Clock generators on Socket 7 and older motherboards
First post, by lazibayer
I like collecting information on clock generators since they tell you if there are hidden jumper settings, but I couldn't find such pool of data so I will start my own. I will start with a few and update whenever I spot a clock generator on the web. I like Socket 1~7 boards since I know little about older boards and I don't like the jumper-less newer boards. Everyone is welcome to post the model of clock generator on your motherboards.
So I will start with the famous ASUS P5A-B (Rev. 1.04)
Clock generator: ICS9148BF-53
Everyone knows that it has hidden jumper settings for 125 and 133MHz, but actually it can do more than that 😎
97.11 KiB
No downloads
FIC 486-GAC-2
Clock generator: VT8225N
The board only prints 25 and 33MHz, but the chip is able to range from 2 to 50MHz 🤣
And it actually boots at 2MHz!
18.43 KiB
Boards with VIA VT82C496G / VT82C406MV chipset
The clock generator is built inside the chipset and the control logic is a little complicated. It takes 7 bits to decide the CPU clock and another 4 bits to decide ISA clock. A board may not have that many jumpers but you can enumerate all the possibilities if you know how to manipulate the chip's registers!
157.05 KiB
No downloads
Reply 1 of 86, by lazibayer
ASUS T2P4 Rev. 3.10
Clock generator: PLL52C61-01HSC
Highlight: it reaches as low as TCLK/2, i.e. 7MHz with 14MHz crystal, great for low record lovers!
--UPDATE 12.23.14-- It won't boot if set to TCLK/2 😢
78.42 KiB
No downloads
Compaq Prolinea 197023-001
Clock generator: AV9155-03CW20
The chip can generate 16 different clocks but the board only gives you one jumper for clock! Time to heat your iron, man.
42.13 KiB
HP Compaq PWA-PWA CAMARO
Clock generator: ICS9248AF-127
MVP4 chipset. Ranges from 60 to 124MHz, quite typical for SS7 platform.
59.07 KiB
Reply 2 of 86, by lazibayer
Abit AB-AX5 Rev. 2.21
Clock generator: PLL52C62-02XC
I can't find the IC's datasheet. The board has the "jumper-less" feature that I don't like. For example, once it detects 6x86/6x86L processor it locks the multiplier at x2. Although the other multipliers of 6x86, x1 and x3, are not that useful, but I prefer more choices.
Gigabyte GA-5SMM Rev. 1.2
Clock generator: W153BH
I can only find the datasheet for W153B, which shows even less options than the board's manual. I have cross-referenced the manual and the datasheet, and filled out the blanks with experiments. The values with "~" are estimated by Sandra RAM bandwidth test, "*" are reported by Sandra, and "?" means no way to find out (I tried Sandra, AIDA32 and Everest). The board supports PCI 1/4 divider and works stably at 133MHz FSB (L2 and onboard VGA disabled).
66.06 KiB
No downloads
ASUS P5S-VM (Rev. 1.01 & 2.02)
Clock generator: ICS9248AF-81
Pretty standard for SiS530 boards. Supports PCI 1/4 divider and works stably at 133MHz FSB (L2 and onboard VGA disabled).
43.29 KiB
Reply 3 of 86, by lazibayer
ASUS TXP4-X Rev. 3.01
Clock generator: ICS9169CJ-27
It supports 7MHz FSB! 🤣
26.18 KiB
ASUS TX97-X Rev. 2.03 & 2.05
Clock generator: ICS9147F-03
Also 7MHz certified! Do I have an obsession with 7MHz FSB? 😕
--UPDATE 12.23.14-- It actually boots with 7MHz FSB! 😁
27.01 KiB
ASUS TX97-XV Rev. 1.13
Same as above!
ASUS TX97 Rev. 1.21
Clock generator: ICS9147F-09
18.05 KiB
ASUS TX97-XE Rev. 3.01
Clock generator: ICS9169CJ-272
27.49 KiB
Reply 4 of 86, by gerwin
Thanks for sharing this information!
I always check the type of PLL clock generator when selecting a retro motherboard. Unfortunatey it is usually impossible to determine from all but the sharpest photos.
