First post, by rarcher
So long time lurker of these forums over many years, and as I am going to be turning 39 this August I guess this purchase maybe means I am hitting my mid-life crisis? Anyhow I got an itch to 'relive' my youth in computers and wanted to buy the same computer as I had back in 1993. Which was a Packard Bell 486/DX2 pc with dos/windows 3.1. I cant recall the exact model but it was a full 'multimedia' enhanced option. Anyhow after some digging I found one like it but while it had a video and such showing it all working the seller on ebay wanted 550 some dollars for it. A bit too high for my taste. So I figured ok let's get a pc of that era with the same or better hardware.
The restrictions though were it had to have:
  • Must have a 486/DX2 cpu with 66mhz cpu and 33mhz or faster bus
  • Must have at least 1mb or higher video capacity either on board or by a half decent era appropriate video card
  • Must have a working at the time of purcahse 1.44mb floppy and 2x or faster working cdrom drive
  • Must have some kind of half decent sound card option either on board or by card
  • Have memory options to support up to least 64mb
  • Must have at least a 200+mb sized HDD and a bios capable of up to 2gb (last part here is optional but really desired)
  • Be a machine that originally came with Dos 6.22 and Windows 3.1/3.11
  • I could not spend more then 300 dollars for all the above must haves, including any extra purchases in the near future (memory, cache chips, etc)
With this all in mind I was SO overjoyed to find an ebay listing by a company out of New York called Sunnking. They had this beauty:
The attachment IBM-1.jpg is no longer available
Which just arrived today after ordering it on Monday. The original listing was $300 + tax/$26 shipping. I contacted the company directly and got to talking to the tech and lister for the computer. After talking with them for 45 minutes on what I wanted to do with it (mostly display and maybe a little gaming), they dropped the price to 150 dollars including tax/shipping! I jumped on it on the spot and was SO happy to come way in under my budget.
The system as it arrived has a 486/DX2 66mhz cpu , 4mb of ram (I already expanded it to 128mb from buying the sticks separately), 128kb L2 cache which I'd like to expand to 256kb if I can figure out what exactly chips are needed, and 1mb on board video memory using a S3-864 chipset. Again i'd like to up that to 2mb so any insight onto where or what specific dram chips i need to get would be awesome! It is preinstalled with a 270mb HDD with DOS 6.22. The internal case is a lightly dusty but nothing major, coloring on the case is minimal from age which i love. Only thing I noticed so far i'll need to do to get a VGA monitor I got working with it is pull out one of the second row pins to make it work with the older VGA type it has.
Future plans:
  • Upgrade to 128mb (done!)
  • Install a 256kb L2 Cache
  • Install another 1mb of dram for the onboard video OR buy a dedicated video card of better quality without going too expensive
  • Install a 2gb HDD
  • Upgrade the bios if needed for Y2k and other support/stability (must investigate this!)
  • Maybe put in a better sound card with higher performance/quality then the one in there at present (need to ID current card)
  • Install an ethernet card
  • Install Windows 3.11 with networking support to access in home file server for easier file transfers
  • Look at pricing and ability to install a higher 486/586 type CPU for faster speed provided price of part isnt too expensive
I'll get some more pictures posted up once I can, for now I hope I posted this in the right spot (I think I did?) but if not as a newbie I hope the mods wont get too angry on me 🤣
Reply 1 of 23, by Meatball
Wow... that is one, good clean looking machine!
Reply 2 of 23, by Jura Tastatura
Nice story and nice 486. I'm in a bit same bandwagon with you considering age and motivation but decided to go with P1 instead.
After talking to them for 45 mins no wonder they put the price down, just to let them go. Can't imagine being on work and some dude explaining me his hobbies for almost an hour. I'd give you anything just to leave me free. 😅😅😅
Edit: I'm lying, I've been there. 🤦‍♂️😁
Reply 3 of 23, by jakethompson1
Nice. I am a few years younger, but used the 486SX/25 model of the same machine as a dialup NAT gateway in the early 2000s.
