Clock generators on Socket 7 and older motherboards
Reply 26 of 102, by dosgamer
Board: Asus PCI/I-486SP3G
Clock IC: Macronix MX8315PC
Datasheet: http://images.ihscontent.net/vipimages/VipMas … /MXMAS016-1.pdf
The attachment asus_sp3g.png is no longer available
Certainly has some overclocking potential for a 486 board 😁
Edit: The MX8315 also has a pin that drops the CPU clock down to 8MHz when pulled low. This doesn't seem connected to anything/have anything to do with the turbo switch input that this board also has. Maybe the two could be used simultaneously?
Coppermine Celeron 800 @ 1.12GHz (8x140) - Asus P2B Rev. 1.12 - 256MB PC133 CL2 - Voodoo5 5500 AGP - SB AWE64 CT4520 - Roland SCC-1 - Intel Pro/1000GT - 1.44MB Floppy - ATAPI ZIP 100 - 120GB IDE - DVD-ROM - DVD-R/RW/RAM - Win98SE
Reply 27 of 102, by lazibayer
Not S7 or older but what the heck!
Shuttle HOT-637 V3
ICS9150F-04
source
Reply 28 of 102, by lazibayer
dosgamer wrote:
Board: Asus PCI/I-486SP3G Clock IC: Macronix MX8315PC Datasheet: http://images.ihscontent.net/vipimages/VipMas … /MXMAS016-1.pdf […]
Put a 5x86 on it and crank it to 80 x 2! 🤣 🤣 🤣
Reply 29 of 102, by lazibayer
Motherboard: MSI Premio TX5
It has two versions, one with ICS9148-04 PLL-IC
The attachment Screen Shot 2017-06-23 at 10.07.47 AM.png is no longer available
The other with IMI SC653AYB
The attachment Screen Shot 2017-06-23 at 10.13.59 AM.png is no longer available
cyclone3d reported in this thread that the ON-OFF-ON combination on the IMI version gives 100MHz bus speed! 😳 😳 😳
Reply 30 of 102, by lazibayer
ECS P5SJ-A uses ICS9169CM-23, the same as SP97-V.
Reply 31 of 102, by cyclone3d
lazibayer wrote:
Motherboard: MSI Premio TX5 It has two versions, one with ICS9148-04 PLL-IC […]
So I finally had a chance to test out this board some more. I never did really do anything even when the 166MMX was in there except test the POST with some different video cards.
The events are not necessarily in the order listed below, but it makes more sense to stick with what I tried with the different CPUs.
I first put in a Pentium 233MMX that I recently received and I was able to get it to POST at a reported 250Mhz at the supposed 100Mhz fsb setting. I was also able to get it to POST at 300Mhz by raising the voltage to 2.9.
I tried all the way up to 3.1v and the only difference it made was that it reported 266Mhz when at 3.0v and 240Mhz when at 3.1v. Something is definitely screwy with that fsb setting.
However, it freaks out when it gets to the second screen where it should be listing the CPU speed, RAM, IRQs, etc. Just locks up. I think either the board is trying to run the PCI bus at 50Mhz at that setting or something else is going on like it needs more I/O voltage of which there is no adjustment for.
I also tried with a K6-III+ 450 and although it POSTED, even at the 4.5 multiplier at the supposed 100Mhz fsb setting it had the same issues as the 233MMX did. I tried all the way down to the 2.5 multipler and it still did the same thing. THE CPU speeds reported were way off. Guessing that is because it only officially supports the original K6 CPUs.
So I guess I am just going to make it into a 233MMX system and be done with it. I could run at the 75 or 83Mhz fsb setting, but I really don't need to as I have other builds in the works that will cover faster speeds.
Yamaha XG repository
YMF7x4 Guide
Aopen AW744L II SB-LINK
Reply 32 of 102, by lazibayer
cyclone3d wrote:
So I finally had a chance to test out this board some more. I never did really do anything even when the 166MMX was in there exc […]
Thanks for the tests! Sounds like the 100MHz setting is messing up the mind of the poor board's BIOS. 🤣
Reply 33 of 102, by lazibayer
Was curious about the possibility of overclocking the FSB of pentium pro. So far no luck.
ASUS XP6NP5: W48C60-414G, 2 jumpers, 4 combinations, 60 and 66MHz marked out and two others undocumented.
Gigabyte GA-686NX: PLL52C59-14LSC, 1 jumper
Micronics W6-LI: W48C60-404G, 2 jumpers, 4 combinations, 60 and 66MHz marked out and two others undocumented.
Reply 34 of 102, by lazibayer
ASUS P2L97 Rev. 2.04
ICS9148B-04
file.php?id=37662&mode=view
Thanks shamino for sharing this info.
Reply 35 of 102, by infiniteclouds
Did you discover these through just experimenting with jumper settings?
I wonder if my AOpen X59 motherboard has hidden settings... I was disappointed when I saw it didn't have settings for lowering than 66FSB.
Reply 36 of 102, by lazibayer
Most of the settings are taken from the datasheets of the clock generators. What's the model number of your board's clock generator? We can try and see if there is a datasheet for it.
Reply 37 of 102, by infiniteclouds
is this what I'm looking for?
BjZhHHO.jpg?1
I never wanted to just haphazardly try other jumper configurations on here for fear of frying my board and/or GPU. The manual has configurations for 66, 68, 75, 83, 95, 100, 112, and 124 FSB speeds but give a warning saying that it only supports a maximum of 100FSB and that 112/124 is for internal test only. I'm only interesting in seeing if it can go below 66, anyway.
Reply 38 of 102, by lazibayer
The winbond chip is tag-ram. The half-cropped chip at bottom left is the clock generator.
Reply 39 of 102, by infiniteclouds
This is that chip from the bottom left --
UtWE8jM.jpg?1
Reply 40 of 102, by lazibayer
Thanks. I can't find the datasheet for W48S87-27AH but I did find W48S87-27A and W127/W127-A. The former does have 60MHz and 90MHz settings but it lacks 95 and 124, so it's not the same as yours. The latter is an updated version of the former but it only has the 8 frequencies you listed above:
The attachment Screen Shot 2017-09-04 at 10.45.50 PM.png is no longer available
Not sure if the combinations can match the jumper settings on your boards manual. Interestingly it uses 2/3 and 1/3 divider for AGP and PCI at 83MHz.
All three chips have 48 pins, so I reckon it's unlikely for yours to have any hidden combinations.
Reply 42 of 102, by gdjacobs
The W127 PLL is used in other (presumably later) versions of the AX59 Pro. I suspect it's a complete drop-in replacement for the -27AH.
Reply 44 of 102, by lazibayer
ASUS P2B-B Rev. 1.02
W83194R-39A
Reply 45 of 102, by lazibayer
HOT-569/A
ICS9148BF-04
