Reply 20 of 23, by rarcher
So some updates on this PC:
As mentioned I got the memory upgraded to 128mb of RAM
The HDD i upgraded from a 250 some mb to a 2gb that I bought as new old stock/never used for a local seller here where I live in exchange for the 250mb drive I only had to spend 10 bucks on it!
I got Dos 6.22 with Windows 3.11 for workgroups installed now
I've got the actual drivers for the onboard graphics installed and auto loading in dos/windows thanks David!
Ive got the y2k bios update for said pc dont too Again thanks David!
I upgraded the ISA sound blaster (seems to be a clone of maybe the soundblaster vibra16 series that had the built in telephone options too), to an official sound blaster awe64 gold it has currently the 4mb memory but I could up that in time to 28mb if i can get said chips for now it more then suits my needs
For now I got a knock off brand isa ethernet card from realtek or something in the computer that had driver support that I got from the above local seller for the hdd I got (only a 1.50! 🤣) I plan to upgrade this later with likely a 3com or something once I settle on a price and such.
Ive also done some dos/win 3.11 tweaks for config.sys and autoexec.bat to get more performance out of things on loading, i also ran memmaker too to get more free memory just for kicks.
Still on my list to do is find what L2 cache chip i need, I know its a write-back cache chip but i cant find any parts matching the parts numbers from ibm, does it HAVE to be from ibm? or could someone suggest another search term to try that would still let me upgrade to 256kb?
Also on my to do list is get another 1mb of video dram (I think it comes out to be 2x512kb chips) again part numbers I got but am not finding anything specific for ibm, again do they got to be from ibm or can I use an equilvant and if so what types do I need to look for?
Sadly for both of these my knowledge of PCs in hardware didn't really kick off in full until the late 90s-early 2ks by which point such things were mostly a thing of the past. So any insight or suggestions to fill in my knowledge would be appreciated.
Also on my radar is upgrading the cpu to an AMD 5x86 133MHz cpu like from here https://www.ebay.com/itm/333700483164 though ideally i'd like to get it from a US seller if I can. The board supports the 3.3v out of the gate so i just need to get the jumpers set once i get said cpu, also need to get an appropriate heatsink/fan any suggestions on that?
