Voodoo 2 DOS Glide compatibility matrix
Reply 200 of 365, by kanecvr
What about Uprising? I can't get it to run on anything other than my 4MB Voodoo 1, and it's not very smooth... on any Voodoo 2 / Banshee configuration it will hang at the loading screen... Any advice?
EDITED - woops - just noticed the title sais DOS Glide.... uprising is a windows game...
Reply 201 of 365, by boxpressed
Glad I saw this thread. I was all set to try the S3 version of Descent 2 when I discovered that my Virge card was dead. I was going to buy another one when I saw this thread. I downloaded the unofficial 3dfx patch instead and can play the game with my Voodoo 3 now!
Reply 202 of 365, by Tertz
Would be good to see a list with Voodoo 5 compatibility data for DOS and Windows Glide/native games. Voodoo 3, 4 are also interesting.
DOSBox CPU Benchmark
Yamaha YMF7x4 Guide
Reply 203 of 365, by meljor
voodoo3 is on page 2 of this topic.
Reply 204 of 365, by Gamecollector
Have tested my Voodoo2 with P4 3.0E/2 GiB RAM/6 GB FAT32 HDD volume/MS-DOS 7.1 (Win98 SE no GUI).
Have used uide.sys, shsucdx.exe and ctmouse.exe from Freedos 1.1.
All statically linked games not detect the Voodoo2, all .ovls except 3.03.00b and 3.02.02 not detect it too. It was expected, the CPU is too fast for them. Downclocking to 1.6 GHz have foxed .ovls but statically linked games still refuse to work.
There is 1 trouble.
Archimedean Dynasty freezes instantly even with the software renderer. To be more precise - both software .exes and the 3dfx .exe freeze the PC w/o any message.
Any suggestion?
Reply 205 of 365, by Tertz
Only for DOS. The situation with Windows games stays unknown, - there may to be issues too.
Probably the compatibilitiy of V3 and V4-5 was similar as we don't see any testing.
Yamaha YMF7x4 Guide
Reply 206 of 365, by PhilsComputerLab
At least the glide games I tried, worked across all Voodoo cards. But I admit, it was mostly Unreal, UT, Turok, Turok 2, Descent III and maybe some other games. But no exhaustive testing by any means.
YouTube, Facebook, Website
Reply 207 of 365, by alexanrs
Older Glide games (like Pandemonium) that use glide.dll instead of glide2x.dll will only work up to Voodoo2. I got Pandemonium working with a Voodoo3 on a K6-2 366 using dgVoodoo, though, but that is emulation (even though it is on a retro machine), as even my Voodoo2 gave me trouble (game running too fast, even with all the environment variables set).
Reply 208 of 365, by Stiletto
It's actually "wrapping", not what hobbyists consider "emulation" per se. 😉
do the Fandango!" - Queen
Stiletto
Reply 209 of 365, by FeedingDragon
I've been digging through my old games and looking for the ones I don't have. I've come into a couple of issues about the list that have been giving me a bit of a problem.
Every where I look the games Actua Soccer & VR Soccer 96 are listed as the same game, just with different names. The same seems to be true for Fatal Racing & Whiplash. Are they the same games or are they different games?
Also, NASCAR Racing 1999 Edition is listed as a Windows game (not DOS.) The ones I found on eBay, when I can actually see the requirements in the pictures, say Windows 95. Is there a DOS version of the game that I just can't seem to find?
Feeding Dragon
Reply 210 of 365, by Stiletto
They are the same games, given different names on different continents.
It had a Windows installer (and IIRC a Windows binary too?) but come with a DOS binary. Or something like that. Been a while since I looked at it but I'm sure vetz will remember.
Stiletto
Reply 211 of 365, by vetz
You are correct. Its the most "windowfied" DOS game I know about, Elderscrolls Redguard is another one. I dunno actually if they have a DOS installer at all.
Reply 212 of 365, by Gamecollector
Nascar Racing 1999 Edition - no DOS installer, DOS and Win32 glide executables. AFAIK is the only glide game with DOS and Win32 versions.
Plus there are DOS software, Win32 software (ddraw?) and DOS Rendition executables.
Reply 213 of 365, by alexanrs
About Dreams to Reality - is the DOS Glide version any better than the Windows D3D one? The Glide version is crashing both inside Windows and in pure DOS (though I haven't tested many glide2x.ovl versions) but my Voodoo 3000 seems to be able to handle the D3D version just fine.
Reply 214 of 365, by F2bnp
There's a D3D version ?
Reply 215 of 365, by alexanrs
It doesn't run like ass on my K6-2 366, so I assumed it was somehow hardware accelerated. It might be just DirectDraw though (windreams.exe).
Reply 216 of 365, by F2bnp
It's DirectDraw.
Reply 217 of 365, by dr.zeissler
I have some Problems with my V3+V1 Combination. Perhaps it's better to change the V1 with a V2.
Reply 218 of 365, by meljor
works perfectly fine:
Clean install 98se
install directx 7
install voodoo1 (i prefer the old diamond drivers first, and then a newer driver WITHOUT overwriting some file when asked)
install voodoo3
Now in some games you can simply choose for d3d, others pick the v3. Windows glide games that support the card will pick the v3. For older glide games that do not pick up the v1, install the v1 glide.dll in the game folder (same place as executable).
Same steps with v2 + v3, works perfectly.
I tried v1+v2 sli+ v3 just for fun in one system but that gave me troubles (v1 didn't work but should be possible)
Reply 219 of 365, by dr.zeissler
what are the "old" diamond drivers? http://falconfly.de/voodoo1.htm
To be correct:
- I installed Win98se (it detects the v1 but there are no drivers installed)
- I install the V3-DX6 driver
Schleichfahrt and Extreme Assault are working in Dosbox of Win98se with 3dfx.
When I boot Dos 6.22 and want to run some Dosglidegames I get several issues:
- Schleichfahrt: Does not run. It does not change the GFX-Mode. It stays in Textmode and freezes.
- ExtremeAssault: This Game works with the V1 under plain Dos.
- ShadowWarrior3Dfx: Game does not work. I alway get a white screen and nothing else, the machine freezes.
Doc
