Reply 240 of 254, by DustyShinigami
Okay, my MT-32 has arrived! It’s all connected up and it’s powered, but I think I’m still missing something. I’m not sure if I ever asked about the red and white output cables…? Those are coming from my speakers and are connected to my SC-55, but… how would I go about hooking them/some up to the MT-32…? Do I need to daisy-chain between both modules?
OS: Windows 98 SE
CPU: Slot 1 Pentium III Coppermine 933MHz (SL448)
RAM: Kingston 256MB 133MHz
GPU: Nvidia 16MB Riva TNT/128MB Geforce 4 Ti 4200
Motherboard: ABit AB-BE6-II Intel 440BX
Sound Card: Sound Blaster Live Value CT4670
Reply 241 of 254, by Shponglefan
You mean the audio cables? If you want to hook up both the SC-55 and MT-32 at the same time, this is where you need a mixer or audio switcher.
Otherwise, you'll have to unplug the SC-55 and hook up the MT-32 in its place.
Pentium 4 Multi-OS Build
486 DX-33 with 5 sound cards
Reply 242 of 254, by DustyShinigami
Shponglefan wrote on 2026-04-07, 16:25:
Ahhhh. Okay. For some reason I was under the impression both could be hooked up together, but you have to toggle between them depending on the game and its setup. But thanks. I’ll have to look into that next. For now, I’ll disconnect the SC-55 so I can test it. 😀
Also, does it require totally different audio cables? It doesn’t look like the standard red and white ones connect.
OS: Windows 98 SE
Reply 243 of 254, by DustyShinigami
Okay, just watched Phil’s video. Looks like I’ll need to get an adapter or two. I don’t think I have what’s needed in my cable/adapter collection.
OS: Windows 98 SE
Reply 244 of 254, by Shponglefan
DustyShinigami wrote on 2026-04-07, 16:32:
Yes, the MT-32 uses 6.35mm audio jacks. Whereas the SC-55 uses RCA jacks.
Reply 245 of 254, by DustyShinigami
Shponglefan wrote on 2026-04-07, 17:05:
Yeah. Makes sense though considering how old the MT-32 is. In fact, as old as me. ^^ I've ordered those 6.35mm to RCA adapters. I think there's about six of them.
OS: Windows 98 SE
Reply 246 of 254, by DustyShinigami
Yeah, this is the space I have, between the monitor and case.
The attachment IMG_5452.jpeg is no longer available
I’m just a bit concerned how wide/big a mixer is going to be. Especially 6-10 channel mixers. I suspect they’re going to be far too big. 😕
OS: Windows 98 SE
Reply 247 of 254, by orcish75
DustyShinigami wrote on 2026-04-07, 22:18:
The 6 channel is narrower than the SC-55, the 10 channel is about as wide as the SC-55, perhaps ever so slightly wider. They're much smaller than pro mixers.
These 6/10 channel mixers use 6.35mm stereo jacks, so you'll need a 6.35mm stereo to dual RCA cable for the SC-55 and a 6.35mm stereo to dual mono 6.35mm for the MT-32.
https://www.amazon.com/Yeung-Qee-6-35mm-Stere … B08NZJ7XLC?th=1
https://www.amazon.co.uk/Ome-Audio-6-35mm-4-I … B0F3VXS41B?th=1
You can get 6.35mm to 3.5mm adapters, but you're introducing more connection points and thus increasing the chance of ground loops and bad connections. Rather get cables like those linked above to minimise the chances of bad connections.
Reply 248 of 254, by DustyShinigami
orcish75 wrote on 2026-04-08, 07:12:
The 6 channel is narrower than the SC-55, the 10 channel is about as wide as the SC-55, perhaps ever so slightly wider. They're […]
Awesome! Thank you. 😄 I have ordered myself about six of those 6.35mm to RCA adapters, which should be arriving today. These:
https://amzn.eu/d/0fv9qXG2
OS: Windows 98 SE
Reply 249 of 254, by DustyShinigami
Okay, the MT-32 measures at about 30.5cm wide, so if a mixer is less or around that, I should be fine anyway. I do have my eye on one on eBay. A 6 channel one. Google says it's a COKYSIS MIX600 PRO, although the COKYSIS label doesn't appear to be on the unit.
OS: Windows 98 SE
Reply 250 of 254, by Shponglefan
DustyShinigami wrote on 2026-04-08, 09:38:
Just note that these are mono jacks.
If you're planning on using things with one of those stereo mixers, you may need stereo adapter jacks.
Reply 251 of 254, by Shponglefan
DustyShinigami wrote on 2026-04-08, 13:53:
The brand/labeling doesn't matter. These are all the same sort of Chinese hardware that shows up on Amazon often under a variety of "brands".
Looking them up on Alibaba, they're listed as the "Enping Guanyi Electroacoustic Equipment Factory".
Reply 252 of 254, by DustyShinigami
Shponglefan wrote on 2026-04-08, 14:09:
Right, okay. Thanks for the heads-up. 😀
OS: Windows 98 SE
Reply 253 of 254, by DustyShinigami
Shponglefan wrote on 2026-04-08, 14:13:
I see. Huh. Interesting. Are these known to be any good? I just wouldn't want to get something that does the job, but only for so long until they go wrong.
OS: Windows 98 SE
Reply 254 of 254, by Shponglefan
DustyShinigami wrote on 2026-04-08, 14:24:
I have no idea as to the quality of those.
I've only used the Edirol (Roland) mixers on my setups.