Super Socket 7 and Slot-1 boards with SMBus enabled PLL chips are usually listed in FSB selecting programs. Meaning that if you open the database of SoftFSB, CPU-FSB or SiSoft Sandra one can find the PLL type for all supported motherboards.
Me neither, Good to agree with someone on this. 😀
Reply 5 of 86, by lazibayer
Yup, most of the models are from eyeballing sharp online pictures. It would be great helpful if everyone can participate and post their PLL's info 😊
I am trying to focus on the older boards that do not support soft FSB adjustment.
Reply 6 of 86, by lazibayer
Elitr UX584VIO-A Rev. 1.2
Clock generator: ICW43C94-146
Can't find data sheet for this one 🙁
Shuttle HOT-433
Clock generator: MX8315PC
40.39 KiB
Shuttle HOT-541
Clock generator: AV9154A-42
Range: 16-66MHz
31.02 KiB
Reply 8 of 86, by lazibayer
ASUS SP97-V Rev. 1.02
Clock generator: ICS9169CM-23
7MHz supported, but won't boot if you set so.
16.56 KiB
Reply 10 of 86, by lazibayer
GA-586T2 Rev. 1.2
Clock generator: ICS9148F-25
The board only provides 2 jumpers. Might need hard mod to get 83MHz.
27.1 KiB
Reply 12 of 86, by lazibayer
ATC-1000+
Clock generator: ICS9159M-14
Bo~~~ring~~~
22.42 KiB
Reply 14 of 86, by Stiletto
lazibayer wrote:
ASUS PVI-486SP3
Clock generator: VT8228N
Datasheet not found 🙁
Agreed, cannot find this one anywhere. I wonder how VIA would react if you asked them for it, or who exactly owns this obsolete intellectual property now (they've been bought and sold a bunch of times IIRC.)
The best you can do for this board is refer to the jumper settings:
http://stason.org/TULARC/pc/motherboards/A/AS … tml#.VJbzW1AAcA
http://gboeger.de/Computer/Asus_PVI486SP3/pvisp3-cpu.html
dlsvr01.asus.com/pub/ASUS/mb/sock5/486sp3/pvi_486sp3.zip (page 9 of the PDF)
and 5u3's experimentation: Re: Test:486 undocumented jumper settings
do the Fandango!" - Queen
Stiletto
Reply 16 of 86, by lazibayer
Some hard-to-identify OEM boards on ebay:
The first one looks like Packard Bell 680/682/685 series but has NEC BIOS
http://www.ebay.com/itm/430VX-Socket-7-mother … =item43d4eaca4c
Clock generator: CY2260SC-2
Nothing more than 50/55/60/66
75.25 KiB
No downloads
The second one is a DEC 486SX board
http://www.ebay.com/itm/vintage-intel-i486sx- … =item1c470ca576
Clock generator: CH9001CC-SC
116.5 KiB
No downloads
The third one is a Gateway 486DX2/66 board
http://www.ebay.com/itm/Gateway-09-00144-01-4 … =item4874664008
Clock generator: AV9155-01CW20
21.26 KiB
Ebay has been an important source for me to identify motherboard models and their PLL chips. I listed the ebay links for the above boards since I don't know how to accurately describe these boards. It would be great if some one can help me identify them so I can replace the links with models and revisions, otherwise the links will expire some time.
Reply 17 of 86, by Stiletto
lazibayer wrote:
5u3 wrote:
lazibayer wrote:
ASUS PVI-486SP3
I tried the combinations for this one a few years ago: Link
Thanks for the input!
Whoops, 5u3 must have posted while I was writing mine. 😀
Stiletto
Reply 18 of 86, by lazibayer
Shuttle HOT-419 R2 & R3
Clock generator: AV9107C-03
The table is misaligned by one return.
32.25 KiB
FIC 486-GVT-2
Same as 486-GAC-2
Reply 19 of 86, by Stiletto
So re-do it? There was also an error in the "truth table" in column 1 row 4 it seems. 😉
31.65 KiB
Stiletto
