard drive on my modern computer and transplant it into my retro rig
Reply 12 of 25, by darry
I am having a bit of trouble following exactly what you want to do .
a) What OS are you trying to install ?
b) Why don't you try booting the bootable CD with the CD-ROM connected to the integrated IDE controller ? Is it because the motherboard BIOS does not support this (you did not specify what board you have) .
c) Alternatively, are you able to temporarily connect the hard temporarily to a modern PC ? If you can, you might be able to copy your OS installation files to that hard disk and possibly even make the hard disk bootable using a virtual machine .
d) Do you have a floppy drive and a bootable DOS floppy disk or the means to make one?
Reply 13 of 25, by Warlord
i don't get it. You are using a sata drive correct? hook it up to another computer, and make a primary partition on it and format it fat32. Then go search the internet for a program called BOOTICE
In bootice process the MBR so its nt 5x 6x Then process the PBR and make it MSDOS. Copy command.com, msdos.sys and io.sys to the drive, along with the contents of a 98 boot disk.
Make a folder on the drive called 98 and copy the entire contents of the 98 or 95 install cd.
move the drive to the computer and after it boots to command change directory to 98 and run setup.exe from there.
Reply 14 of 25, by Sphere478
Warlord wrote on 2021-01-23, 06:54:
i don't get it. You are using a sata drive correct? hook it up to another computer, and make a primary partition on it and for […]
I’m not sure, but I think this is exactly what I needed to know.
I used to do stuff like this 15 years ago but now I’m super rusty and have almost none of my old disks, cables, drives etc.
I’m going to try what you suggested thank you so much!
Reply 15 of 25, by Sphere478
darry wrote on 2021-01-23, 06:40:
I am having a bit of trouble following exactly what you want to do . […]
No floppy is not an option I have a floppy and a drive but this computer is the only one I have that it works on so since none of them are boot disks ai can’t make one on a computer that won’t boot 🤣
At this point any os would be an improvement.
But I think 98 is a good starting point
Booting to the cd is exactly what I tried after getting the cable to fit it but I have discovered that the cd drive appears to be bad. It sounds like a floppy drive and no disk I put in will boot. But it does detect
Yes making the hard drive bootable on a modern pc is my plan atm. I didn’t know how until that last reply, gonna try now.
Reply 16 of 25, by Sphere478
okay, I tried this first on a 60gb ocz ssd
it froze the promise tx4 300 on the detecting screen so I performed the same steps on a 1tb hdd and nothing, it's like the bios isn't even trying to boot to the sata card
i have it set to boot to scsi in bios
any ideas?
the bios is detecting the micro drive on the adapter so at least that's working. too bad I have no way to load these files and bootice as it doesn't fit in my card reader 🤣 (too fat)
in the mail soon I should be getting a ide to sata adapter I can try and see if the onboard ide can pick up my 120 or 60gb ssd but everything else I have is going to be past the 128gb limit of the bios in fact this bios I don't believe is patched even that high I think it still has the 32gb bug as I haven't been able to boot to load the new bios yet
Reply 17 of 25, by Warlord
I wouldn't of thought about trying the 1tb drive thats never going to work and it isnt compatible, with that card. The 60gb drive should work so you have some other kind of unrelated problem there. You do realize you don't have to max out the partition. You can create smaller partitions like only 8gb in size.
Reply 18 of 25, by Sphere478
Warlord wrote on 2021-01-24, 00:37:
The 1tb drive dowsn’t work with the tx4 300?
On one of the attempts I used a 4gb fat partition.
My friend hooked me up with some different cd drives. And a bunch of windows disks and live cds.
Gonna try round two
Also I now have a usb to compact flash reader that I can try to make the microdrive work
I’m feeling optimistic! :p
Reply 19 of 25, by Repo Man11
One way to be sure you have a bootable CD of Win98 is to download one. "Important: Only the OEM Full version is bootable. LINK REMOVED
And here's a nice step by step if you cannot remember (or never knew) the steps for copying the Win98 files to your hard drive and installing it that way. http://www.windowsreinstall.com/win98/install … dexfullpage.htm