128MB is more than the cacheable range, even if you upgrade the cache to 256K. You may or may not care about this, depending on what you want to do with the system. You can run CACHECHK to see the boundary where memory stops being cached.
The onboard video on these is VLB, while if I remember right the only expansion slots on the riser are ISA, so you definitely want to stay with the onboard video.
You can't go wrong with a 3c509 (3Com EtherLink III) ethernet card.
CPU upgrade is made more complicated if the board doesn't already have support for 3.3V CPUs, and the board won't take maximum advantage of the upgraded CPU if it lacks support for a write-back internal cache.
Reply 4 of 23, by jakethompson1
By the way, Unicomp still offers beige model M ("Classic") keyboards that are derived from the keyboard design that would have shipped with this machine and made on the same machinery (spinoff from IBM/Lexmark).
Or you could go hunting down a used model M.
Reply 5 of 23, by Joseph_Joestar
rarcher wrote on 2022-07-14, 17:11:
If you're primarily going to use that system for DOS gaming, you might want lower the RAM amount. Some DOS games (e.g. Aladdin) will refuse to run if more than 32 MB of RAM is installed.
Awesome rig though!
Reply 6 of 23, by darry
My first 486 was 486SX25 Valuepoint mode (
got it used). Chassis was a 6384 variant .
It had an onboard Tseng ET4000, which was way better than the TVGA8900B in my previous 386DX25, even though both intefaced through ISA.
At the time (1994ish), IBM had a public BBS in Montreal where I could get updated drivers.
I had loads of fun, hope you do too!
Reply 7 of 23, by timw4mail
If the board supports a 40MHz bus, AMD (at least) had a 5V DX2 80 cpu. Beyond that, you'd need 3V support or an overdrive processor.
If you look at the cpu in there, it's likely an IBM Blue Lightning DX2 (Cyrix design).
jakethompson1 wrote on 2022-07-14, 17:33:
I've seen old Model Ms going for the same price as new Unicomp boards, for what it's worth.
Reply 8 of 23, by darry
I would go with Unicomp. You have to be really lucky these days to to get a vintage used model M at a price that, IMHO, is not eye-watering.
Reply 9 of 23, by darry
timw4mail wrote on 2022-07-14, 17:42:
If the board supports a 40MHz bus, AMD (at least) had a 5V DX2 80 cpu. Beyond that, you'd need 3V support or an overdrive proces […]
I have seen the used ones going for even more.
Reply 10 of 23, by rarcher
jakethompson1 wrote on 2022-07-14, 17:28:
Nice. I am a few years younger, but used the 486SX/25 model of the same machine as a dialup NAT gateway in the early 2000s. […]
yeah i figured that i just wantrd it more cause i could do so then anything
Reply 11 of 23, by rarcher
Joseph_Joestar wrote on 2022-07-14, 17:38:
Awesome rig though!
tbh while i mention gaming itll probably more likely just be a display piece 🤣
Reply 12 of 23, by maxtherabbit
Are they still built to the same quality? That tooling must be pretty long in the tooth by now
Reply 13 of 23, by davidrg
I think they try to build to similar quality as the later Lexmark ones (not as heavy as the older Ms, no detachable cable, etc). I've never seen a Unicomp one in person but I'd heard a few years ago quality was a bit worse probably due to the age of the tooling. But it looks like they've refreshed the tooling recently as the reviews of the new mini M seem good. They've got a "New" model M too. So perhaps quality is no longer a problem.
