Open Source PC104 Soundcard
Reply 20 of 25, by CarbonLTM
If I only want the output of the headphone jack, do I just solder the resistor/capacitor near the headphone jack and chip?
Reply 22 of 25, by rasteri
CarbonLTM wrote on 2022-12-23, 02:25:
You can skip the resistors and capacitors for the joystick port if you like but most other components are necessary.
Sphere478 wrote on 2022-12-23, 02:50:
Did any of the optimized re spins get done?
I did hear from someone who made an optimized version with the intention to sell them, but he was having trouble getting them working. As he refused to open-source it I refused to help (since he was still using my footprints/schematic etc, rather unfair).
Reply 23 of 25, by Sphere478
Ah, well if someone with soundcard design experience wants to help me I would be willing to put in the time on the drafting. Just give me some idea what design rules/methods are important and I can draft it! 😀
I’m on kicad 6.0
My re spin would be public domain. Full open source. But would credit origional author on silk. 😀
Sphere's PCB projects.
Reply 24 of 25, by RayeR
I finally got a nice small PC/104 MB with AMD Elan 520 (a low-power 486 on steroids @133MHz). PCB marking says "Dr. Berghaus Gmbh" which I couldn't find much about but it seems to be very similar to Kontron 520 (well known industrial PC manufacturer with good support) where full manual with pinouts is available. So I made a simple wire adapter for CRT and KBD and it booted. Then I need some 44 pin 2mm pitch IDE cable.
...and of course the soundcard so I already got PCBs from JLC and started the assembly. I used CS4236B-KQ that I had spare (soldered off some old MB with oboard sound) instead of 4237 but it should be compatible. Now I'm waiting for the xtal, 16.9344MHz is pretty weird f so don't have any.
Reply 25 of 25, by ahmadexp
Hello Rastri,
I was wondering, maybe adding the MT32-Pi based on RPi zero to the card would be helpful (40 pin, like the one on the Tinyllama 2 with the DAC board).
Thank you for your awesome project
