ISA PCMCIA cards for DOS?
Reply 20 of 25, by weedeewee
DerBaum wrote on 2024-01-15, 15:16:
Is there a special reason you want the pcmcia layer in between IDE and a CF card? You can use CF cards as Harddrives with just a […]
jnemo2004 wrote on 2024-01-15, 14:53:
I want to use this adapter card (ISA to PCMCIA) with an adapter PCMCIA to Compact Flash.
You can use CF cards as Harddrives with just a small passive 10 euro adapter.
There are even brackets for the rear of the pc already made for accepting cf cards and a direct ide connection...
hotswappable.
Do not ask Why !
Reply 21 of 25, by Tempus
I use a SCM Swapbox. Needs drivers for DOS and takes a bit of memory. It also requires B000-BFFF excluded with emm386.exe. Supports up to 32MB ATA.
    1.45 MiB
    1.79 MiB
Akumajō Dracula: Belmont's Theme Roland MT-32 | Yamaha YM2151
Reply 22 of 25, by jnemo2004
Thank you very much to all for the good ideas and support.
I want to use this adapter card just for only one reason: Old motherboards like 286, 386 and 486 (maybe not all of them), they have not PCI sockets, they only have ISA sockets and this adapter card could be a good solution for boot or maybe only for storage.
Thank you very much.