As for the PS/ValuePoint itself, some links that may be useful: PS/ValuePoint drivers (or here). s61g1423.pdf is the Hardware Maintenance Manual and there is a full index of all the drivers and other files in that directory below:
Index of PS/ValuePoint files
IBM PS/ValuePoint Files
/pub/pccbbs/valuepnt
540to528.exe 171625 12-15-94 64XX 540 H-disk fix for Novell Server
6381fxx.exe 226681 10-29-93 6381 FXX Power Management Disk
6381wg31.zip 9033 05-25-94 Replaces SYSTEM.INI in Win for WrkGroup
atios232.exe 678200 07-26-94 32-bit video driver for OS/2 2.1 on P60/D
atiset01.exe 1061236 07-26-94 ATI/PCI Mach 32 video drivers for OS/2
clock00.exe 35920 06-02-93 Date/Time error fix for OS/2 1.3 on VP
clock01.sys 3686 10-14-93 VP2 OS/2 2.00.1 Date & Time
d2uf4spl.pdf 444257 08-11-98 ValuePoint HMM Supplement April, 1994
dcodeati.exe 893377 01-11-95 OS/2 ATI-TR fix for P60/D
doscdati.exe 21897 01-04-95 Device driver for TR, ATI & Novell P60D
dosdcati.exe 21783 01-11-95 Fix for Video Hangs with Net. Cards and > 16
colors on network
dosports.exe 1792 02-23-94 Initialize COM3 or COM4 on ISA Systems
dossmc.zip 4071 03-24-94 Fix - 6381 or P60/D serial port hangs-DOS
dsaafix.exe 123391 04-02-96 Code fix for IDE 120, 240, 340MB
fastcur.com 19 12-17-94 Fast cursor for 6381
hddpio.exe 6731 05-18-94 Makes 170&245M HD on 6384 P60D a PIO
ibmatid1.exe 950635 01-27-95 ATI Mach32 setup & video drivers 2.3 P60D #1
ibmatid2.exe 1095131 08-16-94 ATI Mach32 setup & video driver 2.3 P60D #2
ibmkbfix.exe 16766 09-15-93 Fix VP keyboard lockup in Windows
ide311.exe 22324 01-02-93 updated disk driver for netware 3.11
idecdfix.sys 12926 12-22-94 IDE CDROM fix for 6387
l6jt68a.exe 428589 06-21-95 Flash BIOS update for ValuePoint 2 v68
l6jt70a.exe 429023 05-06-97 Flash BIOS update diskette VP2 v70
l6jt70a.new 153 06-13-97 Readme for L6JT70A.EXE
l6jt70a.txt 4454 06-13-97 Readme for L6JT70A.EXE
l8jt43a.exe 568599 03-10-95 Flash BIOS update for 6381 v.43
l8jt44a.exe 569232 01-19-96 Flash BIOS update for 6381 v44
l8jt51a.exe 572766 01-05-98 Flash BIOS v51 6381
l8jt52a.exe 569361 01-19-98 Flash BIOS update v52a 6381
l8jt52a.txt 640 01-19-98 Readme for L8JT52A.EXE
ldjt67a.exe 683785 03-01-95 Flash BIOS update 64xx v67
ldjt70a.exe 683887 05-06-95 Flash BIOS update 64xx v70
ldjt80a.exe 631137 01-05-98 Flash BIOS v80A 6472, 6482, 6492, 6484, 6494
ldjt80a.txt 6361 01-05-98 Readme for LDJT80A
ldjt81a.exe 686465 09-10-99 Flash BIOS update diskette v81a 64xx
ldjt81a.txt 6513 09-10-99 Readme file for LDJT81A.EXE
lformat.exe 144660 01-16-95 low-level format utility for 6384 P60/D
ntfloppy.zip 13802 02-15-94 Patch to load Windows NT from diskette
6384-18x, 6384-19x
os2drvp.exe 918273 02-26-93 OS/2 2.00.1 vid recovery dsk - 486 VP1
p60dgs.exe 626719 06-03-94 Diagnostics for P-60D v 4.0
p60nt.exe 147472 03-15-94 Fix for P60D w/527MB hardfile that can't load
WIN NT 3.1
parityfx.exe 768 07-07-93 Fix for Parity Errors on NEW VP's
preinst1.exe 497344 12-29-92 OS/2 Pre-Install Utility Disk (1 of 3)
preinst2.exe 545752 06-23-94 OS/2 - Pre-install utility disk 2 of 3
preinst3.exe 473647 12-30-92 OS/2 Preinstall Utility Disk (3 of 3)
refresh.exe 33756 02-17-95 Refresh Rate Utility for VP Systems
s3-16m.exe 1358907 12-13-94 OS/2 2.1 S3 video drivers
s3132x25.com 6 01-28-94 132 Column mode for S3 Valuepoints.
