Reply 240 of 642, by Repo Man11
- l33t
My Soyo Dragon, one of my favorites, a project that turned out well. I've played through Max Payne and Half Life on this system. After I had recapped it, I found there was a mod that could be done to allow the use of throughbred core CPUs (fellow Vogons members helped me track down some information that had been lost). I tried an Athlon mobile with it, but it was hit or miss on POSTing with that CPU so I gave up on it.
I hadn't powered this thing on in a while - it takes longer to POST than any other motherboard I've ever had. It doesn't seem to be a problem, just a quirk with this board, but you start to get nervous when you hit the switch and hear nothing but the fans for longer than you'd expect.
A lot of times when you first start out on a project you think, This is never going to be finished. But then it is, and you think, Wow, it wasn't even worth it. - Jack Handey
