BIOS needed for Octek VL-COMBO
Reply 21 of 25, by ViTi95
That is some impressive performance 😮. I'm waiting to receive some eeprom to test XTide. It is required to use the DOS driver with XTide? Or XTide enables all the good stuff?
https://www.youtube.com/@viti95
Reply 22 of 25, by aitotat
DOS driver must not be used with XTIDE Universal BIOS since the driver would reprogram the speeds and take over the disk I/O.
My youtube channel
Reply 23 of 25, by hasat
There are dumps from my card-Revision 2.1 - Promise BIOS is not on C800 address, but on D800 and it's size is 8k, according to what I found with Microsoft Diagnostics program from DOS 6.22. It's also included in ZIP archive.
Also found something interesting - Catalog of Octek products with specifications and jumper settings from August 1998 in Windows HLP format. Run included octeknet.exe in your retro machine (probably max with WinXP, in my retro laptop with 64bit Windows 7 refuses to run). In discontinued products are two versions of our Octek VL-COMBO card.
Reply 24 of 25, by ViTi95
Tested the XTide ROM (386 8kb version) with the Promise controller, it went from 5.5 Mb/s using the DOS driver to 6.6 Mb/s without the driver. Not bad, I guess the CF is on the limit of it's performance.
Reply 25 of 25, by soggi
hasat wrote on 2021-12-18, 10:46:
Great find!
BTW you can always use right-click -> 7-Zip -> open, if you have 7-Zip installed - this should also work on Win x64.
kind regards
soggi
Vintage BIOSes, firmware, drivers, tools, manuals and (3dfx) game patches -> soggi's BIOS & Firmware Page
soggi.org on Twitter - inactive at the moment