s3132x43.com 6 01-27-94 132 col mode for S3 VP's
s3cds22.exe 377277 06-15-95 S3 86C805 v2.20 DOS/Utilities
s3cos1.exe 1357586 06-15-95 S3 86C805 OS/2 2.x High Res
s3cwn24.exe 567357 06-15-95 S3 86C805 v2.4B8 Windows
s3dos20.exe 348507 07-23-93 DOS and CAD S3 drivers ver 2.0
Show last 51 lines
s3dos220.exe   388231 12-16-93  S3 DOS and CAD drivers Ver2.2
s61g1423.pdf 1248701 05-18-98 Valuepoint Hardware Maintenance Manual -
September 1993
shadow.exe 6921 05-12-93 Enable/Disable ROM Shadow for NEW VPs
si25dosb.exe 639877 10-13-93 6381 425sx DOS Video Driver Update
si25winb.exe 689013 10-14-93 6381 (Fxx) Windows 3.1 updated SVGA driver
si33dosb.exe 427010 10-13-93 6381 433dx DOS Video Driver Update
si33winb.exe 611643 10-13-93 6381 433dx Windows Video Driver Update
sirq.exe 7759 05-03-94 Fixes for VP Ethernet Cards in 6381 for IRQ's
other than 11
slwdwn.zip 810 02-24-94 Slow down utility for fast CPU's
vp1diags.exe 145208 05-13-93 Diag diskette for orig. 6384 VP1
vp2copro.zip 61010 09-28-94 VP2 Math-coprocessor fix DOS/Win Req/VP2FL65A
vp2diags.exe 181185 01-13-94 PS/VP Diagnostics (Type 2) 1.2 425SX, 433SX,
433DX, 466DX2
vp2fl53a.exe 428380 09-20-94 Flash bios upgrade for ValuePoint 2 v53
vp2fl54a.exe 428442 09-20-94 Flash bios upgrade for ValuePoint 2 v54
vp2fl58a.exe 428382 09-20-94 Flash bios upgrade for ValuePoint 2 v58
vp2fl62a.exe 428425 09-20-94 Flash bios upgrade for ValuePoint 2 v62
vp2fl65a.exe 428441 09-23-94 Flash BIOS update for ValuePoint 2 v65
vp2fl66a.exe 429333 10-26-94 Fix for Danish Language Problem
vp2upmem.exe 156672 04-13-94 Flash For 192K Upper Memory on VP2.
vp386svg.exe 866834 12-22-93 PS/VP 386 SVGA Drivers/Utilities
vp486svg.exe 339833 11-22-94 PS/VP 486 SVGA Drivers/utilities
vpclock.sys 3712 06-29-93 Old clock01.sys for 6384 VP/ OS2 2.00.1
vpp60fl4.exe 721307 09-20-94 Flash Bios update for P60/D;flicker problems
vpp60fl6.exe 722824 09-20-94 Flash Bios update for P60/D v1.00.06
vppdiags.exe 352413 07-07-94 Diagnostics for 64XX ValuePoint
vppfl44a.exe 623043 09-20-94 Flash BIOS upgrade 64XX v44
vppfl53a.exe 428310 09-14-94 Flash BIOS upgrade 64XX v53
vppfl54a.exe 429233 12-22-94 Flash BIOS update 64xx v54
vppfl56a.exe 626543 09-20-94 Flash BIOS upgrade 64XX v56
vppfl58a.exe 627692 09-19-94 Flash BIOS upgrade 64XX v58
vppfl61a.exe 654404 12-10-94 Flash BIOS upgrade 64XX v61
vppfl63a.exe 683707 12-17-94 Flash BIOS update 64xx v63
vppfl64a.exe 684754 12-21-94 Flash BIOS update 64xx v64
vppfl65a.exe 683871 01-20-95 Flash BIOS update 64xx v65
vppnp10.exe 82452 03-08-95 64xx Plug & Play Utility
vpqna.zip 12967 03-13-93 ValuePoint Common Q&A Excellent Info!!
