Gravis Ultrasound Ram
First post, by AppleSauce
Hi to anyone whos willing to help me out , I just got my hands on a Primax Soundstorm and I'm aware that you can upgrade the memory to 1mb.
I've got some SOJ chips on my S3 Trio card that I'm considering adding to the primax , so basically I just wanted to know if the chips would be compatible and not fry the card or anything.
Thanks in advance.
The attachment 20210910_160159.jpg is no longer available
Reply 1 of 21, by Eep386
If the Trio is using EDO ram, that will probably not work with your GUS-alike.
You'll probably want 256Kx16 fast page SOJs. Not sure about the speed but 70ns would be my guess.
Reply 2 of 21, by AppleSauce
Eep386 wrote on 2021-09-10, 06:26:
Do you have any recommendations on specific ram model numbers to look for?
Reply 3 of 21, by Eep386
NEC 42S4260, Hynix/Hyundai HY514260B
Reply 4 of 21, by AppleSauce
Eep386 wrote on 2021-09-10, 06:39:
Okay ill keep that in mind and how about this ram?
The attachment s-l1600 (53).jpg is no longer available
Reply 5 of 21, by kixs
I think EDO will work with Primax Soundstorm card - at least I had it in mine.
Visit my AmiBay items for sale (updated: 2025-10-29). I also take requests 😉
Reply 6 of 21, by Eep386
I seriously doubt that EDO will work with a NOS ultrasound IC from 1994. The RAM that's installed on this card is FPM, after looking up the datasheet for it:
https://www.karlsitretro.com/primax-soundstorm-wave-review/
The RAM in question: https://www.datasheet.live/index.php?title=Sp … 514260ALJ-8.pdf
Reply 8 of 21, by Eep386
Huh. Do the samples play back without corruption or glitches?
I still find it difficult to believe that a 1994 sound card would work properly with EDO, when so many 486 motherboards wouldn't.
Reply 10 of 21, by AppleSauce
Although looking at data sheets , it does seem like EDO differs a tiny bit from FPM , it seems the manual also recommends FPM.
So maybe ill grab a HYB514171BJ chip from ebay and play it safe.
Reply 11 of 21, by kixs
Eep386 wrote on 2021-09-10, 07:32:
I had FPM and EDO. Tested with both and there were no differences noticeable.
Reply 13 of 21, by kixs
It is faster but it has nothing to do with "speed". EDO should be compatible with FPM. But in practice there are many incompatibilities with older motherboards and some video cards.
Reply 14 of 21, by AppleSauce
Okay so in a nutshell then , the EDO ram (VG264265BJ) specifically from my S3 should work with the Primax Soundstorm M16C I have , bug free right?
Reply 16 of 21, by AppleSauce
Ok great , ill let you know how it goes.
Reply 17 of 21, by AppleSauce
Uhhh just one other thing , I'm planning on using it alongside a sound blaster pro 2.0 , what jumper settings should I give it so it wont conflict?
the sbbpro is using the default A220 I5 D1 T3
Reply 18 of 21, by jheronimus
That's actually an interesting topic. I've been using EDO SOJ chips on pretty much everything in the last five years, including various S3 cards, Primax Soundstorm Wave and GUS MAX, a bunch of VLB cards from Ark Logic, Matrox, Cirrus Logic, etc. So yeah, I can confirm that GUS cards don't have issues with EDO chips, and I've been using them with a bunch of demos and ProPatches Lite.
The ONLY card that seemed to give me issues with EDO RAM (corrupted image, etc) was Tseng ET4000/W32P for VLB.
MR BIOS catalog
Unicore catalog
Reply 19 of 21, by jheronimus
AppleSauce wrote on 2021-09-10, 08:41:
I'm generally just using 240/7/7/7/7 for all my GUS cards. Using identical IRQ and DMA sets the card in half-duplex mode (meaning the card can't play and record at the same time), which is perfectly fine for games and demos.
MR BIOS catalog
Unicore catalog
