Reply 20 of 25, by stubbertville
Horun wrote on 2022-02-27, 23:55:I found it: is CJE-0478 at the bottom of the FCC list you show and points to the same model 871731 00 as on the white sticker. D […]
Jo22 wrote on 2022-02-26, 16:48:^Hi. The manufacturer could have been US Robotics. Model type perhaps is "CJE-0283"? The Telepath seems to be an early modem, pe […]
The Telepath seems to be an early modem, perhaps with 28800 bps or 32600 bps or so.
The Telepath for Windows X2 seems to be an WinModem with 56k from ca. 1998..
- I've found some information, but it was scattered around.I found it: is CJE-0478 at the bottom of the FCC list you show and points to the same model 871731 00 as on the white sticker.
Did not help much as they currently do not have any of the older drivers at the USR website 😒
I think you are correct and is a very early WInmodem version....stubbertville wrote on 2022-02-27, 18:10:So I’m having an issue where I go to launch the installer it just won’t load
Odd. My Win 9x machine is in storage so cannot test it and my XP box complained "not for this windows version" and sort of locked up 🤣
Curious what version of Winows 95 are you running ??
Ah, crap