vpsidia2.exe 175302 01-05-94 Diagnostics Diskette for 6381SX/SI VP v1.01
vpsidiag.exe 175302 06-03-94 Diagnostics diskette for 6381 VP v1.01
vpsifl39.exe 569061 09-20-94 Flash BIOS update for 6381 v39
vpsifl40.exe 568677 09-20-94 Flash BIOS update for 6381 v40
vpsifl42.exe 569147 09-20-94 Flash BIOS update for 6381 v42
vpwinbhf.exe 27390 01-12-95 WIN 32 bit disk access for > 527 meg IDE HD
windr386.exe 753476 12-22-92 Windows 3.1 drivers for 386 PS/VP
windr486.exe 1132886 10-19-93 Windows driver for et4000 -vp1
winsmc.zip 6788 03-24-94 Fix - 6381 or P60/D serial port hangs-Windows.
winwgsmc.zip 23162 06-09-94 Fix Problems in Windows for Workgroups 6381,
P60/D
zero_dma.zip 857 05-12-93 3rd party DMA Networking Card Fix
Reply 14 of 23, by timw4mail
davidrg wrote on 2022-07-14, 21:39:
I have a PS/2 variant of the "New" Model M. Other than the dark color scheme (Black case, silver keys), it looks and feels a lot more like an original Model M than Unicomp's previous models. I'm not sure if it's because it's a PS/2 version, but mine even has the traditional green leds instead of the blue leds that usually come with them.
Reply 15 of 23, by rarcher
Jura Tastatura wrote on 2022-07-14, 17:24:
Actually funnily enough the tech guy started it and kept it going 🤣. He likely at first was seeing if I was someone probably trying to make a quick buck scraping it for parts individually selling or to scrap for gold or something. But after I think he realized he didn't plan that he got more interested asking me like what games I played or planned to play, what I planned to do with it for upgrades etc 🤣 so really I feel the discount was more of being glad its going to a good home and going to get some useful loving and use.
Reply 16 of 23, by rarcher
colors on network
6384-18x, 6384-19x
WIN NT 3.1
Show last 51 lines
September 1993
other than 11
433DX, 466DX2
P60/D
Hey thanks David! I netted the bios update I needed off here for y2k and got the S3 drivers for dos I was struggling to find. Thanks for the help! I'm still confused though exactly dram chip for another 1mb of video memory, and more cache chips i need to get. I googled the parts numbers but I was only finding pdfs listing them, not the chips themselves. Which is sad 🙁
Reply 17 of 23, by rarcher
Well from googling around on this exact model it seems my best bet without going stupidly crazy on price for a Cyrix is the AMD 5x86-100 or the same but 133. I've seen a few of these both on ebay atm for 30-60 bucks so probably will look into those at some point once I find a motherboard jumper settings to make it happen.
Reply 18 of 23, by rarcher
I'm actually using just a more modern ps/2 keyboard/mouse those being era specific arent a big deal for me same for the monitor (i'm using a flatscreen LCD that works just fine at the 800x600 resolution atm) keeps the bulky crts from taking up my desk 🤣
Only real problem I've found actually after digging into it a bit more is the case is a bit worn/flexed from age. So when you remove the top cover to access the inside and go to put it back on its almost impossible to line it up on the rails to get a proper secure latch, so its a bit of an annoyance there but I can manage 🤣
Reply 19 of 23, by pbagain
My story is pretty much the same . For a while I held on to my Packard Bell nostalgia (love the brand for all its glorious imperfection) and ended up buying multiple cheaper and more available (i.e. newer) Packard Bell systems, which didn't quite scratch my 486-era itch. Also time and money spent probably exceeded similar 550 ebay deals that I was looking at at that time. Anyway, no regrets. But your approach to switch brands seems to me entirely more practical. You did good, may it bring you lots of retro joy 😀
