DoZator wrote on Today, 09:57:
It is obvious that "SETUPDS /s" works before returning to Windows and changes all the necessary registers in one pass. Perhaps this is the peculiarity. We’ll need to try doing this using "RU" instead of "SETUPDS". But I already anticipate that in this case, we might also need to apply the registers twice in a row. We’ll need to take a register dump after "SETUPDS /s", and then try applying it using RU to verify this.
It might be the same with other sound cards. I would check this first.
In general, I checked this myself, and when returning to Windows, this method (with double register restoration) doesn’t work in this case. It only helps to revive the sound card after Windows so that it is detected by SBEMU and works correctly with it in MS-DOS mode. However, to return to Windows, it turned out that you need exactly "setupds /s", and a simple manual rewriting of the registers doesn’t produce the expected effect (even twice or three times). In general, this "setupds /s" in this case works some kind of special magic.. (I find it hard to even imagine what exactly it does and how it can be ported to all other sound cards that don’t have a built-in DOS configuration tool).
