Reply 20 of 45, by Putas
Spark wrote on 2024-03-02, 15:02:
I would have hoped the rage xl would look more like the voodoo.
It does.
Reply 21 of 45, by Kahenraz
Putas wrote on 2024-03-03, 04:38:
It does.
I can confirm that the Rage XL is excellent in Quake 1 and 2. It can also overclock with PowerStrip for smooth FPS in Quake 2 at 800x600 with the AGP variant and a fast processor.
Quake 3 will run, but it's very slow. It's definitely a Direct3D 5 and early OpenGL 1.1-class card. If you want DirectX 6 or higher, choose the Rage 128 instead.
I teased Return to Castle Wolfenstein, but it does not have a playable frame rate. Especially in outdoor areas. It was interesting to see that it would, though.
Unreal is barely playable as well. Again, Quake 3 and Unreal would be better suited for the next generation's Rage 128 and TNT2.
Reply 22 of 45, by leileilol
Quake3 should perform on the XL at least with textures down a couple notches. Quake3 was targeting Rage Pro with fallbacks so surely it'd be better than that baseline. RTCW's a bit of a CPU/memory hog though and a decent video card (i.e. Geforce2) can suffer there.
long live PCem
Reply 23 of 45, by BitWrangler
I have had American McGee's Alice running on an XL with the last minigl driver it was a minimum res low detail thing, but it ran 15-20fps.
Reply 24 of 45, by 386SX
The Rage Pro AGP was already "good enough" for most late 90 games and later ones, I can only imagine the XL to be better in most cases. But it was all about expectations and time correct low end configs. Nowdays I even consider the Rage IIC with late drivers to be good enough as long as resolution remains 400x300 and an higher end cpu was used.
Reply 25 of 45, by Kahenraz
386SX wrote on 2024-03-03, 06:42:
The Rage Pro AGP was already "good enough" for most late 90 games and later ones, I can only imagine the XL to be better in most cases. But it was all about expectations and time correct low end configs. Nowdays I even consider the Rage IIC with late drivers to be good enough as long as resolution remains 400x300.
This is my opinion as well. I'm trying to find a sweet spot for my own comfort. I like the strong OpenGL support and the ability to run Quake 1 and 2 at good frame rates. Everything else, including the XL enhancements, is a bonus.
Reply 26 of 45, by 386SX
Kahenraz wrote on 2024-03-03, 06:45:
This is my opinion as well. I'm trying to find a sweet spot for my own comfort. I like the strong OpenGL support and the ability to run Quake 1 and 2 at good frame rates. Everything else, including the XL enhancements is a bonus.
Also having the multimedia engine basically equal to the Rage128 makes it even more interesting (while sw compatibility with ATi chips and drivers may not be that easy). While I still don't have the XL it feel like I good option.
Reply 27 of 45, by 386SX
I wonder how the game Thief II, first level in the main hall of the house with the XL where shadows can be seen, render on it, because the Rage Pro while it can run that heavy game, has problems with the shadows basically fully dark, a problem that's not seen in the lower resolution rendering on the Rage IIC with same period late drivers.
Reply 28 of 45, by Kahenraz
Can you send me a save game and a screenshot of what to look for? I'm not familiar with the Thief games.
Reply 29 of 45, by 386SX
Kahenraz wrote on 2024-03-03, 07:12:
I don't have the machine running right now but in the first level even demo, there's very soon a big main hall with a big fire. It's the biggest house room and looking at the main house door from the inside you can see the pillars shadows which are really bad on the Rage Pro.
Reply 31 of 45, by 386SX
Kahenraz wrote on 2024-03-03, 07:32:
That's Thief 1 which I don't remember if had the same problem I think did not. The problem can be clearly seen in Thief 2 instead even at 640x480 it should be more visible, I imagine the enhanced game engine required more. I didn't find a tweak option to solve it. Even the Riva128 has an interesting result rendering it. The interesting thing is that the Rage IIC seems not suffering that, I wonder if that's because it may have render some DX6/7 features in sw instead of the Rage Pro maybe missing in hardware the features listed in the Rage Pro <> XL differences.
Anyway looking at the specifications on the improved Rage XL compared to the Rage Pro 3D engine, I imagine the game render good.
