Reply 20900 of 58609, by TheAbandonwareGuy
- Oldbie
wrote:This lot showed up at my door a day or two ago. May I add that I found all the auctions for it thanks to the now gone ebay thread or is it too soon? Anyway I already tested most of the interesting stuff. Sadly only the Asus P2L97 works, the P3B-F doesn’t even light its green LED when I supply power to it. By the looks its perfect so.. Also tested the 3 Voodoo 3 who looked like the could work, even though they are missing a lot of their caps, which I only realized later (see “detail” photo). Not really sure what to do with the 4th Voodoo as it is in the shape it is in. I kinda doubt it would work, even if I would solder another VGA connector. Also all TNT2 work but since I don't care about them in the slightest, I will probably try to sell all but one. A special place in my heart has the Orchid Voodoo 1 (thats the one with the mechanical relays and their soo satisfying click when the switch from 2D to 3D mode), I already have one of those but can't hurt to have a backup. Lots of stuff to play with, in one way or another 😀
If you buy an untested lot that is near 100 percent failures you've been scammed. They tested them bad, there just not telling you that. Any that work are probably flukes or they didn't test them properly.
Cyb3rst0rm.com: Here There Be Screeds https://www.cyb3rst0rm.com
