Gravis Ultrasound Ram
Reply 20 of 21, by AppleSauce
jheronimus wrote on 2021-09-10, 08:42:
AppleSauce wrote on 2021-09-10, 08:41:
Uhhh just one other thing , I'm planning on using it alongside a sound blaster pro 2.0 , what jumper settings should I give it so it wont conflict?
the sbbpro is using the default A220 I5 D1 T3
I'm generally just using 240/7/7/7/7 for all my GUS cards. Using identical IRQ and DMA sets the card in half-duplex mode (meaning the card can't play and record at the same time), which is perfectly fine for games and demos.
Alright , cheers for the settings , ill give it a whack.
And yeah it's interesting seeing to what degree newer iterations of hardware are backwards compatible with older versions.
Reply 21 of 21, by AppleSauce
Hokay it seems to be mostly working
Epic pinball , jazz jackrabbit , doom and duke nukem 3D all work fine.
2 problems though ,
I get this error at the end of the setup for the sound blaster and mt32 emulation.
The attachment 20210910_204211.jpg is no longer available
and shadow warrior gives me a black screen on startup.