Reply 32 of 45, by Minutemanqvs
Just as a side note, I came across a video explaining that there are actually "new" Rage XL made with old salvaged chips. But they need to be modded to run on old mainboards (5V vs 3.3V PCI).
https://www.youtube.com/watch?v=Gbyv4wI0v0s
Searching a Nexgen Nx586 with FPU, PM me if you have one. I have some Athlon MP systems and cookies.
Reply 33 of 45, by 386SX
Minutemanqvs wrote on 2024-03-03, 16:17:
I bought one of those cards but didn't work not even on the 3,3v PCI boards. I've read of various random results in getting one perfectly working or with problems, I suppose the quality control may not exist as supposed to or chips installed (both ram and video chips) may be already used too much. Also the PCB layout is not as complex as the same cards using that chip for desktop mainboards and seems oriented to save most possible costs.
Reply 34 of 45, by auron
i don't think the original question has been quite fully explored yet. here is what the spec document says about the different rage pro versions:
The attachment rage pro.png is no longer available
so, the confusion starts with it referring to five different "packaging options" while only listing four, and i'm not sure of what use those IDs are, because they don't seem to be printed on the chips. can they at least be read out by a tool like pci.exe? the AGP chips are segmented by 1x/200mhz ramdac and 2x/230mhz ramdac, but these are still pin-compatible, so maybe the silicon is the same too? does "cost-sensitive" mean they were saving on PCB layers, passives or something for the lower-end parts? is any rage pro that doesn't say 2x or turbo definitely the 1x/200mhz variant? also interestingly they don't even bother listing the ramdac speed on the PCI version, at least in that section.
i wonder, did anyone ever try reflashing a "1x" card with a 2x BIOS?
Reply 35 of 45, by Kahenraz
Kahenraz wrote on 2024-03-02, 03:46:
Here are the same screenshots from the Rage XL
Can anyone with a Rage LT check to see if this chip also supports billinear filtering on transparent textures, like the Rage XL? I've heard that the LT is faster than the XL, but I don't want buy one if the texture filtering is the same as the Rage Pro, since I would never want to use it otherwise.
This is very easy to test when running the demo of Return to Castle Wolfenstein.
Reply 36 of 45, by Putas
Kahenraz wrote on 2025-02-06, 20:24:
Do you mean Rage LT Pro? Those produce same images as Rage Pro.
And who says they are faster?
Reply 37 of 45, by leileilol
All the text in RTCW is an alpha blend and I always hear how Rage drivers are responsible for dealing that part in software and you can't really have the 'turbo' name without compromising on quality somewhere....
long live PCem
Reply 38 of 45, by Kahenraz
I think my confusion came from here, where someone said that the Rage LT Pro PCI was faster than the Rage Pro Turbo PCI. I was searching for information on the Rage XL and got my wires crossed.
Also, yes, I meant the Rage LT Pro.
I'm curious how to stacks up against the Rage XL and if it has billinear texture filtering for transparent textures.
BigDaddyM wrote on 2020-11-20, 18:07:
Putas wrote on 2020-11-20, 15:11:
Never have I seen Rage Pro with a different core clock. Does that "Pro Turbo PCI" have EDO memory by any chance?
No, cards have SD or SG ram but Rage Pro Turbo PCI is slower than LT Rage Pro PCI, fillrate is this same but textures rendering is faster on LT Pro. AGP cards of Rage Pro Turbo and LT Pro have better fillrate than PCI cards.
Reply 39 of 45, by marxveix
Nexus GA has 16MB of WRAM already from 1997
It has ATi Rage Pro and FullHD resolution support
https://drivers.amd.com/manuals/nexusga.pdf
ATi PN 109-42600-00 (MAC only, PC cards are up to 8MB)
http://www.yjfy.com/images/oldhard/video/NEXUS_1.jpg
http://www.yjfy.com/images/oldhard/video/NEXUS.jpg
http://www.yjfy.com/images/oldhard/video/NEXUS_3.jpg
http://www.yjfy.com/images/oldhard/video/NEXUS_2.jpg
30+ MiniGL/OpenGL Win9x files for all Rage3 cards: Re: ATi RagePro OpenGL files
